I have a snapper pro s200x zero turn mower with a 27hp Kohler engine that starts and runs fine until the parking brake is disengaged. The engine then dies. I have inspected the switch on the parking brake and it appears to be functioning correctly. Half of the switch is normally open and half is normally closed just as the wiring diagram states in my parts manual. The mower was running well this evening and then just stopped dead in action. Now this is the behavior that is found (previously described). This also happened one other time at the beginning of spring. At that time I went through all the wiring to check for lose safety switch connections and found now. I swapped the two relays and the mower started to run just fine after that (used the same two relays just traded locations). I attributed this coincidence to possible dirt in the relay connections but, it was a stretch to believe at that time. I have tried that trick again with no luck. So, I am not sure where to go next and I don't want to start throwings parts at it in a blind attempt to resolve the issue.
SOURCE: Problem with camera on my pearl
I have had this problem for the last 4 month after upgrading the OS. The camera never worked, but... two or three times, after taking the phone from my pocket, I saw that the camera was working (the phone was not locked). Then, I wondered why the camera worked in my pocket and not when I tried to make it works.
I have realized that if you put your finger covering the flash when you try to start the camera, the camera will start without problems. Not sure if this will work also for you.
Now the flash seems not to work properly when taking pictures but at least I can take some with light.
Posted on Apr 28, 2008
rytech uk
  • 85 Answers
SOURCE: initialization failure after rom update
Hi. I had this problem with my iPaq and there is a soloution. Unfortunatley. it is impossible to repair whilt you are running vista. HP insists that you run Windows XP or Erlier, with Active Sync installed. We can however give this repair a try. I would need to know first of all what country you are in, and which version of the 6515 you have. i.e a, b, c etc....
email me with the details and i'll email you back with the soloution.
Posted on Jun 20, 2008
SOURCE: My HTC Touch suddenly turn off, and Is hard to start it again.
the solution to the problem is explained in detail here
Posted on Oct 31, 2008
SOURCE: Car skips and sputters and dies
My problem was the fuel pump. The one I got didn't seat in the bracket like my previous one. This caused the fuel line to lose pressure. Turn off and back on, and it was fine for a while. I put a gasket spacer between the fuel pump and the bottom of the bracket (in October) and haven't had the problem since. Hope this helps.
Posted on Apr 10, 2009
SOURCE: LG ku990 icon shows(application running)but don't
Apparently I had the camera application open when the phone rang. After completing the call the phone did not go back to the camera, but the main screen. I forgot that I was on camera application.
Problem solved.
Posted on May 13, 2009
Husqvarna 61 inch zero turn model ZTH6125 Engine cuts out.
Sounds like the safety switch may have stuck. Allowing it to set, the switch "released". Just my guess.
Apr 18, 2015 | Husqvarna Garden
48" snapper zero turn yard cruiser
ether bad check valve or pump went out check valve 100.00 if pump 300.00
Sep 07, 2014 | Snapper ZT2748 48" 27HP Zero Turn Lawn...
When parking brake is moved off position, the engine shuts off on my rz5426 zero turn mower.
One of the safety switches is bad or not making contact. Check the switches on the levers and the seat switch.
Jul 19, 2014 | Husqvarna Rz5426 54" Zero Turn Lawn Mower...
Unlock hydraulics
2 places where they might be, lift your seat and look where your hydraulics are and you should see on each pump a bolt with a hole going through it turn those to loosen the pressure, another place is under the mower, on both sides you will see a pin that you pull back to a locking bracket just pull those out and it will roll freely and put the back to drive again same with the first suggestion
Nov 13, 2013 | Snapper Pro S200x 27 Hp Kohler 61"...
Engine starts fine. Go to release the brake and it stalls. Snapper pro 61"
u have a bad switch or a wire touching somewhere maybe the sit switch
Oct 14, 2013 | Snapper Pro S200x 27 Hp Kohler 61"...
Safety switch - parking brake
You can but I wouldn't recommend it. I would get a multimeter and check switches for continuity. This will tell you if switches are good or bad. This switch could be a normally open or normally closed switch that is why I wouldn't recommend jumping it until you know what kind of switch you have. I think your defineitly on the right track though. Good luck.
Aug 05, 2013 | Toro 52" 27hp Z Master Zero Turn Lawn...
2 mowers 19.5 hp and 27hp kohler, both die when you let off brake
Sure sounds like an elusive safety switch to me. There's usually one on the seat, the blade control, and the brake.
Jun 04, 2009 | Garden
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
