Question about Garden
Coleman model 550 by maax spas....pump on my hot tub went out and r and r pump and it worked fine...pump (bigffot 56 dual speed 220v) connected to heater started making same noises and went out... replaced that motor and filled tub... turned on and heat light on display (power works 516 on panel cover) comes on but pump does not. hear a clicking noise in the panel when i push the pump button.... left on for a few minutes and pump 2 came on... but heater side pump does not....any ideas ...Thanks Scott Androes pueblo colorado.
MrBob84
  • 90 Answers
SOURCE: pioneer 710 hd power/not turning on 10/12/08
When the set goes into protection BANG like that, without any intermittencies, usually the convergence ICs have gone out and need replacing. I recommend using the STK 392-180s, which are the stronger upgrade to the 392-110s used originally. You'll need 2.
Mr Bob
www.imageperfection.com
510-278-4247
bob at imageperfection dot com
Posted on Nov 12, 2008
  • 82 Answers
SOURCE: Blower motor or resistor?
If it was the motor that went out then it would not blow at all. The resistor is the culprit that starts killing off speeds. It should be about $25 to $30 at an aftermarket store like autozone or advanced auto parts.
Posted on Jan 09, 2009
  • 112 Answers
SOURCE: garden tractor, starter motor does not crank
Your starter may need to be rebuilt or replaced.
Posted on Apr 04, 2009
e-Guru
  • 3917 Answers
Yes its the blower motor resistor.
More then likley theres some trash or something in it, or possibly the motor itself is on it's way out. There not that bad to pull out of that body car, just pull it out and see what you can see.
The blower motor is under the glove compartment
You can replace the resistor on your own. Please find a detailed diagram which would guide you to do it.
http://autorepair.about.com/library/images/bl629a-lib.htm
Thanks
Posted on Apr 09, 2009
  • 153 Answers
SOURCE: mower will not start will make clicking noise. did start at for one minute
Your battery is dead. Replace it.
In the winter keep a smart trickle charger on the battery to prevent it from discharging. Lead/acid batteries lose 1% of their charge per day and are basically junk in 3 months. They have to be kept charged.
Posted on May 05, 2009
Water sensor needs to be replaced. 8 yr old unit. Maax doesn't carry old parts unavailable HELP PLEASE!
Parts for Maax Spas‎
www.spaguts.com/
(714) 764-0014
Pumps, packs, heaters, controls,
ozonators for Maax hot tubs.
# 27 Hot Tub Heater Replacement for 240 volt hot tubs ...
? 6:27
https://www.youtube.com/watch?v=xNWjM8c_b-8
Oct 10, 2011 - Uploaded by softcellelectrical
27 How to replace an in line or flow through heater for an above ground ... I just changed out the water in my spa when I discovered the heater element ... Is there a hose that should fit on it? ... I figure it will run similar to a whirlpool setup. ... tests on the unit...but, it sounds like 1. your sensors may be DC and
Jan 18, 2016 | Maax Home
How do you reset an imperial hot tub flo control panel? this one is 10 yrs old.
shut it off entirely .. unplug..reconnect and power it back up reset all settings..
Nov 21, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
QCA Dream Series, Mystic SPA. Drained, cleaned and re-filled. Following power restore (and 5 min or so prime cycle), the the pump runs continuously at low speed - it NEVER stops. Everything else works fine...
After refiling a spa, typicall the water is below 50 degrees F. Spas have a freeze protection in their programming so that when the water is that cold, the pumps run constantly to keep it from freezing. It will correct itself
Aug 09, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Leaking #1 pump on Arctic Spas Cub hot tub.
I found out that the pump impeller can be unscrewed from the motor shaft by turning the impeller while keeping the shaft from rotating. There is a brass shaft coupling embedded in the back side of the impeller. This allowed me to remove the leaking seal assembly inside the pump by tapping it out gently. However, instead of just replacing the seal, I decided to replace the entire pump with a newer version. Cost was only about $25 more than replacing the seal and gaskets. The pump-motor assembly has been reinstalled in the spa and there are no more leaks.
Dec 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Coleman Hot Tub Model 411
This spa was manufactured by Maax. Try Maaxspas.com for your owners manual.
Nov 23, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Just looked at 2000 coast spa hot tub with 1 6.5hp motor,is this enough power to support the 30 jets as opposed to another hot tub that has 2 7hp motors with 40 jets
a 6.5hp motor produces quite a bit of force. It should be able to support 30 jets just fine. Most spas range from 2hp to 7hp. Depending on your preferences, the 6.5 should be plenty but if you really want a powerful therapy jet, two 7hp pumps should be more than sufficient. They will also kick your electric meter up a few notches...
Two pumps give you more options, you don't have to have half of the jets turned off so one area can have more power, the dual pumps give you the option to run nearly all of the jets at the same time if you have more than just a couple people in the spa a once.
Nov 09, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
