Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Rheem rr410T - my drain valve is leakin!!, I have now drained the hot water tank - what do I do now - just opened the cottage and had water everywhere after turning the water on...I am not a fix it person ( and neither is my husband) - this is the beginning of a long holiday weekend and we will have no hot water for guests arriving tomorrow; is there it easy to fix - can I do it myself - what part do I need to buy - the one I have is a plastic one.. please advise as soon as possible -
1) If leak is simple, then put garden hose cap over end of drain valve.
Pick up hose cap in garden department at home center or hardware store
http://waterheatertimer.org/images/garden-hose-thread-cap-76.jpg
2) Or install a garden hose and run to a drain until valve can be replaced.
The hot water will not last as long for showers until valve is fixed
3) If drain valve is cracked, it needs to be replaced.
If you are a DIY adventurer, then replace drain valve.
Since drain valve is plastic, expect to use every tool you can borrow when the plastic valve breaks off.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
4) Call a plumber who will prefer to replace with new heater.
5) If you want adventure, then replace heater yourself and save $400 installation. Here in Houston 2011, electric heater costs 220 and gas 330 at local box store. Offer 10% less.
Open following link for gas installation, and use basic information for replacing electric.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Good luck and Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 20, 2011
Drain hot water heater
turn off gas
turn off cold water to heater
connect hose to spickot
place hose end outside
turn on spickot
open hot water faucets in house
wait.
when water stops, turn on cold water for 30-60 sec or so to try to stir up any sentiment in tank
turn off cold water and let drain.
close spickot
turn on cold water
let fill till water start coming out hot water faucets then turn off hot water faucets.
turn on gas and relight pilot.
finish bleeding air from hot water faucets.
set water heater thermostat
Jun 14, 2014 | Rheem 43VP50E2 50 Gallon FVR Natural Gas...
Drain Valve leaking on Hot Water Tank for model #21V40-7
You can purchase a new drain valve at a hardware store to replace it. Turn power and water off to replace it after you drain it down. Replace drain and turn water back on and open faucets to get air out of lines before turning power back on.
Oct 17, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Our hot water will last for about 5- 10 minutes then turn luke warm. I have replaced both elements but problem remains . Do you hink it is the thermostat ? thanks chazz
If you have not done so already then turn thermostats up to 140 degrees. You may also try to drain and flush tank to clean out any mineral deposits that could be hurting your effiency. To do this shut off electrical power to heater then connect garden hose to drain valve on the bottom of tank. Run hose to floor drain or other safe area and open drain valve. If it drains good with the water on then let it flush for a couple of mins. then shut incoming water supply off. Let tank drain as far as it will. You may need to open a faucet on the hot side of nearby fixture to break vacumn.
Drain it completly then close drain valve and hot side of faucet.Turn water supply back on and let tank refill. Do this 2-3 times to get inside of tank as clean as possible. Hope this helps you and thanks. P.S. You may need to replace thermostat also.
Mar 28, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
Slight water leak from plastic drain fitting on rheem fury 40 gal gas water heater
You can try to crack it open and get a little piece of crud out of there, I'm sure that is all it is, Just get a tray or something to catch the water, It should stop it, If it gets worse, turn the water off to the heater, then open the valve and hope the bigger piece of crud comes out. It is about all you can do, other than drain the whole thing and take the valve apart and replace the rubber in it. Check it out, Hope this helps.
Dec 12, 2010 | Rheem Water Heaters
Empty boiler
Turn main water off to the water heater, it may be a valve on cold side coming in to shut off. Next turn power off to the heater and drain the tank the drain will be located near the bottom of the tank.
You will need a water hose to connect to the drain to run water outside. Open a faucet hot side to allow you to drain the tank.
Upon reinstall connect the tank up and fill tank and open up hot side on one faucet at a time to purge out air from system before turning power back on. Make sure you have water flowing from each faucet's hot side before turning power back on.
Jul 02, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Pop off valve dripping Rheem 50 gal electric valve at bottom
If you are reffering to the drain valve at the bottom of the hot water tank. It may be leaking due to the O ring being cracked or worn out. You can either drain the tank and replace the valve or you can buy a hosebib brass cap and thread it on the existing valve. There is no cause for alarm when doing this as this valve is just to drain the tank when replacing your hot water heater
Feb 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How to drain the rheem 135 litre tank
1. turn off the electrical power first.
2. attach a garden hose to the hose bib attachement on the bottom of the water tank and run the hose outside to allow the water to drain out by gravity.
3. Turn the valve that is on the inlet of the water heater. Now that the power is off, you can drain the tank.
4. open the drain valve where the hose has been attached.
5. To release the pressure, you can open a hot water faucet in your kitchen. This will allow the water to drain out easier.
Sep 12, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches.     Normally the drain valves are plastic with a Male hosebib attached.  Attach a  garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve.  If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level.     Replace the P/T valve  and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads.    You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Jan 31, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
277 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
