Question about Corinex AV200 Powerline Ethernet Wall Mount - Dual Pack (CXPAV200WME2) Network Adapter
Changed a setting on my cableLAN adapter, and now I can't log back into the menu, any help would be great. Thanks.
I cant find my beacon interval
Select Wireless under the Configuration tab, then select Advanced from the side menu the beacon setting should be the 3rd setting listed.
The default beacon setting should be good for any setup it might help to know why you want it changed.
Jan 30, 2013 | NetGear N600 Wireless Dual Band Router
Wireless connection issue w/ ZyXEL PK5001Z DSL Modem/Router
Try switching your WiFi Channel to 11. In your web browser (while attached to the internet through the ethernet cable), type in 192.168.0.1, log in using info on back of modem, or use your custom admin password if you changed it. Select Wireless Setup. On the left hand column select Radio Setup. In the drop-down menu, select channel 11 instead of auto detect. Apply changes to save the setting. Hope this helps.
Aug 18, 2012 | Apple Computers & Internet
LGP350 Wireless connection issues
Log onto your router. Then find the wep code or wireless security code.
Enter the code into the lpg350 wireless setup menu.The code is either 16 or 25 letters or numbers long.
Dec 21, 2011 | Video Game Consoles & Games
Wireless Connections keeps dropping and won't reconnect. The Adapter can see the network it simply won't connect.
Without knowing what wireless device/adapter is trying to connect and lacking the information regarding the router you're using, the following is the best I can do with the information you've provided. If this does not work, please repost your question the same as you have, but include the info for the adapter, PC, operating system, and router (or as much of this as you can track down).
If your adapter can see the network but will not connect, it is usually due to a wireless network key (wifi password) issue. Change your wireless router's network key encryption to something different. WEP is less secure than other encryption methods, however, it tends to be compatible with more adapters than any other method. If you're uncomfortable with using WEP (you may have no choice, but you'll have to mess around with it to see), then you could use standard WPA instead of WPA2.
While you're at it, please change the SSID(network name) to something else. You can even do something as simple as adding "1" to the end of it. The reason for this is because your wireless device will retain previous network security information for the original SSID and this will be easier than clearing all wireless network settings from each of your wireless devices.
Now that you have changed the wifi security settings in your router, you are now ready to try to connect to your "new" network. It's new because you changed the SSID. Search for networks and connect. It SHOULD ask you for the network key (or network password). If it does, PLEASE enter it exactly. Capitalization matters!
If this does not work, repeat the process. This time, choose another encryption method. Every other step should be exactly the same.
Again, if none of this works, re-post your question with as many details as possible (above) and I'll keep a look-out for your question. If this is helpful, please help me by leaving a great rating for this answer to your question. Thanks for using Fixya!
Sep 24, 2011 | Samsung Computers & Internet
I have a Dell latitude e4310 laptop my 10 year old has somehow changed the password and locked my computer. Can you please help
If you haven't set a password for the Administrator account you could try to log in as an Administrator then change your password back. First you need to change how users log on.
1. Click Start
2. Click Settings
3. Click Control Panel
4. Click User Accounts
5. Click Change the way users log on or off
6. Deselect Use the Welcome screen
7. Click Apply options
Exit Control Panel. Then Restart computer, hold F8 when rebooting and choose SafeMode when prompted.
When Log on Prompt appears type in Administrator as user and leave password blank ( this is the Windows default password)
This will let you boot into Windows where you can go back to Control Panel, User Accounts and change your account password.
Then just reboot normally and enter new password.
Hope this helps. Thanks for using FixYa.
Sep 17, 2011 | Computers & Internet
My Lexmark X4650's wifi light is off. I have tried to reset the wireless settings but when I try it says "network connection in progress" and goes back to the set up menu. How do i resolve this? Thanks.
Great job on trying to reset the printer's wireless network adapter. Somehow, the printer's memory is stuck to thinking to connect to a wireless network when it's not communicating at all. Unplug the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging back the power adapter in the printer. That should refresh itself. If wifi light won't turn on orange after the printer's on ready, reset the wireless network adapter again. Thanks.
Jul 24, 2010 | Lexmark X4650 InkJet Printer
Corinex AV200 Powerline Ethernet Wall Mount - Dual Pack (CXPAV200WME2) Network Adapter Logo
24 people viewed this question
Top Corinex Computers & Internet Experts
David Payne
David Payne
Are you a Corinex Computer and Internet Expert? Answer questions, earn points and help others
