Question about Rheem Water Heaters
Electric Water heater not heating all of sudden
If you have tankless, then open following link before calling service technician.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If you have ordinary tank-type electric water heater, then reset button is probably tripped out, or circuit breaker is not delivering power to heater.
Reset circuit breaker, then open cover located on side of tank and push in ECO red reset button.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/How-water-heater-thermostat-works.html
If you have boiler or indirect heater or solar heater or faucet-type heater, I would need more information, and might not be able to provide best answer.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 20, 2011
Why no power to pump?
[PDF]residential hybrid electric heat pump water - AO Smith Water ...
www.hotwater.com/.../hybrid-electric-heat-pump-service-handbook-(32...
... MAINTENANCE -. OPERATION & SERVICE - TROUBLESHOOTING ..... Tools for servicing residential electric heat pump water heater models: • Container (to ...
How to troubleshoot electric water heater - Water Heater Timer
waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-...
How to troubleshoot electric water heater. ... 2) Heat pump electric water heater has fan and compressor and will make sound when operating Read 3) Clean ...
Jan 01, 2016 | Water Heaters
Why does the water suddenly runs COLD after many minutes of running hot?
Unless you are using a tankless hot water heater, there is a limited amount of hot water available in the tank. Electric and gas water tanks need time to recover after use, and if you are using heavily, it can exhaust the available supply. That said, there are a couple reasons why you may have less hot water than seems normal. In both electric and gas water heaters, silt can form in the bottom of the tank. This will build up over time and displace water. It also reduces the heating efficiency of gas units. There is a drain valve on the bottom of water heater tanks to allow for purging of this silt periodically, but few ever do it. You could also have, in the case of an electric hot water heater, a bad element or thermostat. Most electric heaters have an upper and lower element and thermostat. If one fails the other will still work, but the water takes longer to get hot and will deplete faster.
Nov 04, 2015 | Water Water Heaters
Why do I suddenly have no hot water in my electric Premier Plus water heater?
1st check the circuit breaker that supplies power to the water heater. If that is OK then check and see if you have power to the heating elements on the water heater. If not then check and see if the thermostat on the water heater has power to its connections and verify that it is calling for the water to be heated. Last if all these checks are OK then you must have a burnt out heating element. Some can be replaced but you will have to drain the water from the heater before replacing the elements.
Feb 22, 2015 | Water Water Heaters
Ticking sound top 1/3 of AOSmith Electric Water Heater
Replace heat trap nipples or inserts?
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#heat-trap
Factory Heat traps save $2-$9 per year but can cause noise, and you can make your own heat traps.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#heat-trap
Electric water heater is probably the only household appliance made today that can be maintained and repaired by homeowner to last almost indefinitely. Certainly no other water heater can last as long, even with maintenance.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Add a comment and say what you find
May 06, 2013 | Water Heaters
No hot water
10-22-12
Copy following links to help identify product and download possible troubleshoot resources:
Tank-type gas
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Tank-type electric:
Rheem tankless:
Other types of water heaters include boiler, tankless electric, indirect, solar-assisted, solar, hybrid electric, heat pump, wood-burning, gas hybrid, 3-phase commercial electric.
Oct 21, 2012 | Rheem Water Heaters
No heat the water.
Suddenly no hot water: Red reset button tripped, circuit breaker tripped, bad upper element, bad thermostat, loose wire, TP valve is running hot water out of tank, leaking faucet is running hot water out of tank.
1) Check for leaks.
2) Check circuit breaker.
3) Open top cover on water heater and push in red reset button.
If reset is popped out and will not reset, replace thermostat:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
4) Test upper element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
5) Loose wire
Do full troubleshoot:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 01, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a model 71-408 B which just stop heating
If I understand correctly, you have electric water heater.
Heater suddenly stopped heating.
Four things cause sudden loss of water heater.
1) Reset button located under the top cover is tripped > turn off power, remove cover, press reset button > if reset keeps tripping, go to the troubleshooting link shown below.
2) Electric power to heater is interrupted > check circuit breaker > test for voltage > look for loose wire on breaker
3) Upper element burned out > test and replace element
4) Upper thermostat bad > replace upper thermostat
Reset button is best suspect.
Here is a link for complete troubleshoot and homeowner repair of electric water heater:
Nov 19, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
All of a sudden, no hot water. No red light....what to do? Already checked the breaker.
Bottom heating unit is probably burned out from overheating due to sediment in bottom of tank.
Feb 26, 2010 | AMERICAN STANDARD Electric Water Heater
Water Heaters Logo
171 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
