Question about Frigidaire FAC107P1A Wall/Window Air Conditioner
A/C Model: FAC107P1A My unit is not putting out cold air. The temp wire is not touching the coils. I've cleaned the filter, and behind it. What do you think the problem is? What needs to be done to fix the problem? Could it need Freon? What type of Freon does it take? I have a certified person to put it in, but I have to get the Freon myself. Is it a sealed unit? Will it be obvious to him, where to put in the Freon? He said that he's not sure, but hasn't looked at my unit yet. I have to get everything done in one visit. He's our bldg's Maintenance man, and is not suppose to do to do any personal work. That's why he said, that it all has to be done, at once. I personally, am not mechanically inclined. Therefore, any assistance you can give me, will be greatly appreciated. Even if this is not causing the problem, I may need to clean the A/C unit better. I live next-door to a huge industrial plant. It's putting ash, and who knows what, in the air. If you look at my car, you can see where it's eating the paint. I've thought about using a can of compressed air on it, like you use on a computer. What are your thoughts on this?
  • 8 more comments
  • drillsgtsnoo May 20, 2011
    I haven't done those checks yet, but wanted to answer your questions.
    This A/C has a permanent filter, which I clean very frequently. While cleaning it, I use the sprayer on the
    kitchen sink. This unit, also has a dirty filter indicator light. It use to take 2-3 mos, for the light to come on. Now, it comes on weekly. This is why I thought about using a can of compressed air. I try to clean it before the light comes on, but sometimes it beats me to it.
    Even though the A/C is not putting out cold air, I still have it running. No, I haven't been hearing the compressor kick on. I use to.
    I'm not sure what you mean by "programmable thermostat". On the A/C itself, there are digital controls. I can set it for specific temps, like 66, 72, and etc. It goes down to 60 degrees. This unit does have a remote control, which contains batteries. Are you telling me that I need to change them?
    I don't know specifically, where all those coils are located. I tried Googling for a diagram of my unit, and it took me back to your website. When I searched your site, there were 368 results. I'm having trouble finding the exact one I need. Would you please send me a diagram, showing me where all the coils, and temp sensor, are located? I have the manual that came with this unit, but it's poorly designed. Could you also, please tell me the best way to clean the coils. Does the part of the A/C, which is outside the house, need to be cleaned? Do I need to take it apart?
    I just realized, that this entire time, I've left an important part out. It is NOT DRAINING AT ALL.
    I'm a disabled vet, whom lives alone. To remove the cover/housing, do I have to take the A/C out of the window?
  • drillsgtsnoo May 22, 2011
    Yes, I have a friend that will help me. It's going to take some time though, due to their work schedule. I hate to keep asking you questions. When doing the Freon Test inside the house, how far do I hold the thermometer from the A/C? Outside the house, do I go by what the actual temp is, or do I need to use a thermometer? If so, how far from A/C do I need to hold it? Where do I put the thermometer on the A/C, outside my house? Normally, my A/C drains every time I use it. It stopped draining, at the same time, it quit cooling. Could that be why it's not cooling? Or is it just coincidence?
    Fixed, or not, I WILL get back with you. PLEASE don't close my case, yet.
    I really APPRECIATE all your help. You have been so patient with me, thank you so much.
    I have one more question... since the temp sensor was not touching the coils, could that be the whole problem? I'm just asking, I DON'T know anything about A/C's, except what you've taught me.
  • drillsgtsnoo May 24, 2011
    Just wanted to touch base with you. Haven't been able to mess with my A/C yet. Just got home, and it"s almost dark, and lightening. I'll be able to check it out on Tue or Wed. It'll probably be Wed. I'm sending you this email, so you won't be "hangin". I WILL DEFINATELY be in touch. It'll probably be Wed.
  • drillsgtsnoo May 27, 2011
    No. I asked the Maintenance man to check the Freon with his gauge. He said that he has to access it the same way, as if putting Freon in it. Therefore, just in case, I'm going ahead and getting the Freon, and piercing valve. If not needed, then I can return them. I'm trying to accomplish that today, so maybe the Maint man can take care of it today. The 90's are too hot for my apt, and it's a holiday weekend. I'll get back with you later today, or tomorrow. Thank you for your patience.
  • drillsgtsnoo Jun 02, 2011
    Sorry it's taken me so long to get back to you. I still haven't gotten that A/C going. I still have to try putting Freon in it. Our Maint man asked me to look online & see if I could find it in small cans. He told me the wrong kind of Freon, so I wasted hours of my time. Now, I have to research the correct Freon. Meanwhile, due to my health, I've had to go ahead & purchase another new A/C. It's been a nightmare & an expensive one. We've had to go to Lowe's & purchase 3 different A/C's, before we found one, which fits in the window & works properly. I'm still going to try to fix the old A/C. If I can get it going, I can put it in the kitchen window.
    I have a question about the new A/C. I just want to make sure that it's working like it's suppose to. It's been on since Mon. It has not drained at all, and I've never heard the compressor kick on. It is cooling, but it should be a little cooler. It too, is a Frigidaire. The old A/C was 10,000 BTU's, and the new one is 15,000 BTU's. Do you think this new A/C is working properly?
  • drillsgtsnoo Jun 03, 2011
    It's set at 60 degr, which is the lowest it will go. I called the store mgr. He said that I may not hear the compressor kick on, in this model. If it wasn't working, would it be cooling? As far as old A/C, I'll look for the Freon online this weekend.
  • drillsgtsnoo Jun 05, 2011
    it is 22. The Maint man told me to look around for the best deal. He's going to order it for me with credit card.
    Genius:
  • Frigidaire Master
  • 1,033 Answers
Hello, if the filter, evap, coil, condenser coil are clean then most likely the unit if low on freon. most window units take either r 134a or r -22, it will say on the data plate on the unit. To charge freon into the unit a piercing valve will need to be installed on the low side of the system since most window units do not have acess fittings, piercing valves are about 10 bucks and can be purchased at any heating and cooling store. a easy to check if the unit is low on freon is take a thermometer and measure the air going into the filter and then the air leaving the unit, the differance should be 15-20 degrees, if not the unit is low on freon. But first verify everything is clean and airflow is not obstructed.
Posted on May 20, 2011
  • 7 more comments
  • Robert May 20, 2011
    also it's very important that the thermostat temp sensor touches the evap coil or the compressor wont engage.
    I dont have the diagram for your unit, but there are two sets of coils,one in the front of tje unit and one in the back of the unit. In order to get to them you must remove the cover to the unit. In order to clean them youncan buy coil cleaner at any heating and cooling store and spray it on both sets of coils. The temp sensor will be on the coil that is inside the home, so when you you remove the cover and filter you will see it against the coil. Just make sure it is making good contact with the coil. As far as draining most window unitsuse the fan to splash water on the condenser coil to evaporate the condensate, if you unit has a drain hooked up to it just make sure it is clean.
    Yes, unfortunatly it has to be removed from the window. Is there anybody that can help you remove it from tje window?
  • Robert May 22, 2011
    You want to hold the thermometer as close as possible to the evaporator coil and as close as possible to where the cold air should be coming out, then find the differance between those nombers. The teason it could not be draining is because the system is very low on freon, if tje unit d oes not have freon the moisture from the air cannot condense on the coil and therfore does not produce condensate, or if tne temp sensor if not making good contact with the evaporator coil the compressor does not engage and allow the refrigerant to flow.thus no condensate. And yes if the tempmsensor was not touching that could of been the whole problem. Feel free to keep asking questions, i want to help youmget this unit going.
  • Robert May 24, 2011
    No problem
  • Robert May 26, 2011
    Hi there, were you able to check your ac?
  • Robert May 27, 2011
    No problem, if you have any questions feel free to ask.
  • Robert Jun 02, 2011
    Most window units do not drain the condensate, basically the fan blade scoops up the water and splashes it on the condenser, since the condenser is warm/ hot it will evaporate the condensate and no drain is needed. As far as thec ompressor kicking in it will depend on the temp you have it set on, you might need to turn it down a little for the ompressor to engage.
  • Robert Jun 03, 2011
    Well if the unit is cooling than the compressor is running, what type of freon does your old window unit use? If it is freon-22 than you wont be able to buy it without a epa card.
  • 710 Answers
With the outside air quality you described, you'll have to clean the filter a lot more frequently. Maybe a total filter replacement would be better than cleaning in your case.
Let me ask first, do you hear the compressor kicking on when you turn it on?
Check the thermostat and see if it is set lower than the room temperature. Try setting it at least 10 degrees lower than your house. Listen for the compressor to kick in. If it does, close up the room and give it at least 20 minutes, then go in and see if it feels any cooler.
Do you have a programmable thermostat? If you do, change the batteries and see if that helps.
Don't just let someone put freon in your A/C when you don't know what's wrong with it. The added pressure, if it doesn't need it, can blow the unit for good.
Please reply back and let me know how it's doing after these checks. If it's still not working, we'll go further.
By all means, clean it! :>)
Compressed air is fine.
Thanks,
Handie Andie
  • Handie Andie
    Handie Andie May 23, 2011
    I'm very sorry. I didn't receive notice that you had replied back.
    If you don't hear your compressor kicking in, then, yes it could be low on refrigerant. There are other things that could cause the compressor not to work also.
    If the maintenance man has a gauge and knows how to put the right amount of freon it, then let him try it. If this does not solve the situation, then I would call a repair person.
    Hope this helps. Sorry it took so long to get back to you.
    Stay cool!
    Andie
How to check filter of frigidare fac107p1a
Good Afternoon Friend,
I understand you want to know how to check the filter of your Frigidaire air conditioner, model# FAC107P1A. The air filter should be checked at least once a month to see if cleaning is necessary.
Trapped particles in the filter can build up and cause an accumulation of frost on the cooling coils.
    1)Push the vent handle to the Vent Closed position (where applicable).
    2)Open the front panel.
    3)Grasp the filter by the center and pull up and out.
    4)Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing.
    5)Or, instead of washing you may vacuum the filter clean.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 02, 2014 | Frigidaire FAC107P1A Wall/Window Air...
Why is my air conditioner not blowing cold air
I understand that your Frigidaire air conditioner, model# FAC107P1A, comes on with the compressor running, but the air is not cold. First, check to see that the temperature sensing element, located behind air filter, is not touching a cold coil. If it is, straighten the element away from the coil. Secondly, try resetting to a lower temperature. Lastly, the compressor may have shut-off by changing modes. Wait approximately 3 minutes and listen for compressor to restart when set in the COOL mode. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire FAC107P1A Wall/Window Air...
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
Apr 19, 2017 | Heating & Cooling
My unit has a ton of black mold in the back of it; should I be worried; how do i clean it??? Also i need to know the best way to clean the filter? I just moved in to an apt with this unit and i've...
I would let the managment know about the mold problem, this can be serious. If you want to clean this yourself, use rubber gloves, a brush, and buy a spray bottle of mold remover. The filter should be located behind the front grill. It should snap loose, and they are normally made of a foam material that you can wash in your sink and let dry. Sometimes they remove them a throw them out!! If this is the case, let them no about that also.Please keep me posted.
Shastalaker7
A/C, & Heating Contractor
Aug 08, 2011 | Frigidaire FAC107P1A Wall/Window Air...
Hi. My 2 year old Friedrich CP10E10 window unit is not cooling the room like it should/like it has. I followed obvious troubleshooting steps per the operation guide, including thoroughly cleaning filter....
Check the OUTDOOR coil... it sounds like it is clogged up and the system is cutting out on high pressure...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Friedrich CP10E10 Thru-Wall/Window Air...
99 Chevy Blazer(4.3) will not start on cold mornings(20-30 degrees). Will turn-over but not start. Once the Sun is up and it warms up, will start all day. Distributor changed about a year ago.
Sounds like a coil intermittent. Try a new coil or if you want to test it you can connect an ohmeter to the wires then put it in an oven at about 200 deg. Watch for opening, increase in ohms, in the coil wires.
Hope this helps.
Jan 14, 2010 | 1999 Chevrolet Blazer
AIR NOT COLD ENOUGH
sounds like it loss some freon
May 02, 2009 | Heating & Cooling
Bad Odor
You need to clean the indoor coils with a coil cleaner. Its probably mold that has been dormant until you turned the unit on and it became wet. Clean the indoor coil real well with an approved cleaner. Some Home Depot's carry a coil cleaner that is in a spray bottle.
Apr 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Sometimes it blows cold, sometimes it doesnt.
The coils that are located right behind the filter need to be cleaned extremely well. You can purchase a spray from your local hardware dealer that can clean the coils. Also, rinse the fins at the back side of the unit as well. Dirty units can cause this to happen. If you clean it and it continues, you have developed a refrigerant leak. Since window units are so inexpensive today, it is not cost effective to hire someone to come out and find and repair it. Hope this is of help to you.
Apr 11, 2009 | Frigidaire FAC052K7 Air Conditioner
Heating & Cooling Logo
151 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
