Question about HP Office Equipment & Supplies
Hp 4000 error code 93:11, not in my manual, can't find anything online need HELP.
  • raytcmia Aug 14, 2008
    NEED HELP
    THANK YOU
3 Suggested Answers
SOURCE:
SOURCE: trying to conect to the singstore and am recieving
http://boardsus.playstation.com/playstation/board/message?board.id=singstar&message.id=12521&jump=true#M12521
Try to change the DNS server. It worked in my case.
Posted on Dec 23, 2009
seeker5211
  • 1089 Answers
SOURCE: Errorcode 93:11 on HP designjet
Unable to pressurize the IDS(ink delivery system). Ink Pumping problem.
Corrective Action: Try the following:
Remove ALL the Ink Cartridges and reinstall them one by one in to the
Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing
Cable
Posted on Jul 16, 2011
HoMedics SS-4000 adaptor replacement specs.
Google (Homedics)(SS-4000)(manual) without parens for guidance.
Aug 03, 2018 | Homedics Audio Players & Recorders
How do i fix error: illegalAttributeValue
Hi PATRICK OKYERE
I'd like to help you with the illegalAttributeValue error you are seeing. I found something that might be helpful to you, please use the following link to take a look:
PCL XL error IllegalAttributeValue on printing some excel files
I hope this helps,
I work on behalf of HP.
Jul 05, 2015 | HP Laserjet 4000 Series Printer 27920 Page...
Printer settings can not be changed error 0x000006d9
You can easily get rid off of Printer settings cannot be changed error 0x000006d9 within time by dialing HP Printer Customer Support Number 1(844)355-5111 24*7 available for your support to fix your printer error online with the help of brilliant technicians.
HP Printer Support Phone Number 1 844 355 5111
Jan 15, 2018 | Canon Office Equipment & Supplies
Janome memory craft 4000 manual online
You can find it here:
http://ifixmachines.com/index.php?page=shop.product_details&product_id=776&option=com_virtuemart&Itemid=54
Jul 25, 2010 | Janome Memory Craft 4000 Sewing Machine
Printer buttons all flash green when I turn it on
You can usually download a pdf manual from HP support for free.
Here is a link to on on Fixya
http://www.fixya.com/support/p378621-hp_psc_2210_all_in_one_inkjet_printer/manual-3472
The manual should have the error code near the end of it.
You may want to go to HP support to find the exact error code shown by the lights and how to resolve it. Usually given that you just changed cartridges I would say one or more isn't seated correctly. Take them back out and reseat them and see if that fixes it.
Without the exact code being displayed I can't give you the exact proper answer/fix.
Aug 21, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp 4si
Your post is correct that error 53 refers to bad memory board or at times defective SIMM only. Since you have replaced them and no change, you may want to try to do a Cold Reset of the printer. This is done by powering on the printer while holding down the GO or Online button. Additionally, you may want to check/reset your NVRAM settings which can be done manually through the Service Mode.
This page lists most of the HP Laser Printer error codes. This link displays most HP LaserJets - Cold Reset Instructions.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 16, 2007 | HP LaserJet 4si Printer
Error codes
Hi, you have listed three problems lets start with the first one. A rundll error code is usually related to a program trying to run that has been altered in some way. The first place you will want to look is in the startup folder in all programs in the start menu. Delete anything that you no longer use. If you want, list everything in the startup folder and I will help sort through them.
Sep 15, 2007 | HP Compaq Presario V2000 Notebook
Open Questions:
422 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
