Question about BOSS AUDIO SYSTEMS AVA1204 7Band Car Equalizer
How do i hook up my Boss audio AVA-1204 equalizer?
Where do I connect The red and violet wire
Squealing thats what, solid colors are the pos+ , same color with a stripe of a different color is the neg- side, of the same channel, green+ and GREEN with a white stripe -, its the general rule but it chances with different brands and manufactors..
Sep 15, 2016 | Boss AVA-1204 7-Band Car Equalizer
On my boss ava-1204 equalizer what are the high input line use for to connect to
High input is designed for using speaker level output from another component (such as an amplifier) into the equalizer. Any source that is loud enough to power a speaker is a candidate for that input. The other type of input is the line-level input. This is a more common way to connect components. The power level on these is very tiny and must be amplified in order to be head.
Oct 28, 2014 | Car Audio & Video
How to install Boss audio systems AVA 1210
I tried to install my boss Ava 1210-7 equalizer but I have a 2din001 radio i have a rca jack plug at the back of the radio say AV in its 3 jacks red,white and yellow. I only connect a rca jack to the red and white and leave out the yellow one when I put that to my EQ CD rca section it doesn't work I don't know what to do next! Can someone help Out?
The picture is the rca jack section from the back of my radio
Mar 05, 2012 | Boss Car Audio & Video
Hi i just got a ava1202 boss eq it didnt have instructions this eq has rca inputs and high level speaker inputs can i use this eq with out an amp can smeone plz help me thnk u
Yes you can use the equalizer without an amplifier. That is what the high level speaker inputs are for. You simply take the positive and negative from a speaker and hook it up to the positive and negative high level speaker inputs on the equalizer.
Jun 04, 2011 | Boss AVA-1404 7-Band Car Equalizer
I dont know where to put the remote wire
If you have an aftermarket stereo you can hook it up to the antenna wire usually blue/white or just blue color if is not an after market I need to know the car year/make/model.
Jan 20, 2011 | Boss AVA-1215 5-Band Car Equalizer
What is source ground on an equalizer
Ground Source, not the other way around. It is a metallic place, interconnected to the vehicle chassis, where the electricity will flow from positive to negative. Best bet is to connect your equalizer black ground wire to the radio black ground wire, since it has already been bolted to a good ground. Furthermore, grounding it to radio, will prevent any humming between the two units.
Jan 22, 2010 | Boss AVA-1204 7-Band Car Equalizer
My car stereo
CHECK AND MAKE SURE YOUR BRAKE IS NOT PINCHING YOUR REMOTE WIRE OR ANY OTHER AUDIO SOURCE
Apr 06, 2009 | Boss AVA-1202 7-Band Car Equalizer
No clue how to connect my equalizer
FOR EXAMPLE IF YOU WER HOOKING IT TO A CD PLAYER,, YOU WOULD PLUG RCA JACKS IN THE LINE OUT ON THE CD PLAYER,, THEN PLUG THEM IN THE EQ WERE IT SAYS LINE IN OR AUDIO IN,,THEN TAKE SOME RCA JACKS PLUG IN THE EQ TO AUDIO OUT, THEN TO YOUR RECIEVER,, IN CD ,,AND VISE VERSA ,,WETHER ITS A TV OR PHONO,, ANYTHING,,
Sep 25, 2008 | AudioSource EQ-100 Home Equalizer
BOSS AUDIO SYSTEMS AVA1204 7Band Car Equalizer Logo
100 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
