Question about IBM ThinkCentre A50p PC Desktop
Where do i find the ether net connection - IBM ThinkCentre A50p PC Desktop
    Problem Solver:
  • 5 Answers
If you mean the ethernet jack on the machine itself, you should find it on the back near USB ports and where you plug the monitor into it. It will look like a phone jack, but wider.
Or, there may not be an ethernet jack built into the computer. You could purchase a PCI expansion card with an ethernet jack if this is the case.
Posted on May 20, 2011
  • 40 Answers
It is on the back of your tower. It looks like a phone jack.
Why can't I access Netflix on my TV - tells me to try again.
Try null start reboot of TV and MODEM , turn off unplug wait 10 sec. ( if modem separate ) unplug all devices including ether net connection cable tv ect. Off 10 before repower connect what ever runs TV 1st this will cause network refresh, some modems have battery back up should reset, try net flix nothing else if it come up plug other devices in the order ether net second repeater wireless check each one before you continue , Is Neflix the only problem if not call signal provider IE , CABLE DISH who ever if you are on a net work have them test your your IP /SUBNET MASK /DSN and see if theirs a problem. Good luck let me know.
Aug 18, 2014 | Computers & Internet
Hi i need help with my wireless connection PLEASE. it will connect to the internet via the ether net cable but not wirelessly
IF you have wifii on the laptop you need to check to make sure the driver was downloaded or you will have to download the driver.
Feb 06, 2011 | Computers & Internet
My modem disappeared off my laptop, how do I get it back?
sounds like your comp did its own system restore on you and the file needed to keep parameters of modem connection disapeared
you need to go into control panel network set up wizard follow instructions this should set your network back up
do you have the driver disks for the ether net card reinstall ether net card drivers
never setup network threw internet explorer these ways dont hold
May 09, 2008 | Acer Aspire 5500 5570-2609 Laptop
Canon ImageRunner 3030: connecting scanner to network
Do you hvae a ether net PCB installed on it ? It is normally a option. You need the right boot rom and ether net pcb first
Feb 08, 2008 | Office Equipment & Supplies
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Wireless router
first connect the devices in this way
from us inter net modem to belkin routers inter net port connect a ether net cable rj45-->then connect another ether net cable rj45 from pc to -->ethernet port on teh belkin router>and reboot the router and modem if u r using cable inter net then immediatly that will work>and open a browser window type this in address bar http://192.168.2.1 u can see the belkin login screen and follow this link
http://www.gorge.net/help/wizard/belkin/f5d7230-4_pppoe.htm
Nov 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
Motorola SB5101
ya u should have a router instead of a modem because modem provide only one ip address>and there is no DHCP server in the switch or hub>so buy one router which has 4 ether net port and connect it directly to the modem and connect ur two pc's behind the router then both will get a seperate ip address from the router both will go online
the connection is
modem-->ether net cable to the inter net port on the router-->and two ether net cable from both pc's to the 1 and 2 ether net jack on the router reboot all the devices>and modem+router+pc's then it will work>rate me solved if its helps thx
Nov 14, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Can't connect to the Internet
iam workinh for vonage and so its ur phone working then change the ether net cable>and and delete all the temp files and cookies and clear history>and also if still its not works change teh ether net port bet ween the pc to teh vonage devie>and still if its works then u need to check with the ether net card driver or ether net card>rate me solved if its help full
Oct 31, 2007 | Arris WR850G Router (DHWR850G)
Wireless router
modem to inter net or wan port on this router>and u have 4 ether net od lan use any one -->ether net cable to pc's>and if u r using cable inter net then reboot the both router and modem u can get inter net access if its dsl contact linksys cause need to configure teh router rate me solved if its help full thx
Oct 29, 2007 | Linksys EtherFast Cable/DSL VPN Router...
IBM ThinkCentre A50p PC Desktop Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
