Question about Magic Chef MCD1611ST Microwave Oven
SOCKET GOT POWER BUT NO DISPLAY - Magic Chef MCD1611ST Microwave Oven
    Scholar:
  • 142 Answers
There is a fuse inside that is probably blown. If you replace it and it keeps blowing the fuse when you open and close the door, that means a problem with the door switches sequence. I could run you through that step by step.......
Posted on May 20, 2011
  • lmorphis
    lmorphis Feb 26, 2012
    Where is the fuse located?
  • sunila obaid Jan 22, 2013
    Hi, I am having the same problem with a magic chef microwave. I replaced the fuse and the thermo cut off fuse and the power came back. (I didn't use it though) next morning it was gone again. Could you please give some more details about the door switch problem? Thank you!
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
How do I replace the bulb for the display panel of a Sharp Microwave oven Model # R-314F ?
Normally switch power off and remove plug from wall socket, undo screws around side and back panel and remove outer cover, then the light socket will be visable so change light bulb and reassemble, CAUTION: high voltage may be present so best left to service person for safety
Jul 23, 2014 | Sharp Microwave Ovens
WHY MICROWAVE OVEN IS DEAD ,2000 MODEL bajaj
there could be many reasons for your microwave to be dead. First did you check if it has power coming to it? Is the plug out of the socket? Sometimes the power plug is behind the microwave and it is hard to see unless you slide it out and look. When you say dead, is the display light up? If so does it indicate PF (Power Failure)
Sometimes the internal fuse blows out because of a short, usually caused by the diodes being shorted or even the transformer or the magnatron tube itself. If you have any of these problems except for the fuse then I would recommend that you replace the microwave with a new one because yours probably wouldn't pay to fix.
Good luck,
Marty
Jun 04, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Microwave light socket shorted out
every thing all right accept working heater both heater tube doesn't light or no power on it
Nov 14, 2013 | Amana Radarange Microwave Oven
Here in Australia we have different power sockets and power supply As I understand the machine I have has 120V 60HZ 1025 W What do I need to use it here in Australia? Do I need a new plug or a...
good day.
first,the power socket,,try to see the power plug of your machine and the power socket you have..compare it..when its compatible no need to replace,,if not you need a socket adapter.or if not available buy a new plug (if your plug is not compatible to the socket)
secondly,you don't need a transformer if your ac supply in Australia is 120v..
if the supply in your place bigger than 120v...like 220v,230 or 250v..you have to use a step-down transformer with input of what you have in Australia and the output is 120v..and of course pay attention for the wattage of transformer to avoid over heat or burn..I suggest to buy 1500w...
thank you and good luck
Apr 07, 2011 | Microwave Ovens
Can i plug in my b4140-1 into a 13 amp socket
Check the power rating of the oven. A simple calculation is divide the power by the voltage to get the current, in other words, if the maximum power rating allowed at 230VAC for a 13A socket is about 2900W or 2.9KW. Normal electric ovens will usually require a 45A supply. A standard microwave is about 800W and so can be connected to a 13A socket.
Feb 22, 2011 | AEG Microwave Ovens
Maytag MMV5165AAS work surface light won't work. I bought a new light and replaced the old one but it still will not turn on. THe microwave display goes thought the cycle of High, Low, Off but nothing...
If the lamp socket has power (and it's the right voltage) and the replacement lamp is the correct one and tests good, then the trouble is in the socket. It may have been damaged when the original lamp went "poof." Check for damaged contacts (burnt or broken off). Also, make sure you're seating the lamp correctly in the socket. If the bulb is a push-and-turn ("bayonet") type, you may be facing it the wrong way and it's not going all the way in.
Nov 11, 2008 | Maytag MMV5165 Microwave Oven
NO power display dimesnion 4 range national microwave NNC 2000P MODEL
on front panel there is alow voltage transformmer the primary side isopen circuit replace
Mar 20, 2007 | Panasonic NN-C994S Convection/Microwave...
Power Problems on NEFF H7871 Combi Microwave
It would seem there is a bad connection in the fuse holder or in the wall socket or in the microwave itself. Maybe you can narrow it down to the microwave by trying other devices in the wall socket. If it's the microwave, it's time to call for serivce.
Dec 11, 2006 | Neff H7871N2GB Convection / Microwave Oven
Magic Chef MCD1611ST Microwave Oven Logo
788 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
