Question about Pyle Dryver PLAD213 Car Audio Amplifier
I have a plad213 what load impendance am i running it i hook up 2 4ohm speakers in series bridged on that amp and how many watts RMS am i getting per speaker
    Novelist:
    Scholar:
  • 85 Answers
2 4 ohm speakers wired in series is 8 ohms and then is dropped back down to 4 ohms when you bridge it.
2 4 ohm speakers wired in parallel is 2 ohms then dropped down to 1 ohm when bridged
(most amplifiers will not handle loads below 2 ohms)
hope this info helps
Posted on May 20, 2011
I have 3 L7 kicker 15" subs will my audio pipe 1500 watt run them
Well the L7 15'' solo-baric subs are rated at 1000 watts RMS, so that would be 3000 watts of RMS amplifier power you would need to supply to adequately power all of them. I also suggest that an amp capable of producing more power than what is needed is usually better in order to prevent the amplifier from running at maximum capacity for long periods. In short your amplifier will power those subs, however you will only be able to supply 1500 RMS watts to the three subs so you will only be pushing the subs to 50% of their rated capacity while using 100% of amp capacity which will make your amp run "hot" and your subs run "weak", but if you're in a pinch it will work. Your best bet in this situation is to wire the setup so that the subs and amp are operating at minimum ohm stable impendence (usually 2 ohm). Seeing that you have 3 subs begging for 3,000 watts of power and you are only going to give it half of what it wants, I would suggest upgrading the amp or at least buying another one so that you can bridge the wattage and redistribute to all three subs with the correct impendence.
Aug 31, 2015 | Kicker Car Audio & Video
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Aug 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
How i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
Nov 17, 2009 | JBL GTO 301.1II Subwoofer Mono Amp - 200W...
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Sep 08, 2009 | Eclipse EA3422 Car Audio Amplifier
2 ohm speakers wont work on a lanzar max pro 4000 watt
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
I found this amp and I can't seem to figure out what the wattage is?
You are probably aware on how to use these output figures, but I'll write a quick explanation on the specifications for future readers anyways :)
The concpet CC-452 amplifier has the following power output specifications:
Calculated at 14.5 volts DC;
At 4 ohms per channel - 45 watts x 2 (RMS)
At 2 ohms per channel - 70 watts x 2 (RMS)
At 4 ohms bridged - 150 watts x 1 (RMS)
This means that your amplifier would provide 45 watts of power each for your front speakers, which are normally a 4 ohm load per side (45 watts for left, 45 watts for right), that's unless they are one of those exotic higher end brands (eg: Boston Z6s which are 3 ohms). Rarely, you will find speakers that are rated at 2 ohms per side, but in this instance the amplifier will provide 70 watts of power into each speaker. On your speaker specifications, you will find a value termed "nominal impedance" which will give you the ohm rating of the speakers being used..
On the other hand, if you "bridge" both channels into a single channel (using a diagram often marked on the speaker terminals of the amp), you could then provide 150 watts into a subwoofer (providing it was a 4 ohm woofer).
It's not recommended to use this amp bridged under 4 ohms..
Some subwoofers may be lower than 4 ohms, and you will not be able to use this amplifier for these types of speakers without risking amplifier failure. Also, some subwoofers may have 2 seperate voice coils, and you will have to use both channels of the amplifier seperately (not bridged) in order to correctly connect this type of speaker for use.
Oct 28, 2008 | Concept CC-452 Car Audio Amplifier
Pyle Dryver PLAD213 Car Audio Amplifier Logo
111 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
