Question about Acer Aspire 5735 Notebook
Hi, my acer 5735 shows 5 flashings in the battery led when i press the power button. What does this means?
    Problem Solver:
  • 10 Answers
I had this problem with my acer before its the motherboard if its in warranty you should send it back to acer and they'll fix it for free and if its a manufacturer like mine was even if its not under warranty they have to fix it for free. http://www.acer.com/worldwide/selection.html
Posted on May 20, 2011
On acer aspire laptop screen is grey at startup
1. When you press the power button to turn it on, do you see any thing on screen, It probably should show an ACER logo?
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). If you do see a faint image it could mean your back light is broken.
3. When you press the power button do you get different LED's lighting up on the laptop? IE power LED, hard drive LED?
4. Does your computer give you any random beeps when it starts up?
Please answer these questions and I would be more than happy to work through this with your.
Thanks RCCT
Jan 16, 2014 | Acer Aspire Computers & Internet
Acer aspire 5735 takes a charge but wont power on
Check memory sticks (one at a time in different slots)
and
Remove battery, and power cable. Keep power button pressed for 5 min then insert only power cable and try to turn on
Mar 21, 2013 | Acer Aspire 5735 Notebook
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
HI , I have an Acer ZG5 netbook. The unit will not turn on, i mean nothing. The wall charger works. The battery light shows its charged. When I push the power button, nothing happens. When I hold the power...
my acer netbook will not come on.the charger is working,i took the battery out ,and still the battery light and the power button blinks at the same time.And after pressing the power button constantly, the screen blink on and off every now and then.
May 08, 2011 | Acer Aspire One Netbook 8.9" Notebook
Are there any battrey problems with this laptop because i take the charger out when it says 100% and plus i put it on saver mode and with in 5 mins it has turned off and the barrty light flashes !
The battery has reached the end of its lifecycle. These days batteries only last between 1 and 2 years. The flashing light just means that you better save your work because the battery is almost out of power.
Feb 20, 2011 | Acer Aspire 5735 Notebook
When you turn the laptop on it turns off with 30 - 60 secs.
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Acer Aspire 5735 Notebook
Hi. My acer aspire 5735 doesnt turn on. I turned the laptop off as normal however when i came to go back on it just wouldnt turn on. The charge light stays on to show whether the battery is being charged....
When a computer does not boot up, but the battery is charging, it could be a CPU or RAM problem.
Re-seat the RAM modules, this will make sure it makes proper connection to the motherboard.
Next try removing the battery and power up the laptop with just the power adapter connected. If it boots up then insert the battery while it is powered up.
Oct 23, 2010 | Acer Aspire 5735 Notebook
Won't turn on. On button glows green and harddrive light flashes and goes out. On button continues to glow. If I hold the on button down 5 seconds it goes out. It was working fine, I turned it off and...
*This method only applies to Aspire ONE A150 only
1) Format USB memory stick with FAT file system.
2) Download BIOS for A150
http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_Acer_3310_A_AOA110%20&%20AOA150.zip?acerid=633850493862245097&Step1=Netbook&Step2=Aspire%20One&Step3=AOA150&OS=X01&LC=en&BC=Acer&SC=PA_7
3) Extract all files the downloaded file and place FLASHIT.EXE and BIOS file onto the memory stick
4) Rename BIOS file to ZG5IA32.FD
5) Turn netbook of, with power AND battery connected
6) Plug in memory stick with BIOS file and Flasit.exe
7) Press and hold Fn+Esc the unit will go on, hold until power LED is flashing then release keys. If it does not flash, then release and press power button once.
8) You'll notice the LED of both the usb memory stick and the power LED will flash together.
9) After a few seconds the flashing will stop and the unit will reboot or switch off completely.
^^ this is a copy paste from my own solutions
May 13, 2010 | Acer Aspire One AOA150-1570 Notebook PC
My acer Notebook Does not switch on
Well you can reseat the RAM and check if that does not fixes the issue, it could be an issue with the system board . You can contact Acer support line, if the unit is under warranty you can have system board replaced.
Jun 29, 2009 | Acer Extensa 5420-5687 Notebook
Changed ink jets alarm flashing number 5800 showing
Hello Saron Girl,
its not 5800 its 5B00
7 times LED Blink Waste ink absorber full [5B00] - Ink absorber (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257)
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
4 times LED Green Waste ink counter resetting
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Regards,
May 14, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Acer Aspire 5735 Notebook Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
