Question about Fiesta Blue Ember Gas Grill
My grill is burning low it will not get hot enough. I leak checked and there is no leaks.
Take it part on inside and clean real good . All parts should lift out. Also you can put a new burner on the bottom of your grill. They sell new burners at Walmart home depot and lowes good luck
Posted on May 20, 2011
Burning Hot and Burning propane tank empty in 2 to 3 uses
What does "and parts to burners" mean? it sounds like you have NG orifices on a LP appliance or the LP orifices are not properly drilled. I use my barbecue several times a week and exchange an LP cylinder about every 6 months. If you are using the grill twice and the cylinder is empty that is not a lot of burning, that is a leak.
to adjust the burner the first and most obvious place to look is to check the pressure on the regulator (LP is 11") and the orifices. Next are there adjustment screws inside the valve stems? if so light the barbecue so the flames are visible and insert a long flat-head screwdriver to adjust the set screw inside the valve stem. turn the valve to "low" and adjust it until the flames are just barely staying on. Leave the set screw in that position and turn the valve on high, close the lid. if you're over 400 degrees in 10 minutes you'll be fine. if not adjust the set screw up a quarter turn at a time.
Feb 24, 2014 | Barbeques Galore Grilling
Why won't my 1999 Chevy cavalier start since it got hot and overheated?
If overheated bad enough to blow a head gasket then the compression is leaking into the cooling system. there is not enough pressure left for heat expansion to keep the gas burning. check engine compression if low due a pressure volume loss test.
Nov 12, 2013 | Cars & Trucks
Exhaust fumes comes through my heater in the car
the heater draws air from outside the engine compartment, usually from the grille between the hood and the windshield. check to see if the carpet is wet on the passenger side floor, under the glovebox. I suspect you have a leak in the heater core, and you are getting coolant fumes rather than exhaust fumes. Other signs of a heater core leak would be oily film on the inside of the windshield near the defroster vents, and low coolant level or overheating. If you do actually have a leak in the exhaust manifold, it could be cracked, or leaking from joints in the pipe or where the manifold bolts to the head. If the leak is at the head, you will hear a sharp hiss every time that cylinder fires. You might also be able to feel the hot gas escaping, if you (obviously use extreme caution to not get a severe burn) put your hand near the manifold. If exhaust fumes are getting inside the car, you should also look for unplugged openings in the firewall. The firewall should be as airtight as possible so you should not smell any fumes even if there is a leak.
Feb 06, 2013 | Mastercool ML90062-A-KIT Tecnicians Shop...
Fill radiator with antifreeze but still low when checked no signs of leaks
You could have a slow leak somewhere near the engine or exhaust and when it does leak it just hits the hot part and burns away before it hit the ground. Your best bet is to get/rent a cooling system pressure tester. You can build up the pressure as if the vehicle is hot and since you are doig it when the engine is cold, you will be able to lovate the source of your leak. Like a freeze plug or even in your heater coil. That's what I would suggest. Hope this helps.
Dec 18, 2011 | 2002 Nissan Altima
The regulator has a hissing leak when tank is attached to grill Grill is Master Forge 2-burner gas grill, Model # MFA350CNP The leak was noticed because the grill would not heat to beyond 250 degrees....
You will need the replace the grill's Hose/Regulator Assembly. You can pick one up at any hardware store or home center that sells grills and accessories for about $30.00. Take your old one with you for comparison purposes.
After you install the new one, be sure to check it for leaks, as described in the grill's Owner's Manual. Also, and this is very important. When opening the gas tank valve, open it Very, Very Slowly (slow motion, slow). If you don't, the regulator will lock up and no gas will flow to the burners.
Hope this helped you and thanks for choosing FixYa. Happy Grilling!!
Sep 07, 2011 | Grilling
Gas only leaks out to grill. Can't get grill hot enough.
Turn gas off
Check all orafices make sure they are clear of any debris.replace burner assembly turn gas on turn dial 1/4 turn or so.lite burner with matxh or elwctric
Apr 08, 2011 | Weber Genesis Silver B Grill
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
Gas not coming out enough; flame not catching on to other burners
Problem: Low flames on grill, tank is full.
Cause: These newer tanks have a device inside that limits the flow of gas to prevent leaking or accidental discharge of gas from the cylinder. The leak detector mechanism inside the tank shuts off the gas whenever the valve is opened rapidly.
Solution:
Close the tank valve and remove the tank. Check the gas line for ANY object that could cause blockage. Open all valves on the grill to eliminate any pressure whatsoever. Close all valves and reattach tank. SLOWLY open the tank not over 2 turns. Check for leaks. I just open my tank a tiny bit but that is just me.
This late model gas grill service manual has more details on page 13.
Apr 28, 2010 | Weber Genesis Silver A Grill
Flames only come out very low on both sides
disconnect tank, hook tank back up, then open valve slowly. When opened to fast it thinks valve is leaking and shuts down.
Jun 11, 2009 | Char-Broil CharBroil Master Flame Gas...
The entire 4 gas burners do not get hot
here is the link to brinkmann.net so you can contact them directly.
http://www.brinkmann.net/Customer%20Service/
Now, the most common problem on all recent gas grills is that the regulator in the gas hose now has a safety feature which prevents it from leaking. Sometimes this feature gets stuck.
Unscrew your propane tank from the regulator, tap the regulator a couple of times and reattach it. This may solve your problem. If not, use the link above.
Apr 10, 2009 | Brinkmann 810-8410-S Stainless Steel...
Fiesta Blue Ember Gas Grill Logo
163 people viewed this question
Top Fiesta Grilling Experts
paulcarew
Dan Webster
Dan Webster
Lawrence Oravetz
Are you a Fiesta Grilling Expert? Answer questions, earn points and help others
