Question about Canon FAX JX210P All-In-One Inkjet Printer
How to keep a fax on phone mode? - Canon FAX JX210P All-In-One Inkjet Printer
    Genius:
  • 1,127 Answers
Hi
Go to the menu and select mode option there u will see three option Tel Mode, Fax Mode, Tel & Fax mode, select Tel Mode..
Posted on May 20, 2011
Canon mx 410 fax answers voice calls
I have an MX870 with the same problem - fax picks up during a voice call and I can no longer hear the caller. As with everyone else, the problem is intermittent and not replicable.
I have tried tel priority mode and fax priority mode (from the phone/paper submenu under physical Fax button) and all the various RX receive setting under Fax Settings submenu of the physical Settings button.
But I have a new possible solution. I only use the fax for outgoing -- for some time now I have been using K7.net for incoming faxes which delivers faxes to my email. That way I have a dedicated fax number, never miss an incoming fax while on the phone, and I have all faxes in electronic form as well.
So, my new idea was to set the MX870 to DRPD (distinctive ring pattern) receive mode (from the phone/paper submenu under physical Fax button). Since my phone service through Xfinity/Comcast does not offer DRPD, I am hoping that the MX870 will NEVER pick up a fax.
I will keep you posted as to whether this works.
Jan 13, 2012 | Canon Pixma MX410 All-In-One Printer
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
I have the fax connected to the phone line with a splitter which is also connected to my portable phone and answering machine. when the phone rings it goes to answering machine if not answered and then to...
The fax machine should have two places on the back where you can plug in a phone cord. One of these is the input: where the cord from the wall goes, and should have either "in" or a picture of a wall phone outlet next to it. The other is used as a line through the fax machine and should have a picture of a phone or "out" next to it. Ideally, you would plug the fax machine directly into the wall and then your phone/answering machine into the "out" plug on your fax machine.
When in auto mode, the fax machine will listen in on the line when the phone rings and if it detects a fax signal (all the whirring and beeping) it will pick up the phone and receive. If there is no signal, it will simply allow the signal to pass through to the phone and answering machine.
Jun 02, 2011 | HP 1010 Plain Paper Inkjet Fax
I cannot receive faxes. I have a voicemail set up on my phone that is in use. I would like to use the 1050 as a phone and a fax machine only. I will settle if I could only use it as a fax machine. I have...
If you have a voicemail set on the same line then you may only be able to use either the fax or the voice mail if you want to the fax then change the rings to answer on the fax to 2 (setup button->basic fax settings->rings to answer->press ok on 2) keep the mode to auto mode. However if you want to use both the voicemail and the fax on the same line you might have to get a DRP (Distinctive Ring Pattern) from you telephone company.
Jun 10, 2010 | HP 1050 Plain Paper Inkjet Fax
The fax answers each time the phone rings. If it's a fax then it's fine and it comes through. If it's a regular phone call then we can't really talk as the fax noises keep going off. We have a phone...
Your symptoms indicate that the machine is set in the "Fax Only" receive mode. If you are using the line for both fax and voice calls, you need to set the receive mode to "Fax/Tel". See Methods for Receiving Faxes in your Basic Manual for your options and how to set the desired mode.
Jan 27, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
The fax mode is turned off. The phone keeps ringing without the fax mode picking up.
You need to setup the fax to pick up automatic fax the moment it receives a call.
Aug 03, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Cannon MX850 Fax Problem
Have you tried telling the printer that it is to be used as "telephone priority"
Press the "fax" button on printer, then "menu" button
Use the left or right arrow keys to key across to "Receive mode settings" then press OK
Use the up or down keys to select receive mode. You should make sure it is in "telephone priority" then press OK
Hope this helps
Dec 04, 2008 | Canon PIXMA MX850 Multifunction Printer
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Able to send fax cannot receive fax
make sure phone line is pluged into line on fax,make sure fax is set auto.there should be a button on fax panel that say's receive mode.
Sep 07, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Canon FAX JX210P All-In-One Inkjet Printer Logo
99 people viewed this question
old marine
old marine
