Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
About mitsubishi air conditioner model PU-4VLJSA changed compressor started but not get proper suction and compressor over heated already did flushing cappillary tubes cleaned what solution for over heating
HVACOracle
  • 5 Answers
SOURCE: Mitsubishi air conditiner
What?
Posted on Sep 29, 2007
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
relaga58
  • 158 Answers
SOURCE: p8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
Posted on Jun 01, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: replacement of mitsubishi mr slim compressor
Part number T92 500 801
Posted on Mar 14, 2010
heatman101
  • 43501 Answers
SOURCE: i have 2 Mitsubishi electric "Mr Slim" type
Have your system checked by a professional.
From what you are describing here it seems as thoug you have a slight leak in the system somewhere and therefore the system is not cooling or heating properly.
Have them check the system... verify the low charge, fine the leak and repair it.
Vacuum and recharge the system...
Then check the operation before you let them out of your sight.
...It can be tough to get some contrators back if you let them go before you check it...espec. if you pay them...:-)
heatman101
Posted on Nov 19, 2010
PU8YAKD-TH MITSUBISHI UNIT COMPRESSOR INTERNAL PRESSURE BY PASSING
Mitsubishi electric Air condition model number
PU-12YAKD I not know this out door 10 ton or not and PU-8YAKD 6 ton model or not 6 ton can you please tell me
Sep 28, 2013 | Heating & Cooling
Condenser model PU36EK, R22 model suffered a compressor failure and was replaced properly with nitrogen float to avoid carbon build up in piping. Once started with weighed in charge, suction went into a...
There one more strainer in the Liquid distribution in the evaporator you will need to desouder the distributor and you will see the strainer just before the capillary. To get him out just heat the distributor with your torch and with a screw extract it out. Sorry for my poor English I normally speak French. I work on that trouble today but that gave me no results I still have 0 psi in the suction. Maybe I put sylfos too much and close the distributor I will see it tomorow good luck
Sep 18, 2011 | Mitsubishi Heating & Cooling
I had bought a Lg inverter wall mounted unit it worked about 3 days but it didnt cooled the area and i decieded to changed the outdoor unit(compressor)according to repairman's advice .during the first...
You changed the compressor?? Why ??? These models do not normally have problems with this. I am conversant with most of the LS series and these have capacitor start compressors, which fail all the time. Generally all models have either a 45 /6 uf or a 50 /6 uf capacitor. If this fails, the compressor wont start, thus a no heat, no cool problem. If you have changed the compressor and made sure it is actually running, what is the operating pressure?? Suction side should be around 0 to -5 degrees c. Perhaps there isnt any gas in the system??
I assume by doing such a repair you are licensed to do so and have all the proper equipment to recharge the system ???
Jun 16, 2011 | LG LSC121PMA Split System Air Conditioner
Cut out with P5
P5 is possibly drain pump malfunction. check pump is working and also suction and exit lines are clear. Hope this helps -
Jul 22, 2010 | Mitsubishi Heating & Cooling
Fujitsu Air Conditioning split unit Model
Your compressor is seized up. shut down unit and let compressor cool down, it may start again but probably needs to be replaced.... sorry for the bad news,
Nov 10, 2009 | Fujitsu 24C1 Air Conditioner
P8 eroor code
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Apr 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Never gets cold
I think there is a problem with the compressor. The compressor has failed.
Apr 07, 2008 | Dometic Rooftop RV Air Conditioner
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
196 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
