How can I adapt the connection from my asko washer that is supposed to plug into the dryer to the outlet in the wall?
    Scholar:
  • 142 Answers
I believe the washer works on 120 Volts. All you need to do is replace the plug with a standard 120 V plug. Home Depot has plenty of them.
Posted on May 20, 2011
My Asko T7781c dryer programme panel is dead. The mains switch turns on but nothing else functions. There is no reset button ; the dryer did not reset itself. A new circuit board at $300+ ?
On the back of the dryer, there should be two fuses in black or grey holders. Should be round knurrled caps or slotted holders. Check these. The fuse holders could also be overheated and burnt.
Is your dryer plugged into the washer for power? Or directly into a outlet in the wall.
Jun 22, 2016 | Asko Dryers
Where I can find circuit breaker for asko washer?
Check your breakers.
You may want to temperally connect to the hot water heater outlet.
May 02, 2014 | Asko Dryers
How to connect a dryer
Hi Sheliah,
I'm an electrician and would like to help you. Assuming you're in the U.S. and this is an electric dryer (not gas), you will need to find a 240 (a.k.a. 250) volt / 30 amp circuit to connect it to for it to work. This would be connected to a double pole 30 amp circuit breaker in the electrical panel. There is no simple residential "adapter" to change voltage, current or number of wires - besides the old 3 wire grounding plug adapter in you grandmother's junk drawer. (What is a 50/250 volt dryer? - did you mean a 30A/250V?)
Your dryer should have a 4 wire cord with a 4 prong plug on the end - and it will need to be plugged into a matching outlet. The old electrical code allowed you to change the cord to match the outlet, but now it requires that both the cord and the outlet be a 4 wire type. The old 3 wire cord type is no longer permitted to be used when the dryer is moved or replaced. Of course, 3 wire cords are available everywhere and it is unlikely that anyone will turn you in for changing the dryer's 4 wire cord back to a 3 wire cord type (but I just wanted to tell they way it is supposed to be done). What you do - is your business.
If you have a gas (or LP) dryer, you probably only need a 120 volt / 15 or 20 amp outlet - they look like the standard types - but I think you'd have simply plugged it in and walked away if that were the case.
I hope this helped!
Apr 07, 2014 | Dryers
ASKO 7000 series washer drum stopped rotating. Smelled of burning. Could not turn the drum by hand. Guessing a burned out bearing as electronics and pump still work and are trying to turn steel drum. ...
check inside your washer for nails or other objects . I already seen a nail fall down in one of the basket holes and the nail stuck into the outer tub not allowing the basket to spin. If you dont see anything in the basket holes, then it is your bearings. The burning smell is coming from your belt. The motor is spinning but your basket is not. It is cheaper to buy a new washer. In ordered to fix your washer you have to rebuild it. The bearing are built into the outer tub of the washer.
Jul 13, 2011 | Asko 8005 Front Load Washing Machine
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
Asko W/D. Power to 220 wall outlet and washer
Hello paulehni, welcome to Fixya.
First things first, have you checked the 15amp fuses which are located at the back of your Asko dryer ?
**Turn off your breaker at the home service panel, it should be a 30amp switch**
That is where I`d start and focus your attention. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown. You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, amresupply.com, reliableparts.ca etc. Part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
May 16, 2010 | Asko Dryers
I need to know if a new Asko Dryer will stack with my old washer
The exterior size hasn't changed and the plug to run the washer is the same so I don't see a problem. A good retailer can check this for you , but I haven't seen any difference in the stacking kits.
Feb 12, 2009 | Asko T712 Electric Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
