Question about Enterasys Distributed Forwarding Engine w/12 1000BASE-X Ports (mini-GBIC) ( 7G4270-12 ) (7G427012) Transceiver
Utorrent port not working
On my utorrent site,down where the dht enabler is ,there is an orange warning triangle whih says port not forwarding correctly.please help,dave
  • seanannan Oct 31, 2008
    There's an orange triangle at the bottom centre of the page, when i place the corsor on it it is telling me that there's no incomming signal
  • 67 Answers
It doesn't need to be port forwarded unless it is not downloading. But if you must, check portforward.com for instructions specific to your router.
Posted on Sep 12, 2008
SOURCE:
Hi, I'm having problems port forwarding my Thompson TG585 v8. Im trying to port forward for utorrent application but it does not seem to work, everytime i get an error saying "port is not...
- Please check if it's UDP or TCP. You might have selected TCP for port forwarding but Torrent also uses UDP. For some ports that's important to make both forwarding. One for TCP, the other for UDP.
- If this doesn't work, you need to go deeper. You need to have access to an external computer on internet (a friend) from which you can start a telnet. For instance :
telnet mypublicip 45682
On your side, you need to check what's coming on your network interface. Two options to achieve this :
- Either you book a linux live cd (kubuntu), and you run in a console :
sudo tcpdump -ni eth0
(eth0 is the first ethernet adapter of your workstation).
- Either you use wireshark on Windows, this should do the trick, but you cannot be sure that there is no other software blocking on your current installation.
Regards,
Jul 10, 2011 | Computers & Internet
How do I change the NAT setting to open?
Hello and welcome to FixYa.
My guess is that you are looking for port forwarding (eg: port 80 to host a webserver, or maybe a utorrent port for torrent downloads).
These are my suggestions for this issue in general (Assuming you first logged in to your router administration panel. Usually located @ address 192.168.0.1 or 192.168.1.1 or 192.168.0.254 depending on manufacturer can be located underneath the router on a sticker, along with the default admin console password and username):
1. Please enable UPnP to set NAT to open.
2. Goto the port forwarding section (might also be called Virtual server section etc.) and do a port forward using the IP of the computer you need to open port to, with TCP port 80 or 8080 or utorrent port or the number of the port you may need in general.
Please tell me how much did that help you.
More info on this matter that might be helpful can be found==> here
Thanks.
**!Dont Forget to rate how helpful was this solution for you!**
Mar 24, 2011 | Computers & Internet
Problem opening port for utorrent with DGL 4300 router
You must set static IP on your computer where the utorrent is installed. Make sure no firewalls are enabled on your computer like windows firewall or any other firewall like norton, mcaffe, zone alarm and the likes. You should forward the port on separate protocol. Go to portforward.com for more information on how to forward port for utorrent
Jun 14, 2009 | D-Link GamerLounge DGL-4300 Router...
Port Forwarding with Kaspersky Internet Security 2009
Anti Hacker -> Settings -> Enable Firewall -> Low Security -> Settings ->
Rules For Applications -> Add -> Torrent
Edit Rules -> Add -> Rule Name -> utorrent
Properties -> Remote port (selected)
properties -> Local Port (selected)
Rule description -> Remote Port - >(enter the port) -> DEPENDS YOUR CONFIG
Rule description -> Local Port - >(enter the port) -> DEPENDS YOUR CONFIG
Allow Inbound and Outbound TCP connection, where :
Remote Port: DEPENDS YOUR CONFIG
Local Port : DEPENDS YOUR CONFIG
May 25, 2009 | U.S. Robotics MAXg(USR9108) Wireless...
Here is a great website: http://portforward.com/routers.htm
Get your model number of your router/modem, and find it on the website list, then it gives you the instructions on how to foward ports.
Hope that helps.
Jan 02, 2009 | D-Link DSL-504T Router
Download speed
1.connect through the lan port
2. keep ip as automatic (from lan properties > tcp/ip)
3. open modem configuration page by typing http://192.168.1.1 in the address bar of your web browser.
4. create a bridge or pppoe setting using vci = 0 and vpi = 35
5. if u choose bridge mode then create a dial up broadband connection from new connection wizard
6. give the port settings over there in modem and use the same ports in your torrent client.
7. You are done . and you will see the speed increases becoz of DHT enabling freely and you will get downloads bypassing the torent server tooo... :-)
Hope it helps to you. Thanks.
Dec 18, 2008 | Computers & Internet
Utorrent
yes that indicates that there are no incoming connections..when u click on the triangle you come to an option that says to check if port is forwarded properly and to configure the connection speeds..
i am a regular u torrent user and my port is never forwarded correctly..despite the orange triangle i get very good download speeds..a trick i use is to use the"force start" option on the downloads..right click on a downloading torrent and use force start option..i also noticed that over time the triangle becomes green..hope it helps!
Oct 31, 2008 | Enterasys Distributed Forwarding Engine...
Utorrent port forwarding
when ya say done everything what ya mean bud????
Aug 19, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Cant get decent speeds from u torrent
I recommend checking out http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/eMule.htm
This is a great tutorial on configuring port forwarding on your particular router. This example is for emule but it will be very similar to uTorrent. You will want to determine what port uTorrent is configured to send data on and use that accordingly.
Jacob
Mar 18, 2008 | Belkin (F5D7230-4) Router (587009)
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
Feb 21, 2008 | Linksys Wireless-G WRT54GL Router
Open Questions:
See all Enterasys Distributed Forwarding Engine w/12 Questions
Enterasys Distributed Forwarding Engine w/12 1000BASE-X Ports (mini-GBIC) ( 7G4270-12 ) (7G427012) Transceiver Logo
599 people viewed this question
Top Enterasys Computers & Internet Experts
Ekse
Alun Cox
Are you an Enterasys Computer and Internet Expert? Answer questions, earn points and help others
