Question about Acer Aspire One AO521-3089 10.1-Inch Netbook - Antique Brass (884483039319)
I have a gateway netbook and the sound is too weak even if the volume is max'd already. please advise. thanks.
  • 2,632 Answers
Welcome to Fixya. Would like to know if this is happening on all movies, youtube videos or even audio files. Please advise
Thanks
Posted on May 20, 2011
The sound is weak. The max. Volumn is very weak. How can I get it louder.
In general, tablets don't have powerful sound systems. Some ear-buds will play louder than others, but don't expect any built-in speaker to play loudly. Try different ear-buds, that may help, or an external "amplifier".
Dec 07, 2015 | Visual Land Prestige Pro 10D 16 GB Wi-Fi...
Low volume problem on the gateway netbook lt2102h
Small Laptops or Laptops in general are not know for sound. The speakers are tiny by design. You can make some adjustments by opening Control Panel, Sounds, Click on speakers and, Configure, and Advanced adjustments. It may help a bit. Try heaphones. The media player may have some adjustments as well, look in settings for Audio, Equalizer, etc.
Jan 30, 2013 | Gateway Computers & Internet
No sound, drivers can't be found
right click on the red X icon select playback devices there will be a red x on the speakers right click configure them
hope this helps
Jun 27, 2012 | Gateway Computers & Internet
Hi, I have Sony Vivas u5, the volume is too low, even after increased max. Is there any code to increase volume. thanks. please help me?
NO sorry there is NO code to do this. I wonder if the speaker hasn't gone partially faulty? Replacement is the only option.
Oct 11, 2011 | Cell Phones
My Marshal Amp MG50DFX sound is very soft even tho the volume is on max. when I switch on the gains circuit and turn up the gains control there is louder sound, but a humming niose also, what can the...
First of all please check your cables because this kind of problems mainly arise due to cable errors.Second solution is check your input.For an example try a another input from a DVD player or etc.Third solution is ,you have to check your amp's mic volumes,please reduce your mic volume fully.Check you equalizer too,Please check and inform me if it doesn't work
Sep 15, 2011 | Audio Players & Recorders
I have been using 901 speakers and eq with onkyo tx-8522 av. but now when i turn on tape 2 monitor on, the sound become very weak, even i turn the volume to the max. when i turn off tape 2, the sound come...
Qualifier: I have 901's in a 7.1 setup and have written many posts on Fixya regarding how to do it right.
NEVER USE MAXIMUM VOLUME FOR ANY PURPOSE UNLESS THE RISK OF ACCIDENTAL SPEAKER DESTRUCTION IS A ACCEPTABLE.
ONLY now it does that? "VERY WEAK" as in attentuated somewhat or is it signal leakage, effectively silence? How is the EQ wired in? Check its own Tape Monitor button.
If you DO NOT have a separate amplifier for the 901's the EQ will affect EVERY speaker and we know that is NOT desired.
If the EQ is in a Tape Loop of a modern AVR and you activate the loop two things will happen: 1) the 901's will sound better and the rest of the speakers will be at risk from excessive amplitude at the extremes; 2) any digital source will be disabled.
Jul 10, 2011 | Bose 901 VI Main / Stereo Speaker
My speaker on my asus eee 1000he is not working corectly. I'm unable to here people speak they sound as if the volume is turned way down and can not here most music clearly. Even with headset it does not...
the sound card in n that netbook is a very weak one, alot of people complain, could be that
could also be that you have the wave volume turned down...
go to start
control panel
sound and audio devices
right under the volume slider click the advanced tab
make sure all tabs there are maxxed out
if that doesnt work
turn dolby on, suposedl;y that helps...
if that doesnt work, turn the volume up all the way, play a soft song, like saxaphone music, adn get the speaker close to your ear, if you can barely hear the music, and get about the same amount of static or white noise, you have a shorted circuit with the internal sound system...
Jan 08, 2010 | ASUS Eee PC 1000HE Netbook
When i connect my netbook on the front of the receiver i have sound from the tv speakers but seems as the power is not enough for loudenss ( i bearly hear them). My netbook has only headphone out. how can...
Check your netbook's volume settings and see if they are at the max. If the head phone Jack is standard 3.5 mm then you can connect it to external speakers and see if it resolves the issue. If they are and still you can't get a decent volume, then you will need to get an amplifier to increase the sound input so that you can get proper volume on your tv.
Sai.
Jan 02, 2010 | Sony KLV-L32MRX1 32 in. LCD Television
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Acer Aspire One AO521-3089 10.1-Inch Netbook - Antique Brass (884483039319) Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
