Question about MTX Car Audio & Video
I have a MTX 3401 thunder mono block amp.....i need a diagram of the inside or where i can get parts from for this amp
SOURCE: Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Posted on Aug 19, 2008
tech48
  • 624 Answers
SOURCE: i need to no how
I hesitate to answer this question for fear that you will not like the answer even if it is the truth. I have received a bad rating from a couple of people in the past just because the right answer was not what they wanted to hear.
This is a mono sub-woofer amp, which means that it is already bridged internally. You only have one speaker output in this amp, that means that the amp circuit is bridged inside, it is not split into two channels.
To bridge any output, it requires 2 channels, otherwise there is nothing to bridge.
I have been repairing car amplifiers for over 18 years, and I promise you that there is no way to bridge a single channel amp. Bridging means to convert 2 channels into 1 channel. If all you have is one channel, then there is nothing left to bridge.
I hope this explains it for you, if you have any other questions feel free to post them here and I will answer as soon as possible.
And please do not punish me with a bad rating if you do not like the answer, it is the correct answer, and sometimes the right answer is not always what we want to hear, but it does not make it wrong.
Dave
Posted on Nov 09, 2008
etirbynnor
  • 655 Answers
SOURCE: Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Posted on Mar 30, 2009
  • 32 Answers
SOURCE: 2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Posted on Feb 12, 2010
  • 5 Answers
SOURCE: need to wire to mono block amp
4 ohm voice coil? on the mono amp it should be from left to right ++ -- you want to go + x x -
Posted on Feb 20, 2010
I installed a MTX Thunder 3401 with a PA sub. after turning the car oh every things works great. After about 2 mins of play, the thermal light begins flashing red and it will shut off the amp. After the...
You are def overheating, If the ohms rating of the subwoofer is too low it will cause this same thermal over heat. If you have 2ohms in sub and a 4 ohms stable amp, you will overheat. Check the ohms rating of the sub to make sure this is not the problem
Jan 31, 2011 | MTX Thunder 3401 Car Audio Amplifier
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Jan 23, 2010 | MTX Thunder 81000D Car Audio Amplifier
Has mtx stop selling the mtx ta81001?
Hello t3h_b,
The MTX web site shows the amp as a current product.
http://www.hifisoundconnection.com/ sells the amp and claims to have it in stock. However, MTX lists only 2 authorized online resellers:
www.crutchfield.com and www.sonicelectronix.com
Crutchfield doesn't list the amp at all and SonicElectronix shows it as "discontinued". I'd recommend going to MTX's contact page and ask them directly. They'll usually respond within a day or two.
Hope this helps.
Oct 06, 2009 | MTX Thunder Class D Mono Amp (TA81001) Car...
Need help MTX 1501d amp diagram
Remove cover and set in direct sunny window for long time, may be no problem with it, Took a month to dry one of my amps out enough that it decided it would come back to life, cell phone dropped in sink took 2 weeks, If you try power to it too soon --fried--, good luck finding diagram and repairing it sincerely-hope its okay, good amp, bad luck,
Mar 13, 2009 | MTX Thunder 1501D Car Audio Amplifier
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
My amp went out and i cant figure out y
Kind of a vague problem description, can you be a little bit more specific. What problems you are experiencing, how many speakers/subs were you powering with it, does it show that it has power, did you check the fuses?
Jun 29, 2008 | MTX Thunder 3401 Car Audio Amplifier
My tweeters do not give sound
just run the tweeters to the front speaker channels on the radio
Mar 10, 2008 | MTX Thunder 1501D Car Audio Amplifier
Amp works fine i think??? but Prsim efx not working at all
You need to contact MTX tech support before the warranty runs out. You'll probably have to get an RA number to send it back.
http://www.mtx.com/caraudio/contactMTX.cfm
Oct 18, 2007 | MTX TA4501 Thunder 4501 MonoBlock Car...
Car Audio & Video Logo
Top MTX Car Audio & Video Experts
hoyzee1
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
