Question about Garden
It idles OK, but when you try and rev it, it does not rev plus it sounds very lumpy and rough, almost like it is getting too much fuel. Any ideas?
  • Anonymous May 20, 2011
    It,s a Husqvarna 325R trimmer ( brush cutter)
    Problem Solver:
  • 13 Answers
What type of equiptment is this?
Posted on May 20, 2011
  • c_dizz13 May 21, 2011
    I would start at the carburetor and exhaust screen, I am not 100% that husvarna uses exhaust screens but if they do it will be in the muffler of the trimmer, If this is clogged it is definitely an issue if not your only issue, second I would diagnose the carburetor, remove the carburetor and give me a description of what you find, it should be fresh fuel and fresh fuel only, is the any debris, are all the internal components sealed correctly, any dirt, etc
Engine will idle but will not accelerate
Fuel pump faulty, clogged fuel filter. Check for those.
Dec 04, 2013 | Volkswagen Cars & Trucks
Ok got a 96 s10 2.2 when it first starts up it has a rough idle then it clears up, then whenu rev it up it does fine but when the rpms drop down it starts a rough idle and it wont rev up near as smoot
had same problem in 97 dodge truck turned out it was vaccum leak hard to find sprayed either around vaccum lines when idle went up found tiny hole in line
Sep 22, 2012 | Chevrolet Vehicle Parts & Accessories
Roaring engine when started
Sounds like your car is over fueling. My first quick look is to make sure your throttle return spring is intact and still connected. Next remove the air ducting between air cleaner box and throttle body so that you can see that the throttle plate is fully closed at start up. If OK then reinstate the temporarily removed ducting. Next I would check your fuel pressure relief (FPR) valve on the fuel line. When the engine is running remove the vacuum line attached to it and check for fuel dribbling from it or a strong smell of fuel. If the FPR is normal and healthy the engine would normally increase in revs for few seconds and then begin to idle roughly. Put your finger over the end of the disconnected vacuum line (if healthy the engine would resume normal idle after aout 5 seconds) and watch the side arm of the FPR for about two minutes. If fuel eventually spits out then change the FPR. Sometimes the diaphragm within the FPR which is acted on by engine inlet vacuum can split and the fuel behind it is sucked into the inlet plenum making the engine rev and idle roughly.
Feb 23, 2012 | Chevrolet Cavalier Cars & Trucks
My 96 olds does not like to start when it gets hot. seems to start ok when it cools down. Any ideas? It doesnt start real easy when its cold. have to rev a let idle a little before moving. idles pretty...
Hello, I have 1996 Ciera with rebuilt engine pretty new, also fuel filter and fuel pump replaced but I have a problem, the car starts and runs well cold but once car has been running for a few hours, either stopping or coming to a stop it starts to idle roughly and has come to a stop at different occasions. Check engine light does come on and off occasionally. Can you help?
Nov 05, 2010 | 1996 Oldsmobile Cutlass Ciera
ERRATIC & LUMPY RUNNING? AND LACK OF POWER
I suspect that you have air leak from air induction system. try to chek the breather hose. there are two hoses behind the intake manifold one is connected to valve cover to PCV , check the hose condition and replace it if necessary.
Jan 25, 2010 | 1999 BMW 318 ti
Rough idle, car has no ICV, idle control valve, so what now?
It will deffinitely have a form of idle control, sometimes it is part of the throttle body but there will be one... 100% certain.
Rough idle as in lumpy will not be an ICV related fault, as with ICV it will either have solid high revs or none at all.
It will either be an inlet vacuum issue - split hose, gasket, MAFS etc or an irratic voltage caused by things like a Lambda or worn throttle potentiometre
Describe the rough idle in more detail if you can, also are you UK or USA etc.
Do you know what cc and engine code your car is?
Dec 15, 2009 | 1998 BMW 3 Series
1995 volvo glt 850 model year, 4.2 literes
Hi!
You meant a 2.4 litre engine, right?
Check:
- Fault codes from the diagnostics system.
- Fuel pump relay, located under the fuse box cover under the hood. If it's a green one labeled 103 it might be the culprit and should be replaced with the new and improved red one.
- The fuel pump itself, measure voltage to the fuel pump and make sure it's getting sufficient power. Can you hear the pump working when turning on ignition?
- Fuel filter might be clogged up. Located under car, by the right rear wheel.
- Unaccounted air entering through vacuum hoses. Spray them with start gas while the engine is idleing, if engine revs up you've found a leak.
- Throttle body might be in need of cleaning, probably a good idea anyway as it usually gives the engine a tad better performance.
- Mass airflow sensor might need replacement or cleaning of connector.
- If idle is rough check idle control valve.
- Make sure all plugs are firing, engine might be missing one cylinder, causing it to vibrate depending on engine RPM.
- Check that coil is ok.
Your problem doesn't sound like a camshaft/crankshaft position sensor, but you never know. Have the codes read, that'll probably help alot!
Well, that should give you some idea as to where to start checking...
Good luck mate!
Jun 05, 2009 | 1995 Volvo 850
Fzr6 running lumpy
il try n help m8,, can i start by eliminating a few things,, have u made sure all 4 carb floats are the same height ,they need to be, ,and there is no holes in the diaphrams at the top of the carbs,,even a pin hole will give u grief,, ,,wot happens wen u pull the choke out wen motor is warm and idling,, if it evens out and pipes warm up then theres a blockage in 3 and 4 carb,and idel jets,or could have a split vacume pipe, or a air leak between the carb and cylinder,,if all fuel symtoms are ok ,, then make sure the coil wires are on properly, and good spark on the coolest cylinders, , try swapping over the coils to to see if the left cylinder becomes cooler than the right,,hope that gives an idea,,
Jan 09, 2009 | 1995 Yamaha FZR 600
95 Maxima SE Cuts out on idle and in mid drive
SOUNDS LIKE THE FUEL INJECTORS ARE BAD WHICH UNFORTUNATELY ARE EXPENSIVE. YOU COULD POSSIBLY GET SOME USED INJECTORS FROM A JUNK YARD FOR CHEAPER.
Oct 17, 2008 | 1995 Nissan Maxima
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
