Question about Cell Phones
Battery back up problem and while charging becoms hot ,how can i avoid this
Can u specify your phone model
Posted on May 20, 2011
My concord 2 android phone gets hot when i charg it why is that
You know it will get hot only if the phone is charged long hours like 3 hrs or 5 hours but if the phone gets hot in a short time then something is wrong with your unit. Discontinue charging to avoid fire and bring it back to where you bought it and complain.
Jul 02, 2014 | Cell Phones
Motorola Fire XT (XT530) charging problem .
Motorola FIRE XT Tips for extending battery life
Back to Previous Page
Are there any tips on how to extend the battery life?
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tips:
  • It may take several charging cycles for your battery to reach optimum performance.
  • The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
  • You can charge your phone via USB cable but this charging time will vary based on computer specifications.
Tips to extend battery life:
  • Select a shorter backlight duration
  • Lower the display brightness
  • Use the AC adapter to charge your phone whenever possible
  • Turn Bluetooth off when not in use
  • Turn Wi-Fi off when not in use
  • Close any third party applications running in the background
  • Playing music, videos and viewing images in your phone will affect your battery life
General Battery use & safety
  • Motorola recommends you always use Motorola-branded batteries and chargers. The warranty does not cover damage caused by non-Motorola batteries and/or chargers.
    Caution: Use of an unqualified battery or charger may present a risk of fire, explosion, leakage, or other hazard. Improper battery use, or use of a damaged battery, may result in a fire, explosion, or other hazard.
  • Your battery can be charged without it being fully depleted, and can be charged every day if desired.
  • Battery usage by children should be supervised.
  • Important: Motorola mobile devices are designed to work best with qualified batteries. If you see a message on your display such as Invalid Battery, Invalid Charger or Unable to Charge, take the following steps:
    • Remove the battery and inspect it to confirm that it bears a Motorola "Original Equipment" hologram;
    • If there is no hologram, the battery is not a qualified battery
    • If there is a hologram, replace the battery and retry charging it
    • If the message remains, contact a Motorola Authorized Service Center
  • New batteries or batteries stored for a long time may take more time to charge.
  • Charging precautions: When charging your battery, keep it near room temperature. Never expose batteries to temperatures below 0°C (32°F) or above 45°C (113°F) when charging. Always take your mobile device with you when you leave your vehicle
  • When storing your battery, keep it in a cool, dry place.
  • It is normal over time for battery life to decrease, and for the battery to exhibit shorter runtime between charges or require more frequent or longer charging times. Motorola batteries are designed to last between 350-700 charge/discharge cycles at room temperature. This amounts to approximately a year to a year and a half of battery use for most people.
  • Avoid damage to battery and mobile device. Do not disassemble, open, crush, bend, deform, puncture, shred, or submerge the battery or mobile device. Avoid dropping the battery or mobile device, especially on a hard surface. If your battery or mobile device has been subjected to such damage, take it to a local service center before using. Do not attempt to dry it with an appliance or heat source, such as a hair dryer or microwave oven.
  • Use care when handling a charged battery-particularly when placing it inside a pocket, purse, or other container with metal objects. Contact with metal objects (such as jewelry, keys, beaded chains) could complete an electrical circuit (short circuit), causing the battery to become very hot, which could cause damage or injury.
Apr 17, 2014 | Motorola Mobility XT530 Fire XT Black...
I have a 2008 BMW 528I (my first BMW). It is sits for several months at a time (second home) between driving. Do they make a
Buy a battery tender maintenance battery charger to keep the battery fully charged and extend the life of the battery. Google "Battery Tender"
Aug 23, 2012 | 2008 BMW 528i Sedan
WHATS HAPPEN MY TOSHIBA SATELLITE A300-14S LAPTOP BATTERY NOT CHARGING THEN WHEN I REMOVE BATTERY PLUG DIRECT DC IF HOT AUTOMATIC SHUT DOWN
the laptop cannot ventilate the hot air out.may be a lot of dust covered the cpu fan.go to any service centre and get it cleaned.if you can do it yourself then its fine.it is becoming too hot and is shutting down.
Apr 05, 2012 | Toshiba Computers & Internet
I am getting A message which says "pause by temperature when the phone should be charging. What does this mean the phone is new.
It's normal with many phones. It's just stating that the phone is taking a brief rest during charging to avoid overheating. It's usually a hot battery rather than a hot phone, and it's most common in warm climates, or on hot days or if the battery is undergoing it's first full recharge.
May 20, 2010 | O2 Samsung SGH-E250 Cellular Phone
No battery backup
then dont charge the battery too long and charge for daily one hour. and the battery may be damaged that so you get the heat problem
Sep 21, 2009 | Nokia E51 Cellular Phone
My laptop wont charge when you plug the charger in it stil heats up but the light indicating that it is charging does not light up and it does not charge
What is getting hotter your power supply adapter or your battery, avoid very hot things - get it replaced with new one.
Caution - If your battery is getting hot there is a chance of explosion. dont keep it connected long time it can damage your computer motherboard
Thanks Hothawk
Jul 24, 2008 | Computers & Internet
Charging cable gets hot, charge port too, not battery though
No it is not a problem. The power dissapiation in the adaptor causes it to become hot.
Jul 16, 2008 | HP Pavilion dv1000 Notebook
Battery charger just flashes to say the battery has to cool down but will not start charging.tried another charger same thing happens but does not show that the batteries are faulty!
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 6 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. But Makita should definitely have a few words with their supplier before they become a liability!
Jul 03, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
