Question about Refrigerators
The handle on the refrigerator section has become progressively loose at both the upper and lower connections to the door. It looks like there are flip out sections in the plastic to access hardware for tightening/resecurement, but I don't want to risk breaking the handle by forcing those sections open incorrectly.
    Sergeant:
    Champion:
  • 257 Answers
There pretty easy to flip out you just have to use something very thin as to not damage the looks. I usually use a razor blade but be careful.
Posted on May 20, 2011
How does someone tighten the handle it is very loose
go to www.youtube.com
refrigerator door handles out loose
see if anyone has idea on how to fix it
most of the time is the way people word there questions or answers to get the right help
manufactures name, make or model #, handle are loose
how to fix
www.howto.com/manufactures_name/model#/service_manual
/ door_handle_diagrams
www.wikipedia.org/manuf./model#/doorhandlediagram
Mar 25, 2015 | Refrigerators
A loose door handle on frigidaire refigerator
There are usually some hex head screws on the upper and lower sides of the handles make sure they are tight.
Nov 29, 2014 | Electrolux Genuine Frigidaire Refrigerator...
Jdb2100aws dishwasher - door handle fasteners loose, handle ready to drop off. This is a dissambly question: The middle section of the door has an upper one-third (which contains the input switch strip)...
after removing the stainless cover l tried to disassemble the door further but found it difficult, there is a hard thick plastic cover, i took my dremel and cut a small hole large enough for a wrench to fit and tighten the thin nut on the handle, line up the hole with where the nut would be on the other side, its a pretty quick and easy fix, l dont understand why they didnt have the openings there throughthe plastic to do the tightening since it is the stainless steel that keeps the water where it should be.
Jan 09, 2011 | Jenn-Air 24 in. JDB2100AWS Built-in...
The powerhead on our kenmore progressive canister vac (model 116.25615506) turns on and off as the yolk handle is raised and lowered. what is the most likely cause and is it repairable? thanks,
Wires (pins) are burned in the handle connection, usually the top section by the switch, unhook from the metal wand and inspect the connection, look for black sooty looking pin holes or pins, check both sides. This means the pins have burned slightly and now have a loose connection with little or no continuity. Very common, you will need to repair with a wire Kit or have a professional do it. Horrible design flaw been going on for years with these types of vacuums.....ACE
Dec 15, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
How do i remove exterior handel from door?
put ur head inbetween handles really close and open door fast , lol just playin no but look on inside upper and lower of handles might be easier if open door and u will notice an upper and lower allen wrench set screw inside just have to find the right allen wrench that fits that and just loosen each one enough until handl comes off... hope this helps let me know
Apr 08, 2010 | GE Profile PSW26P Stainless Steel Side by...
Handle of refrigerator is loose. How can you tighten it?
Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Oct 24, 2009 | KitchenAid Superba Architect KSCS25INSS...
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Dec 22, 2007 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
