Question about ViewSonic VE510b (Black) 15" LCD Monitor
Can I clean my ViewSonic LCD Monitor (VE510b) with water (using cloth)? Please tell me easy procedure of cleaning my ViewSonic LCD Monitor screen. email: amdesh1@gmail.com
    Genius:
  • 1,127 Answers
Hi
Time Required:
Cleaning a flat screen (LCD) monitor usually takes less than 5 minutes Here's How:
  1. Turn off the monitor. If the screen is dark, it will be easier to see the areas that are dirty or oily.
  2. Use a dry, soft cloth and very gently wipe the screen. A great choice would be the microfiber type of cloth used to clean eyeglasses.
    See Tip #1 below for kinds of cloths to avoid.
  3. If the dry cloth did not completely remove the dirt or oil, do not press harder in an attempt to scrub it off.
    Pushing directly on the LCD screen can often cause pixels to burn out.
  4. If necessary, dampen the cloth with distilled water or with an equal ratio of distilled water to white vinegar.
    Many companies also sell small spray bottles of special cleaner for flat screen monitors but the vinegar mixture is usually just as effective.
    See Tip #2 below for products to avoid.
  5. The plastic edge that surrounds the screen can be cleaned with any multipurpose cleaner but take care to avoid contact with the screen itself.
Tips:
  1. Avoid using paper towels, toilet paper, tissue paper, or something like your shirt to wipe the LCD screen. These non-ultrasoft materials can scratch the screen.
  2. Avoid cleaning products that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the materials that the LCD screen is made of which could yellow the screen or cause other kinds of damage.
  3. Never spray liquid directly on the LCD screen or it could run inside the monitor and cause damage.
Posted on May 20, 2011
How to clean a monitor screen?
The best way to clean lcd monitors and touchscreen devices is with a microfiber cloth and a solution of 50% water and 50% white vinegar. This is basically what they sell in stores for about 1000 times the price that you can make it for.
Jan 08, 2012 | ViewSonic E2 VA2012w-2 20 inch LCD...
How do I clean the monitor? my cat has put nose prints all over it, and when I attempt to wipe it off (turned off, of course) I still cannot get it clean.
The best way to clean an LCD monitor is to take a lint free cloth and spray it with Windex or vinegar and water solution, or in a severe case, summer windshield washer fluid (the kind meant to remove insect guts). Make sure the cloth is DAMP, not WET (we don't want anything dripping out of it) and wipe the screen thoroughly.
Dry with another lint free cloth while the screen is still damp.
Jul 17, 2011 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Can I clean my ViewSonic LCD Monitor (VE510b) with water (using cloth)? Please tell me a procedure how can I clean my ViewSonic LCD Monitor screen.
To clean the monitor first turn it off then use something like a microfiber cloth or something that is not abrasive to clean the surface. Don't press down excessively this can cause damage to the monitor. If that does'nt get all the fingerprints and such off a solution of distilled water with a little
white vinegar will do fine just use it lightly and don't drown the monitor. Make sure to use just enough solution to lightly dampen the monitor and not so much as to run down the monitor and
risk getting inside where the circuits are.
May 20, 2011 | ViewSonic VE510b (Black) 15" LCD Monitor
What do i clean the screen with?
Cleaning is simple. Vacuum the rear vents to remove any dust that has built up.
For screen and the fascia, -
1. Unplug the monitor from the power supply.
2. Fill a bowl with warm water with some washing up liquid - just as you would to clean dirty dishes. Soak a soft clean cloth in the water (Kitchen cloth - NONE ABRASIVE!! and not a sponge!), and wring the cloth out so that it is damp (not wet!) and gently wash the screen. When finished use kitchen roll to dry off the monitor.
3. Stubborn marks on the LCD, using the same damp cloth, apply a spot of neat washing up liquid to the cloth. Clean as before - DO NOT PRESS on screen. When finished, use kitchen roll as before.
Voila!
May 14, 2010 | Acer 22" X223w LCD Monitor
Best way to clean screen
Difficulty: Easy
Time Required: Cleaning a flat screen (LCD) monitor usually takes less than 5 minutes Here's How:
  2. Use a dry, soft cloth and very gently wipe the screen. A great choice would be the microfiber type of cloth used to clean eyeglasses. See Tip #1 below for kinds of cloths to avoid.
  3. If the dry cloth did not completely remove the dirt or oil, do not press harder in an attempt to scrub it off. Pushing directly on the LCD screen can often cause pixels to burn out.
    1. If necessary, dampen the cloth with distilled water or with an equal ratio of distilled water to white vinegar. See Tip #2 below for products to avoid.
    2. The plastic edge that surrounds the screen can be cleaned with any multipurpose cleaner but take care to avoid contact with the screen itself.
    Tips:
    1. Avoid using paper towels, toilet paper, tissue paper, or something like your shirt to wipe the LCD screen. These non-ultrasoft materials can easily scratch the screen.
Oct 28, 2009 | Computers & Internet
Cleaning lcd monitor screen
use any soft clothe with liitle bit wet and wipe on screen.and leave it for 10 minutes .
Sep 08, 2009 | Computers & Internet
LCD screen...unsure
Warm water on a lint free cloth and don't rub too hard. Not too much water either ....just needs to be damp ...
Dec 31, 2008 | BenQ FP71G 17" LCD Monitor
Cleaning
Buy an cleaning kit with cleaning solution, and clean the display very carefully. If you apply too muck pressure you can damage the LCD display.
See also:
How to Properly Clean your LCD Screen
How to Clean an LCD Screen
How To Clean A Flat Screen Monitor
Dec 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Stains on the LCD monitor of Permanent marker
you could try mean green or totally awesome gotta love dollar tree. but be careful if you press too hard you could crack the screen or cause a pooling effect that may or may not go away. Oh or rubbing alc. last resort use liquid lighter fluid on a cloth.
May 22, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Cleaning monitor
I dont know which type you have but here is how to clean either:
CRTs
Those big chunky CRT monitors have glass screen which are easily cleaned. The important thing to remember is that you don’t ever want to spray any liquid directly on the screen. Instead, spray the cloth with water or a mild window cleaning solution then wipe the screen. You can use the same damp cloth to clean the entire monitor case, as well. If you prefer, you can also use moistened paper towels to clean CRT monitors, You will be only cleaning the outside of the monitor case and screen. Never open the monitor casing which contain electric voltage that can cause a shock.
Flat Panel LCDs
LCD monitors are often called flat panel monitors because they are flat and thin. These are the types of screens that are used in most laptop computers, and they are also becoming very popular for desktop computers. LCD screens are softer than CRT glass screens, so they require some extra tender loving care. Keep your fingers and sharp objects away from these screens since they are susceptible to damage and scratches.
Use a soft dry cotton cloth to remove fingerprints and smudges from the screen. If this does not completely remove the dirt and splotches, use a small amount of isopropyl alcohol on the cleaning cloth that has been dampened with water. (A small amount of vinegar can be substituted for the isopropyl alcohol.) Again, spray the liquid on the cloth and never directly onto the screen. Do not use paper towels on an LCD screen as they can scratch the screen. Never use ammonia, ammonia-based cleaners, or strong cleaners which can cause the surface to yellow and become brittle.
It is good to have a special clean cloth that is dedicated to use on the LCD screen. Don’t pick up any old rag, as dirt particles in the rag can scratch the surface of the screen. Special LCD cleaning cloths are available and can be an excellent investment.
Jan 04, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
ViewSonic VE510b (Black) 15" LCD Monitor Logo
170 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
