Question about Char-Broil Commercial Stainless Steel Grill
Need a new ignition swicth. year 2005 model DHLB
    Brigadier General:
  • 4,736 Answers
Whether it's electronic ignition or the old, standard, push button piezo ignitor, you can find it at the Char-Broil Parts Link below.
http://www.charbroil.com/Store/ReplacementParts.aspx
Happy Grilling!!
Posted on May 20, 2011
How to replace ignition switch on Troy Bilt Lawn Tractor Model 13ap60tp766?
there should be a nut on the key side of swicth cover by a rubber boot take boot off redisconnect on back of switch take of nut remove switch put back together in reverse order
Aug 25, 2014 | Troy Garden
Turn key car starts fine turn key to shut car off and it dont shut off
that could be the ignition swicth when you turn the key to take it out its like a kill swicth to spot the spark plugs working. you might need a new barrel look for the key. just I think.
Launch X431 tools
Sep 27, 2013 | Mercury Grand Marquis Cars & Trucks
I have a 2005 grand marquis the wipers blades come on themself while driving the swicth is off
disconnect battery first, then with the key in the ignition, using a paper clip or something the same size put it in tiny hole on bottom of switch pushing up and turn key counter clockwise should allow the ignition lock cylinder to come out.
Apr 24, 2011 | 2005 Mercury Grand Marquis
Car wouldnt start ooutta nowhere,, would have to push key in harder b4 wouldnt start finally... help feel like i am paying too much san antionio tx
the first thing to do is to use penrating oil to lubricate the key barrel if the please replace the ignition swicth assemble,remove the steering column cover by a metal screw then remove the cover and remove the screw from the cylinder barrel remove the ignition swicth assemble then replace with a new one
Mar 17, 2011 | 1996 Oldsmobile 88
The security light keeps flashing...everything works in car...just need to know how to program the new key i purchased...
depends on year as some vehicles will programme a new key providing you have the original but a newer car from 2005 is a dealer only job ,if this is GM product then like some europeon GMs you turn ignition on with original then turn off and remove key then insert new one and turn ignition on and pump brake pedal 5 times and depending on the vehicle this will work but an american model ?? i honestly do not know .
Mar 07, 2011 | Chevrolet Monte Carlo Cars & Trucks
New battery...still won't start.
if you have installed a new battery and it still wont start it is most likely the starter that went out and will need replaced. hope this helped
Jan 03, 2011 | 2004 Pontiac Grand Am
I need electrical plan for pluging my radio ,for toyota echo 2005
If you are attempting to install an aftermarket radio Don't butcher the plugs on your Toyota ... simply go to a car stereo shop and buy an adapter plug for $10-$20 then wire it to your new radio ... then just plug them together (the wires on the adapter are marked) You'll likely need a dash kit too ... save yourself from a lot of frustration time and money! ....
May 08, 2009 | 2005 Toyota ECHO
My ktm 105 isn't getting no fire .
you need a new ignition coil
Jan 09, 2009 | 2008 KTM 105 XC
1997 sable changed radio and fuses clock and radio still doesn't work whatelse could it be
You need to identify the cable that feeds electricity to the radio when the ignition swicth is in the ON possition, and then identify the stanby power cable ( this is the cable that always has current even with the swicth on OFF possition) The Stanby cable goes to the cable marcked memory on your new radio. the other cable simply goes to the power suply conection on the new radio.
Aug 29, 2008 | Mercury Sable Cars & Trucks
Won't start up
does the ignition swicth still click wen turned?
check the power to the back of te switch
check battery
check altinator
check engine fuse
check fuel pump fuse
if none works get back to me with make model and year of car and exactly what it is doing
Jul 03, 2008 | 1996 Hyundai Accent
Char-Broil Commercial Stainless Steel Grill Logo
248 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
