Question about Garden
I have a Black and Decker 7552. The brush on the left side will not stay in. I have taken it apart twice and reinserted the brush it will work for about 5 min. Then you can see sparks on the inside. The motor works good then you have no power. If you can also tell me the dot thats on the side its pointed. Does it go the same direction as the other brush or opposite.
  • 2,019 Answers
If you mean it falls inside, then the brush is too short and worn out, and should be replaced.
If you mean the cover vibrates loose and it comes off on the outside, then you need to use a little blue locktite to hold it slightly.
Posted on May 20, 2011
I need the electrical motor P/N 90565704-04.
Do you need a new motor or is it just the brushes which need replaced? Firstly unplug the machine and disassemble the motor or gain access to the brushes, found on either side of the motor at one end only. Remove the brushes (they usually unscrew behind the black caps), if they are burnt or look badly worn or are less than 5-8mm in length, replace them. The BRUSH is the black carbon rectangle of hard material at the end of the brass spring. New brushes are often 25-30mm in length as a guide. Based on that information you then decide if new brushes or a new motor is the answer. A quick tip; If you remove the motor and clamp it safely, connect the correct voltage to the motor lead and switch on long enough to establish if it is working and running freely. If you cannot find the parts locally, try www.4ourhouse.co uk.
Apr 17, 2016 | Black & Decker Black and Decker Mm575 18"...
Tip
B&D GS500 Parts Manual Download
Download Black and Decker GS500 Cordless Grass Shear Parts Manual
Have you misplaced your Black and Decker GS500 Cordless Grass Shear Parts Manual?
Have you taken your Black and Decker GS500 Cordless Grass Shear apart, and can't get it back together?
Would you like a digital, searchable, pdf version of the Black and Decker GS500 Cordless Grass Shear Parts Guide?
Follow this link (& click FREE) to download a pdf version of the Black and Decker GS500 Cordless Grass Shear Parts documentation.
I hope that helps.
__________________________________
B&D GS500 Manual Download
on May 08, 2010 | Garden
Black & Decker Belt Sander suddenly stopped working.
Probably not.
It may have just had a part break inside, like the on-off switch, or one of the wires to one of the brushes, etc., etc.
I buy these regularly, and they are inexpensive, which also means they are made of inexpensive ( cheap) parts.
It wouldn't hurt to take it apart, knowing it may not be repairable. Sometimes parts are available on-line.
Be blessed.
Mar 10, 2013 | Black & Decker BR318 3" x 18" Belt Sander
Two-year-old Black & Decker 19"
if its not in the cord. it may be the brushes in the motor. if they are worn down and not hitting armature. motor will not run. good-day !
May 05, 2011 | Black & Decker 19" Electric Lawnhog...
I have Black Decker electric Edge Hog, does not turn on anymore. Is there a fuse or power reset switch?
I have a black & Decker Electric Edge Hog, does not turn on anymore. Is there a fuse or power reset switch?
Jun 13, 2010 | Black & Decker Le750 Lawn Edger
How do i dissasemble my Black and Decker Electromate 400
Cold weather can freeze the water that the compressor normally makes, try warming up the unit first.... eliminate the simple problems first.....
Jan 30, 2010 | Black & Decker Air Tools & Compressors
Toaster switch- Black and decker- TRO360TY6
I don't know if you can fix it but if you are good at basic diagnosis you can take off the right side and see if the toast latch is broken or perhaps out of place. This type of unit is not so easy to take apart and put back together. The parts fit is a bit strange.
May 14, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Feb 06, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
