I have a DGTEC T88SD set top box and it is flashing "lock" how can I unlock it?
3 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: no audio
I will try to explain this clearly.
Make sure that there is sound leaving from the connections on the top box.
Check that the audio cables are connected to the associated audio input for the video at the rear of the set. Make sure that there are no other shared inputs for the same input. With shared inputs, only one can be the default reference for input.
Check the menus in both the top box and the TV set to make sure that all setups are correctly done.
Jerry G.
Posted on Apr 14, 2008
  • 11800 Answers
SOURCE: we have dgtec dg hd9000
Look at the back of it, you will see a lot of connectors: use the Yellow (video composite) and the Red and White (audio left and right) . Connect those to the corresponding connectors on the tv and select the correct AV entry on it.
But, even with the box disconnected, you should be able to change the channel on it both with the remote and the buttons on the box. If you can't do that then something is wrong in the box, at a hardware level: the processor either can't receive the commands or it can't execute them. You will have to take the box to a repair shop.
Posted on Jan 03, 2011
Whats the universal remote code for a DGTEC DG HD8020 SET TOP BOX
0029.0022. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 10, 2014 | Televison & Video
I've got dgtec hd7710 top box, any idea how to setting a universal remote control? Please help
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Aug 14, 2014 | Televison & Video
Set up code for one for all remote on dgtec set top box
0473,0489,0413,0436,0422. Try these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 19, 2013 | One For All Televison & Video
I need to unlock my Platinum Telefunken set top box. My remote won't work at all and I put new batteries in and it's not that. The green light is on "Lock" on the actual set top box....
I have the same problem, but with no picture at all on my HD Channels. All I did was to retune my TVs analogue channels and bingo I got all my HD Channels back. My HD Set Top Box is still showing as locked.
Aug 08, 2011 | Televison & Video
Hi, I've connected a Philips 42PF9946/79 Plasma TV to a Beyonwiz DP-Lite i Digital Set Top Box. The connection is through a HDMI Cable and TV is viewed on the 'HD' channel/mode. Previous to the Beyonwiz...
@leemcdowall...
your concern points to some adjustments of resolution from your set top box, as we all know all TV'S has fixed resolution doesnt matter what brand and the only way you can change that is through your source which in this set up is your Beyonwiz, please consult their manual and see if you can change the resolution in their video set up page.
Feb 20, 2011 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
DGTEC top box,DG -HD8710, lost manual when moving
The main aerial goes into the box,then a flylead out of the box into the tv(if you have a vcr or dvd rec then it will go in there first then out into the tv).Then connect the box to the tv with a scart lead.
Nov 07, 2009 | Televison & Video
No audio
Jerry G.
Apr 13, 2008 | Televison & Video
MANUAL FOR HD SET TOP BOX
Try this link. Ijust downloaded the manual from here myself.
http://www.dgtec.com.au/arbitrage/pages/134/DG2000A+UserManual.pdf
Regards
Graham
Jan 19, 2008 | Televison & Video
Can't set up
You can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
Jan 14, 2008 | One For All URC-3445 Remote Control
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
