Question about Toshiba 32C100U 32 in. TV
My fuse keeps blowing and my tv won't come on.
  • Toshiba Master
  • 2,098 Answers
Hi Joseph,
Make sure that you replaced the fuse with exact ratings. Low ampere ratings will not handle current as what the original fuse installed. If still fuse keeps blowing after replacing with the same rating, this is an indication that you have a short on the power supply section. It can't be fixed by replacing the fuse alone. Short usually near the AC line where parts like the following are present.
  1. Power Cord - even very low of chances but still to be check.
  2. VDR
  3. Rectifier diode
  4. Main filter electrolytic capacitor
  5. Voltage regulator I.C.
This is the common parts that might be shorted and made the fuse blew. You may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution.
You may also replaced the entire power supply board. Click this LINK to order online.
If you are near to repair shop, you may bring the power supply board to them and isolate the shorted parts, you will save some money rather than sending the entire unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 20, 2011
2 Suggested Answers
electrotech1
  • 1126 Answers
SOURCE: Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Posted on Sep 14, 2011
2006 huskee supreme slt 4600 fuse keeps blowing, any ideas, it's the one by the gas tank
you have a wire grounding causing the fuse to blow you will have to trace wires to see if one is pinched or rubbed raw
Jun 17, 2013 | Garden
Honda Accord keeps blowing fuse and won't start
Recently we had to put a new fuse in the starter ???????????? What fuse ? location , size . A fuse blowing means a electrical short to ground .
May 29, 2017 | 1998 Honda Accord
My atc fuse would keep blowing I put a bigger fuse it didn't blow that but I herd a zap noise from my TCCM now my 4x4 won't work 1999 jimmy
What you have done? You Just damage the TCCM and that's why you will not manage to shift 4x4. Why this happened? Because you had shortage somewhere and you receive blown ATC fuse.You put a bigger fuse in capacity where the was stronger to blown and the fault moved to the tccm system which was not protected and blown.Ask for an expert to check and see whether the fault is easy to get fixed.
Jan 02, 2013 | 1999 GMC Jimmy
The TV won't turn on. It is plugged in, but won't turn on at all. Is it fused?
It has a fuse and if the power light comes on and blinks a specific code that would be a error code.
This set weighs close to two hundred pounds, follow the power cord inside the set as it goes almost directly to the fuse which should be a 6.3 amp fuse----careful if its bad, it is a slow blow and special, a Radio Shack or Generic one the same amperage and type will blow for no reason, if its bad don't keep feeding it fuses.
Dec 08, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Blown fuse amp start fuel 8
Pls be more specific, doe's this fuse keep blowing or what? Fuse blows and your car won't start. I have a 2004 GTC and the #8 fuse kept blowing, had to replace the starter, (it was pulling 80amps instead or the normal 30-35) once the starter was replaced, no more starting issues and the fuse no longer blows. Hope this helps, good luck
Sep 12, 2012 | 2004 Chrysler Sebring
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
Fuse in motor keep blowing and motor keeps running but once stopped won't restart
What year, make model and engine size there? Send details please.
Brake lights keep blowing fuse, Trunk indicator light won't go off with trunk closed
may have a short could be a bare wire recheck the brake switch make sure that the switch is not touching and metal.
____________________
BMW b800 srs airbag scan/reset tool
Jun 11, 2012 | 2001 Dodge Intrepid
Fuel injector fuse is blown, keeps blowing. Engine turns but won't catch and start.
if the injector fuse is blown then the car won`t start as its not getting fuel into the motor to fire.if the fuse keeps blowing then you could have an injector/s that is drawing too much or the injector driver in the ecm may not be any good and needs replacing or a used ecm.it could be a short some where in the wiring for the injector system that is going to ground.
Feb 22, 2012 | 1995 Chevrolet Lumina
My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
Toshiba 32C100U 32 in. TV Logo
422 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
