Question about Philips Audio Players & Recorders
I have philips home theater HTS 3455/98,and sub woofer unit type HWS250/00,any one have a schematic diagram for power supply unit HWS250-GG?i need the type of part T6 and T7,i cant see the type,because of damage,thank you
CompuGuy44
  • 432 Answers
SOURCE: Wiring Schematic
You can get what your looking for here: http://www.manualdirectory.co.uk/Audio___Hi_Fi_Resources/Panasonic/Panasonic_Home_Theater_Systems/index.html http://www.retrevo.com/s/Panasonic-SC-HT17-Home-Theater-Systems-review-manual/id/356bh949/t/1-2/
Posted on Jun 27, 2007
VOTIT
  • 2071 Answers
SOURCE: leads
Most of all electronics accessory or parts you can buy it in electronics shop.The leads you said is the RCA cord,input in dvd player output to home theater subwoofer.Tell the shop that you need RCA cord from dvd player to home theater sub woofer.Or you can order it in the site just type googles and search for electronics accessories.That's all jon-jon txt me what the result.
Posted on Jun 16, 2008
SOURCE: Unlock HTS 3555
works very well for my PHILIPS home theater HTS3545 as well - semi
Posted on Aug 04, 2008
moz205
  • 80 Answers
SOURCE: Problem w/ Panasonic SA-HT700 speakers
Try looking in the audio settings,it might be configured for stereo/mono or any number of surround sound settings e.g; 5:1, 7:1 In which case it might shut off the power to the circuit board inwhich the speakers are connected.If that fails .......Take it back!! Either the connection inside the speakers is faulty or the connections in the unit are faulty.
Posted on Oct 25, 2008
  • 71 Answers
SOURCE: HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Posted on Jun 24, 2009
Does anyone have a schematic for a Tannoy HTS Sub Woofer
Email or phone them direct using details in the manual
The instruction manual is here, but no internal wiring diagram.
http://media.datatail.com/docs/installation/65352_en.pdf
Feb 08, 2016 | Audio Players & Recorders
Model No. PWR2006-37. Where can I buy a power supply?
Before rushing off to buy a replacement power supply, open your sub and check for a blown fuse.
Sep 01, 2015 | Philips Hts3450 5.1 Channel Home Theater...
I need to connect a subwoffer VGA with an stereo receiver. Do you know where I can find a cable to do this?
i have hts 3455/98 i connect perfectly all cables but sound is coming from only one speaker. pl help me about this problem.
Mar 28, 2013 | Philips HTS3450 System
Hello! Pls, send diagram connector to sub-woofer Samsung HT-DS1000. I want to connect low signal(Sub woofer) direct to amplifier. If connect to AUX - sub woofer sound with delay, no good sound. Thank...
The speaker connections are documented in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-DS1000-Home-Theater-Systems-manual/id/287ci764/t/2/
Are we talking about an external add-on sub not supplied with the HT-DS1000? If so, please identify it.
The interconnecting cable itself is a 13-pin DIN.
Mar 07, 2011 | Samsung HT-DS1000 System
The power supply, LCP106830-0001 is bad. I need a schematic for Philips HTS-3555/37 and new poser supply to repair.
You won't get voltage if you completely disconnect the lcp106830 power supply from the board. The connection to the front panel is required and is used as feedback. I just repaired one and found one of the power diodes faulty.
Dec 20, 2010 | Philips HTS-3555 System
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
I bought philips 5.1 home theatre for PC it is not supporting
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jul 02, 2008 | Philips HTS3450 System
Email id
Jun 12, 2008 | Philips HTS3450 System
95 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
