Two days back there was heavy winds and due to it power outage. AC was working fine before but when power was back it didn't cooled. compressor tries to pick up but in vain. what could be the possibilties.
    Genius:
  • 1,015 Answers
It may have lost one leg on the power incoming. It should be 220-240 so if you have a volt meter you can check the incoming power to the contactor. If you are not familiar with electrical work I would recommend that you get a service tech to do it for you. The good news is that if the compressor is trying to start then it probably is not burned out. If you have a disconnect switch by your condensor there may be two fuses in there so check them to make sure they are good.Thank you.
Posted on May 20, 2011
Frigidaire model number FRS6R5EMB8 Not cooling
Feel the top of the compressor and tell me what you feel
Oct 09, 2015 | Frigidaire Refrigerators
AC trips circuit breaker not long after a recent power outage.
Sounds like your compressor is shorted to ground. If you are able, unhook compressor, wrap wires and restart. If breaker doesn't trip than u know.
Jun 07, 2017 | DeLonghi Heating & Cooling
No AC, then recharged, now compressor makes on/off clicking noise while running with AC on
This still sounds like low pressure. If you re-charged a system that was low, and didn't pull a vacuum and evacuate the system first, then you still have air in the system, which is causing the compressor to cycle on and off.
Jun 07, 2012 | 2006 Ford Taurus
Hi, I have a Central Pneumatic air compressor model 94667. The start capacitor burned, so i replaced with a similar size cap. It went fine for 3 minutes and the new capacitor got smoked and started to pop....
We get many chinese compressors with burned capacitors. Most seem to use a 140 uf 250v ac metal run cap.(fairly large metal ). The cap will test bad but not look burned. The motors look pretty crude in the way that they are wound (no start winding) and varnish used on the wiring will not take the heat like other motors. Most likely faulty windings. If you try another cap (or two caps to make value)make sure that the voltage is 250 or higher and run type (metal or light color plastic, not the black start caps) (the higher the voltage the better the quality of materials used ). If the checkvalve is faulty at the tank, the motor will have a higher load at start and run (with out start winding motor works harder to start, if all components are not working correctly, motor /cap will overheat ). Check before next test. Good luck
Sep 26, 2011 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
I have a goodman central air unit. It was not cooling had service man out the first one said the compressor. So he was sending someone out to replace the compressor. That guy said it was not the...
Calll him back out. It sounds like the air cond. is losing refrigerant rather quickly. When the refrig. leaks off, the compressor over heats and kicks off on internal overload. The first guy probably didn't see that, but the second guy caught it, but didn't check to see where the refrigerant leaked off. Call him back they should warranty the refrigerant if it is all leaked off again
Jul 16, 2011 | Goodman Heating & Cooling
Has been off due to power outage. when turned on will not cool or freeze
Power failures can damage the control boards. If the power is back to the unit, but it still won't come on, the control board will need to be replaced.
Furthermore, check whether fans are running, then it is indicating a compressor problem. It could be a restriction in the compressor may not be pumping. You need to call the technician to get it repaired.
Hope this helps.
Shane
May 02, 2011 | Whirlpool Refrigerators
The AC stops blowing air for a while and then re-start working normaly.
Have you noticed that the AC quits blowing cold air when you are heavy on the throttle, or climbing a hill? Does it return to blowing cold air when you let back off the throttle and relieve the load from the engine?
If you answered YES to those questions, your AC is operating normally. AC compressors take quite a bit of power from the engine to operate. In vehicles with smaller engines, the AC compressor will disengage when there is a heavy demand for power placed on the engine, and you will not get cold air. When that demand is gone, it re-engages power to the AC compressor.
Dec 03, 2009 | 2006 Mazda 3
Whirlpool side by side ice maker not working
If your refer is running during a what is called a brown out it can burn the compressor windings. If you are not getting anything check the breaker first. Is the unit running at all? Check your terminal block under the refer where the power cord comes in and check for a burnt contact. After those are checked we can go from there.
Dec 26, 2007 | Whirlpool GS6NBEXR Side by Side...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
