Question about Car Audio & Video
Musical fidelity amp x-a2, one channel intermittent crackling / fading out, any ideas?! Tried swapping source and speakers... Many thanks -chris
  • 6,694 Answers
This problem will occur when any one of the driver transistor is become faulty. You have to replace all the driver transistor of the same channel which make cracking sound . It is very difficult to tell which one is faulty. Because if you check the transistors with multimeter it will be ok. Replace all the driver transistor in that channel with same part number marked on it. The driver transistors will look like this,
Musical fidelity amp x-a2, one - ajin_g_6.jpg ok
Posted on May 20, 2011
Caimbridge audio amp right channel always dies
Stereo amps are two mono amps put together. So if you have a bad channel then you also have a good channel to compare it with. I suspect you have a faulty transistor. You can test it by proding the channels with a pen or your finger - touching plastic only parts. The two channels should buzz. If buzzs in the left then if you touch it in the right it should do the same. An alteration or change in the sound in the right and you have found the faulty part.
It's nothing to do with the power supply section so keep away from that!
Dec 10, 2012 | Cambridge Audio Audio Players & Recorders
Hi, I have a SR92 which intermittantly cuts out on the right side only. If I quickly flick the volume knob up past about a third the speaker kicks back to life. Doesn't seem to be a pattern to it and I...
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Mar 15, 2011 | Marantz SR-92 Mark II Receiver
Fuzzy crackling sound from front right speaker only -tried switching speakers and speaker wires with front left and the right still gets fuzzy and crackles
Look to the source. Try switching or reseating any cables between it and the speakers.
If it's only an analog source doing it I would suspect a bad audio cable or a switch somewhere in the signal path. Typically, it might be a switch you
rarely use, like a Tape Monitor. It's wise to occasionally (with power OFF) operate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Jan 29, 2011 | Audio Players & Recorders
There is a crackling noise coming from centre speaker, have tried another speaker and still the same, so not a speaker problem. Have also tried different DVD player and still the same noise, and even...
It depends on what wrong is with the receiver. If there is bad DSP (digital surround sound processing) board better to buy new receiver. If it is just bad channel it can be repaired below or about hundred dollars. It could be also just simple cold soldering joints. You need to bring it to a repair shop and get an estimate.
Jan 11, 2011 | Denon AVR-1507 Receiver
Hi, I get very intermittent hissing/crackling from the left channel of my NAD C370. I've replaced the speaker wire and the wire that I'm using for bridges on my AE Evo 3 speakers which seems to have...
Could be caused by a burnt resistor in the channel of the main power amp. You should be able to see it. It might have been caused by the faulty speaker wires.
Oct 07, 2017 | Audio Players & Recorders
NAD 3020a crackle in right channel regardless of volume.
more than likely you have a bad transisitor on that side and the frequincey is distorted there's not much you can do except take it back if it's new or take it apart and check for the bad part but if you do that you had better know what your doing!! it may be just 12 volts but thru an amp it's a nasty shock
Jul 26, 2009 | Audio Players & Recorders
No sound out of left side speakers, front and back.
easiest way to see if the left outputs have gone is to swap the right and left speakers over. if the left works out of the right channels you know if the set has had it.hope this helps
Apr 22, 2009 | 2004 Nissan Sentra
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Car Audio & Video Logo
409 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
