Question about Refrigerators
My Vestfrost wine fridge (more than 10 years old) now trips the mains in my house everytime it is plugged in to turn power on. Had to keep it off power to prevent blackout. Who can I call to check if it is worth repairing ?
    Top Expert:
  • 2,899 Answers
I like to use Sears Parts for that www.searsparts.com
They repair or furnish replacement parts for all brands.
Hope this helps.
Posted on Jan 27, 2015
  • danoyachtcap
    danoyachtcap Jan 28, 2015
    Sorry, that's www.searspartsdirect.com
    Scholar:
  • 142 Answers
Does it trip in a fraction of a second? That shows a direct short. Does it take, lets say, 10 seconds? That could mean that the compressor will not start, and usually that can be fixed with a new start relay.
Posted on May 20, 2011
Why does My marvel 61WCM wine fridge turn on but right away off again?
First make sure it is not plugged into an extension cord. Low voltage could cause this type of problem. If you have it plugged directly in ,It is probably the compressor or overload relay on the compressor. You can bypass the thermostat to see if it is the problem, by first unplugging the device, then removing the wires from the thermostat, and jumping them together. Then plug it in If it still acts the same way the problem is in the compressor or overload relay mounted on the compressor. Sometimes the relay can be purchased and replaced or a hard start might work solve your problem.
Aug 07, 2014 | Marvel 61WCM Luxury 45 Bottle Wine Cooler...
Amana refrigerator sparked by plug and now won"t turn on even when plugged into another outlet with extension cord should i repair or replace?
i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
Oct 12, 2017 | Kenmore Refrigerators
Hi there, i have a two door westinghouse fridge it's 4 yrs old, we had a storm monday afternoon and came tuesday morning it had a power search then the whole thing just swtch off and also all the major...
Unplug the fridge, plug in a different appliance to the outlet to make sure the outlet isn't bad.If it trips the breaker for that circut might be bad.Hope this helps if so give us a 4 thumbs up. THANKS
Mar 02, 2011 | Westinghouse Refrigerators
Pushmatic breaker keeps tripping everytime I hit
You have it shorted out somewhere along the line. If it is a light switch you are switching, what have you done lately to make this trip? Anything? You might have a bad breaker. You can check it by shutting off the power, pull the wire out of the tripping breaker, put it in another breaker, turn the power back on, switch the breaker on, then hit the switch and see what happens. If it snaps off, it is not the breaker, but the switch, the wires in the box, or the lights, or something along the line, you will have to check each one. New construction has made all lights and all receptacles separate, so if your house is old, you might be looking at receptacles too. Check anything plugged in to an outlet, make sure there is nothing shorting. Hope this helps.
Apr 03, 2010 | RTO Pushmatic 100Amp 2-pole circuit...
MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Jun 29, 2009 | Magic Chef MCWC16MCG Wine Cooler
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
When I plug in my refrigerator, it throws my circuit breaker?
You may have a seized compressor, evaporator or condenser fan - have you tried turning it off first, plugging it in and seeing if that will hold? If you open the doors with the fridge off, will the lights still work? Can you hear the compressor start up when you turn the fridge on, or does it trip right then?
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Fridge keeps tripping the circuit breaker
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Mar 01, 2009 | Refrigerators
Zanussi frostfre fridgefreezer r600a
if a frost free type and happens only now and again, suspect defrost element short to earth
Mar 20, 2007 | Zanussi ZEBF277W Bottom Freezer...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
