Question about Samsung Televison & Video
Connection advice needed
I have a Samsung flat screen tv, a sky box (pace) and a new samsung dvd/video combi recorder complete with hdmi lead. Could you tell me what way they should all be connected? Thanks
Mandy
    Problem Solver:
  • 12 Answers
Hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me (dodzio24@o2.pl) and i send you the best solution i can.
Posted on Aug 14, 2008
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
I have a Bose 3.2.1. GSX Series 3 system. Recently, when playing DVD's I am getting sound only and a message on the TV screen saying 'No Signal' and on the 3.2.1. display 'communicating with your TV'....
Possible faulty lead or a poor connection. Has the new Sky Box been fitted to the HDMI socket the Bose had? Try switching sockets if there is more than one HDMI socket.
Jun 02, 2017 | Bose 321GS Series II System
Diagram to set up the Panasonic DMR EZ47V DVD/Video recorder
Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the LCD . Connect the AV output of the Sky box to the AV input of the Panasonic combo.
Hope it will cover the matter
good luck
Jan 29, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
I need a wiring diagram to connect a samsung tv, sky+HD, DVD recorder, Wii and Playstation 3...thnx
all you have to remember is out of one into the other IF got Ariela on house that goes into sky then out of sky in to DVD recorder and out of that and into tv
on back of sky hd if you are going to use HDMI cable put cable into sky box and other end into tv ( you will have ot put tv on HDMI input/source)
or use scart lead in stead
THIS DEPENDS ON HOW YOU WANT TO CONNECT PLAYSTATION
everything else is colour coded
Nov 08, 2009 | Samsung 37" 720p Flat-Panel LCD HDTV
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Sony connectivity
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Dec 23, 2008 | Televison & Video
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
177 people viewed this question
Henry  Thomas
Henry Thomas
