Question about Car Audio & Video
Bought a replacement key had it calibrated twice but still car is immobilised
  • 22,156 Answers
Try taking it to the dealer as they have the correct software
Posted on May 20, 2011
Tip
I removed the battery and now the car won't start
'I disconnected the car battery/changed the car battery and now my car won't start'
Another common question on Fixya.
You've done nothing wrong. It's simply that the immobiliser doesn't recognise the key.
Put the key into the ignition. Turn the ignition on. Press the LOCK button twice on your remote. Wait 1 minute.
Turn the ignition off and press the UNLOCK button on the remote a couple of times. This will disarm the immobiliser.
The key should be recognised and your vehicle will start.
on Feb 19, 2016 | Cars & Trucks
My car wont start lost my key so got an ignition barrel and key out of a different car wat do i need to do? plz if anyone can help plz
Your car is probably fitted with an immobiliser , you need to have the original key in the car when you start it or replace the immobiliser module and key with a programmed chip to match that immobiliser , otherwise go to the dealer with VIN number and they will replace the key (not cheap usually) the trick is the immobiliser chip in the key must match the one in the car , it's a security feature .
Jul 08, 2014 | 2002 Hyundai Accent
I have a 1998 VW LT35 minibus which i have just bought to convert into a camper, which up to this point has been running fine, i have recently replaced the dashboard and under the steering column i found a...
Unfortunately the ignition barrel has been replaced with a new key,which has not been adapted to the immobiliser.The three core wire is from the reader coil which is supposed to fit around the ignition barrel.Obviously the key head was taped in the right position for the reader coil to read the key chip.Now the immobiliser is doing its job and cutting the ECU to stop it from running.It will take persiverance to find the right position to tape key back to coil for engine to run.Then your local VW Commercial dealership can readapt your key.
Sep 20, 2010 | 2005 Volkswagen Microbus
Hazard lights flashing and remote fobs not working only manual key open and locking doors Audi 2003 a4 sport 19tdi
replace batteries in remotes,then with key unlock car/hold key over windows go down,wait 20 secs,then lock/hold key over,windows go up,wait 20secs, then using remote press/hold down the unlock button for 30 secs.you have just reset the alarm/immobiliser.if remotes/keys dont work after this,then take it to a dealer for a computer/key reset.
Aug 25, 2010 | 2003 Audi A4 Cabriolet
Does not start.on ignition the immobiliser light on panel flashes
most common cause is your key fob is broken.
check this by 1st gettin a camra phone goin onto the camra point key at camra and press button if you see a red light flash it is workin if not it is faulty which means a replacment key hope this helps
Sep 26, 2009 | Renault R5 Cars & Trucks
Flat battery caused immobiliser problems
1-insert and remove key from ignition two times
2-close and open driver door two times
3-insert and remove key once from ign.
4-close and open drvr door twice
5-insert key into ign.,then close driver door
6-turn key to on (not start) then off, twice this is rewrite mode,have all remotes to reprogram it will clear any lost remotes.
7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
8-press lock/unlock together and hold for a second
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possession,you are done. To end mode open door or insert key into ignition.
You'll need to follow the steps with no more than a 1-2 second delay between each step.. hope it works
Aug 10, 2009 | Renault Sport Cars & Trucks
Renualt megane (Auto) 2001 model wont start
Have you tried cleaning or replacing the flywheel rotation sensor ????
Jun 10, 2009 | 2003 Renault 181
Cobra 8510 immobiliser fitted to my ford excort rs turbo
Wheelsnboots
When you say the Immobiliser is broken... Do you mean the touch key?
The 8510 touch key is prone to the internal contacts failing. If you open the case up and reconnect it then you should be able to disarm the immobiliser
You should have two touch keys so try your spare on first.
Be warned... You will need 1 working touch key to program a spare or the system will lock out and will need replacing
Hope this helps!
As for Sutty
Sounds like the system has lost power if the LED is not flashing. Have you made sure cars the battery is not flat?
May 05, 2008 | Car Audio & Video
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
