Question about Pyle PLD61MU Car Video Player
Sound works but there is no display on the monitor. it worked for the first few days then now cant see nothing. Does the park brake wire have to be hooked up in order to show the display cause i know it has to be hooked up to watch a video?
    New Friend:
  • 3 Answers
Ground the parking wire should do it
Posted on Sep 26, 2014
  • 3,018 Answers
  • Yes it does. The emergency brake wire is a safety feature. If you don't have it hooked up it won't even display anything. If you do have it hooked up then you have to have the emergency brake engaged to be able to view DVD'S. The manufacturer does this so people can't just unhook the brake wire and watch DVD'S while driving
Regards, Tony
Posted on May 20, 2011
2004 acura tl 6speed standard. VSA light/triangle light/parking brake light come on.
your vsa is vehicle stability assist that works with the abs system, verify brake calipers for proper functioning, sounds like breaks stick and cant return efficiently after breaking, vsa is a traction control light, if both lights remain on without flashing, those systems are disabled due to a problem, scan vehicle for possible abs sensor malfunction
Jan 06, 2017 | Acura Cars & Trucks
Cant take my car out of park, 2007 ~ 300 chry
there should be a shift lock overide button on the shifter look in owners manuel. just push button in and shift
make sure brake lights work most cars wont shift out of park unless brake is on. they use the brake light switch for this though some have a seperate switch on the brake pedal
check ALL fuses under dash and under hood replace any that are bad
Mar 25, 2010 | 2007 Chrysler 300 AWD Sedan
Rear parking lights dont work 2001 GMC sierra
It would then be a bad ground. Start at the bulb fixtures cleaning and refastening; look for cracked broken wires as you go. A little multimeter will help.
Jun 09, 2009 | 2001 GMC Sierra Crew Cab
All brake lights suddenly stopped working changed bulbs park light fuse and cant find any blown fuses what else can it be
brake switch on the pedal bad.bad relay. do you have a second fuse box if so check it. look at the wiring see if it is frayed or chafed check the connections.check all the fuses not just the ones labeled brakes.switch the relay with one that you know is good like turn signal and see if the turn signal works then check brakes.use a 12 volt test light check the brake switch and probe the wires. hope this helped if not write back and i'll give you more ideas.
Apr 24, 2009 | 1996 Buick Park Avenue
Handbrake indicator light & interior light not working
the buld in the dash that lites up the dash are burned out. well they have individual bulds so check it out.
Nov 17, 2008 | Ford Festiva Cars & Trucks
NO DVD PIC
Do you have the manual, on a kenwood i think the brake wire is green, this wire is usually quite long, long enuff to go from head unit to your handbrake. You need to connect this wire to the vehicle chassis( ground). This may sort you out. You would normally have a message saying parking brake not applied. Do you get a display when listening to radio or cd????
Apr 24, 2008 | Kenwood KVT-719DVD 7 in. Car Monitor
I cant getta dvd picture on my kenwood kvt 719dvd...brake wire???
Did you install it, they generally sense whether youre moving by having a connection to your handbrake, if this is not connected the unit thinks youre moving but usually gives an on screen message.
To disable this you usually have to ground the brake sensor wire( connect it to the body of the vehicle)
YOU TRY THIS AT YOUR OWN RISK!!!!!!!!!!!!!!!!!!!!!!!!!!
Linear uv7
here's the code. I did this with my remote and it works.
press stop twice(which is also the band button)
press1,2,6,4
press down 1 time(button below the play/enter)
press play/enter 1 time
(you should see the menu now)
brake override should say no
I was told to change macrovision to no
hit system setup twice to save and exit
hope it works like mine did
Dec 07, 2007 | Phase Linear 160W AM/FM/CD Receiver W/...
Panasonic CQ-VD7005U in dash dvd 7'' touch screen
Connect the light blue parking brake wire coming out of the back of the radio to the black ground wire also out of the radio to the black ground wire on the wiring harness.... Basically just ground the parking brake wire.. Itll work, I promise. I have the 7001u.
Dec 03, 2007 | Panasonic CQ-Vd7001U
Pyle PLD61MU Car Video Player Logo
296 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
