Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
x3 has lots of software bugs, just power off phone , remove battery , repower and try again, if still not working do a factory reset from settings, beware this will delete contacts also, so back up phone memory from memory card option an contacts option and pc suite backup to be on safe side.
dont forget to comment
This problem is caused by Viruses use a good anti virus and update it regularly.... First you need to format your phone take out memmory card from it,save important contacts and files to pc, Then full charge battery and dial *#7370# Then press yes and enter password wait for a minute at that time your phone is formatted. Now insert memmory card to computer(dont insert memmory card to phone) and format it. Now download a antivirus For free(Netquin) Click here
check you message settings and check weather you using phone memory or card memory and lastly check in file manager that you have a enough phone memory to memorise your last called numbers...
Sorry, your phone can keep a record of up to 100 incoming calls through its caller ID function, but on the outbound it only saves one - the last number dialed - for redial purposes.
This sounds like this may be an issue with your tv 2, make sure your remote is in sat mode by pressingthe sat button. then select, if still nothing take your remote to the recvr and look on the back of the recvr to make sure the uhf ant. is standing straight up if not, straighten and try remote functions. if you stillg et no responce there could be other issues that are simple to fix depending on what kind of equipment you have. you can call 800-333-3474 for assistance or reply with recvr name or model #.
no your software is not damaged actually your problem is that the phone memory is full what you do is install pc suite and backup your data after that use this code to reset the phone *#7370# after punching this code it will ask for security code put default security of nokia that is 12345 phone will reboot and everything is done last you do is restore your data i hope your problem will sove
