Question about Garden
I have a Poulan Pro 54" riding mower, 25 HP Kohler. The problem is the steering. It turns all the way left no problem, but will only turn about 2/3 to the right. I though maybe the drag link was bent, replaced with no luck. Nothing appears to be damaged....but I guess anything is possible. Final note: when I max out the steering to the left to the steering stop....I've noticed there is still a few teeth left on the steering shaft area...can you help? Thanks for your time.
  • 1 more comment
  • Jeff Johnson May 20, 2011
    How many teeth are left on the steering shaft area when you turn it to the right as far as it will go? Maybe you are just off center?
  • magnakid May 20, 2011
    Looks like about 3 teeth left...not actually on the steering shaft....but the "fan" gear that it drives
    re-read your comment....when I turn to the LEFT...it has the 3 teeth remaining...almost like if the steering stop wasn't there,,,it'd turn some more! when I max out to the right (maxed out where the steering shaft drives the fan gear) there is still plenty more to go at the steering stop near the front wheels...hope this clarifies my prob
  • 86 Answers
SOURCE: riding mower steering non responsive
Check your ball joints
Posted on May 10, 2009
  • 323 Answers
SOURCE: I tipped my poulan riding mower up from the right to check belt
If you remove the plug(s) so that the oil all drains back down, and some will drain back out of the muffler, it should start. But give a at least one day, maybe two. You may still have to put new plug(s) in it after it's gone. Check the fuel filter and see if you can see oil in it.
Take off the air cleaner when you get ready to start it and spray just a little starting fluid in the carb, Don't choke it. It will run rough and smoke like crazy, but after it runs a while it should be fine. It make take a few starts before it continues to run. At first it may run just on the starting fluid, but once the plugs fire up enough to burn the oil out it should run on its own.
Be sure and check the oil and if it seems like the slightest amount of gas in it, change the oil and filter.
Let us know how it comes out!
Sirwriter
Posted on May 16, 2009
  • 6 Answers
SOURCE: Craftsman riding lawn mower wheel toe needs adjustment.
put it in reverse ton the wheel to the right and hit the wall again....or ir you were backing up when u hit the wall runn into foward
Posted on May 19, 2009
Dolfoff
  • 148 Answers
SOURCE: craftsman riding lawn mower steering shaft fell.
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
Having trouble removing drive belt
Remove belt from opposite end so you don't fight with clutch end.
Jul 02, 2015 | Ariens Max Zoom 60 in. 25 HP Kohler...
Kohler command pro 23 engine model cv23s manuel
that engine uses 2 so if you have no spark from either one check your safety switches unplug the harness going to the engine and try then some have a module check for power in
Jul 02, 2012 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Jun 14, 2012 | Garden
I have Poulan Por 54 inch deck,25 hp Kohler hydrostatic. After I mow on unlevel ground for about 30 min. Transmission makes noise jerks and won't go till it cools off. Will changing the fluid help
couldn't hurt to try but some cheaper mowers don't have a drain plug look on a parts break down on sears parts online but check the belt tension first
Apr 13, 2012 | Garden
My 54" Poulan Pro riding mower dies when the
battery weak replace or charge, mower has electric clutch which pulls amps from battery
Jun 26, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Turns fine to the left but will not turn right past going straight.
check your steering linkage on the front side by that right hand wheel, is it bent or being restricted? Even check up and down on the steering wheel column itself.
Aug 13, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
