If i turn my Thomson 585v7 modem off and back on it dosent change my ip and im sure i dont have a static ip
    Problem Solver:
  • 18 Answers
Depending on you ISP (Internet Service Provider) it may assign you a DHCP address with a certain amount lease time. in other words when your modem requests an IP to connect to the web your ISP says 'OK here use this one for this long'. When that time limit is reached it will request a new address at which point may then get a new one or it might just re-new the current one you have.
Typically your can log into your modems web interface and find a menu that will show the current status of your modem and somewhere on that page should be a release/renew button that you can click to force the modem to let go of its current IP address and request a new one. Again it might just give you the same address you just released back to you though.
Having the same IP address is not really a bad thing.
Hope that helps clear it up.
Posted on May 20, 2011
Change ip address
If your IP address is static,you cannot change it.Static IP will not change even when you reset the modem.You have to contact your Internet Service provider(ISP) for changing static IP.If your IP address is dynamic,it will change whenever you reset the modem.If you want to check your IP address,visit Ip-details.com .
May 11, 2013 | Toshiba Satellite Computers & Internet
When i first set it up it was fine,since then the wires had been disconnected,when i put it all back the way it should go,i lose my internet connection on my pc,and on my nextbook,says i have connected to...
Make sure that the cable from the modem goes to the Router's Internet slot.
then the cable from either 1,2,3,4 can go in your computer.
then you need to turn OFF the router and modem for 1 minute
then turn ON the modem first, wait for 30 seconds.
Then turn ON the router, wait for 30 seconds. It shold work now.
Feb 27, 2011 | Cisco Linksys Wirelessn Router Black...
I have a DHG536C Cable modem from Comcast. I am using a Linksys Switch, EZS88W, and the modem can see one computer but nothing eles, what is wrong?
Have you connected all computers, then switched off the switch and modem. now switch off your computers.
If you then power everything up, it should detect the computers, and assign them the correct IP addresses.
If your still having problems, you may need to assign static ip addresses (google for instructions for your computers/switch)
Sep 14, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
I need to download a modem for thomson tg
Dear,
This is the location
http://www.thomson.net/GlobalEnglish/customer-service/SpeedTouchDocuments/xDSLGA-Wireless_Firmware_UK_gen_TG585_en_7-4-4-7.zip
Oct 17, 2009 | Computers & Internet
IP Address
Your ADSL port IP address will be set by your ISP and will be displayed on router status page. Your LAN port IP address is likely to be http://192.168.1.254
Oct 09, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Thomson 585V7 router cannot get a WPA wireless connection
Try to reset the router by pressing reset button and holding for 20 sec (its a small hole at the back of router).
Then try to setup wireless network.
Jul 27, 2009 | Computers & Internet
Need to forward to static ip
access your modem i belive the ip address is
192168.0.1
if not then run an (ipconfig) on ur command prompt
use the default gateway on ur address bar
by default the username and password are both (admin)
if you set ur own up then im sure u know what it is
go inthe modem click on
(advanced) then on (ip static routes) and type in information that should take care of it !
rate my service please
july
thanx
Apr 20, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Ps3 conection
the username and password should both be admin. once in the settings select the ps3 IP and change to a static IP this should just solve your connection problem
Nov 09, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Installation problem with edimax 6104kp
Hi Omdi,
Please proceed with the following instruction as follow.
1.) Connect first the modem to your pc, if you find it is working then get the IP Address, Subnet, Gateway, Primary DNS, Alternative DNS at the network properties TCP/IP.
2.) Open your router where you can configure the static IP or manually enter the IP address, subnet, gateway, primary dns, alternative dns.
3.) Make it sure you used the cable properly by connecting it to the appropriate line. For the modem to router you should connect the cable to WAN port. And the LAN port must be go through the computer.
If you still experience the problem, please let me know.
Best regards,
Philip
Oct 02, 2007 | Edimax BR-6104K Router (br6104k)
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
