I have two U3011 dell monitors that have half the screen coming up as a yellow/blue tinge, i have tried to clean the connectors between the main board and the t-com as well as the connectors between the t-com and the panel.
MicrowaveSvc
  • 9086 Answers
SOURCE: monitor color changed
Assuming you can rule out the PC and the cable (are the pins ok?) then it sounds like it needs component-level electrical troubleshooting.
Posted on Jan 12, 2007
CoachTim
  • 202 Answers
SOURCE: Everything has a yellow tinge.
Have you tried giving it a good tap on the side? Hey its worked before. Have you tried hooking it to another machine to verify "yellow." Was it yellow on your friends computer? How old is the monitor? Good Luck, Tim
Posted on Feb 08, 2007
  • 3940 Answers
SOURCE: my monitor is blue
this could be as simple as reseating the cable connections to the video card. If reseating doesn't resolve, try flexing the video cable the entire length of the cable and see if you can locate a spot in the cable where bending it causes/fixes the issue. If bending the video cable causes the issue to change, then there is a broken wire in the cable.
If that doesn't help, then you may want to look at buying a replacment if the monitor is out of warranty as they are usually cheaper to replace than repair.
Posted on May 14, 2008
Marrie
  • 563 Answers
SOURCE: Yellow middle, Blue Exterior
Hi Druaga
This is a Blue LCD Polarizer that will have to be replaced if the spot shows yellow.
You will find that this will only get worse as time goes by.
Posted on May 28, 2008
SOURCE: ds touch screen and main screen not working - connectors broken
$90 you robing sod
Posted on Mar 15, 2009
Half my screen is a blue square stating
Unfortuneately the only solution is to replace the monitor because the LCD panel is defective or the main processing board that is attached to the back of the display panel.
Sep 16, 2012 | Dell ST2420L 24 inch LCD Monitor
Everything on the screen is in a blue tint. Applications work, but nearly unreadable due to the tint. I made no changes to any settings.
Check all connections to the monitor and try it on another computer. If the tinge is gone on another computer, check graphics card on your computer. If the tinge does not go, the screen is failinga nd will need repairing (but most likely replacing)
Jan 12, 2011 | Acer AL1914 19" LCD Monitor
The color on my tv has gone crazy. There's either a blue tinge or a yellow tinge when I adjust the colour (so either people look like they are faintly related to a smurf or have scurvy!!). I am also...
I would suggest to unplug the TV from the AC power outlet first, wait a couple of minutes to plug it back in. If that does not work, the main board is defective since is not providing proper video info to the main digital controller board (D board). The Main board part number is: TNPH0721AJS or TNPH0721ADS. If you need to verify the main board part number, you will need to remove the back cover of your plasma to check it out.
Let me know if you require further assistance.
Nov 27, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Viewsonic vx2835wm monitor, in DVI mode connection, altough getting signal from the PC(Other monitor connected and tested for graphic card problem-No graphics card problem!!) , Prompts "No input-signal"...
You will need to change the resolution of the screen on the computer to 800-600 and the bit to 24bits or 16bits, to do this right click on the windows screen, and click properties, goto settings.
You should see a slider at the bottem left of the screen to adjust the resolution, and a drop down bar on the other side for the bit rate. This should solve the problem, also you could open the scond screen also in the display properties, and drag what you need to see on the screen to that screen, you will know what i mean when you open screen 2 it just expands the desktop. hope this helps.
Aug 21, 2010 | ViewSonic VX2835wm Monitor
The right half of the screen is darker that the left side making it hard to read or see tings on that side.
call dell support and have the service tech do the parts replacement.
video card or LCD need to replace.
try to connect to a desktop monitor if the issue are the same , its video card
if not..LCD
Mar 20, 2009 | Dell XPS M1710 Notebook
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
Dell Inspiron 2200 monitor issue
Could be that the monitor is going out, but it sounds more like a connector has worked loose or corroded and isn't making a good contact. Check and clean the screen connection, screen to inverter, and screen to motherboard.
Jul 13, 2008 | Dell Inspiron 2200 Notebook
Hi Druaga
May 28, 2008 | Panasonic PT-AE700U Multimedia Projector
Feb 07, 2007 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
