My WA90G9 washing machine generally works good but only the water flows very slow and sometimes the machine stops with an error display E40. I would like also to request for an ecopy of the operating manual of my washing machine. thanks and God bless.. jose maghanoy
murdozzz2
  • 75 Answers
SOURCE: RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Posted on Dec 14, 2007
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
Posted on Feb 22, 2008
SOURCE: LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Amber
Posted on Nov 11, 2008
  • 26 Answers
SOURCE: Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Posted on Nov 19, 2008
jonniewalker
  • 1031 Answers
SOURCE: E40 on my washing machine
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame ,where the door striker pin goes through hole.hope this helps you.held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
Posted on Feb 20, 2009
Hi my Electrolux EWF1074 isn't working. The timer is counting down but there is no water in the machine. I tried resetting it but it didn't work. Could someone please help me. Regards Matt.
Rapid reading of alarms:
Press the START/PAUSE button and the nearest option button (4) simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
ewf1074-2rgnvy5j4oifscmshudmmeh4-3-0.jpg After reading error code (look display) will be a lot clearer in which phase of the washing cycle has occurred or is happening malfunction.
New washing machine (electronic) compared to the old models (electromechanical) consume much less water, so it looks that your washing machine is working properly, otherwise it would be stopped. This will be confirmed if the display show E00 which means there is no any malfunction. Any other error code, for exp. E10,E20,E30, E40, E50...... means some malfunction.
Dado
Mar 11, 2017 | Electrolux Washing Machines
Hello. my Lavamat 74500 update does not start the wash cycle. everythig is on, door locks but nothing happens.
sounds like a water fill problem to me, normally at start of cycle door locked, program set, start water solenoid opens and fills machine with water, once water reaches set level heater will come on and wash program will commence,
so if you have a restriction in the water supply/ water tap not turned on correctly, on blockage in water solenoid valve water flow to machine will be restricted causing a long delay before machine starts, things to try
1. make sure hose connection water valve is fully open
2.open soap draw to see / if you can hear water flowing into machine,
3 if its very slow you have a restriction in water supply
could be a twist in water supply hose, causing a restriction
all above is if machine is taking to long to fill with water,
good luck .
Oct 05, 2016 | Washing Machines
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
May 07, 2014 | Zanussi ZWF1640 Front Load Washer
I have a GLTF2940ES frigidaire washer. I ran it on permanent press to check water level. Paused it and checked it. changed setting to drain and spin. Now when i press start, the lights go out, and no...
Good Morning Aaron - Based on the symptoms you are describing and if you are receiving an error code E40, your loading door may be ajar. Double-check to ensure that it is closed. If it is secure, reset the power to your appliance for about 30 seconds. You can do this by unplugging the unit or flipping your circuit breaker into the off position. If the error persists, it could either be the door switch assembly or your unit's main control board. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Jul 25, 2013 | Frigidaire GLTF2940ES Front Load Washer
I HAVE A CODE F H THAT STOPS MY WASHER DURING THE 28 MINUTE DURING THE WASH CYCLE AND STOPS THE PROCESS WHAT DO I DO
F H shows when the water flowing into the machine( to fill it up) either does not flow when the control says to flow, or if the water continues to flow more than 10.5 gallons at one time, then the water inlet valve is stopped nd the F H is displayed.
press pause/cancel twice to clear the display. If no water is entering the washer, then chek the hot and cold valves are turned on and check for any kinks in the hoses. also, you may need to remove hoses from washer and check for dirt on the filter screens where the hoses attach.
If water entera the washer but there is too much (over 10.5 gal) then you havwe a whole host of other problems such as: drain pump slow or not working or clogged; pressure switch and small sensor hose to the tub are not dislodged or kinked; check wire connections to inlet valve and pressure switch, drain pump, flow meter, and centrol control board (CCU).
Good luck, Macgivor
Nov 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My whirpool aw614 displays FH error display which suggest water inlet probs, clean filters a;though they are spotless, still get same prob, on some programs it will work until it comes to rinse, where it...
Suspect low water flow rate ., check flow rate from main sink tap , when turned on full this should be pretty fierce. Put machine on normal cool wash , when it is taking in cold water through the soap drawer , pull out the drawer a little , the water flow rate should be allmost the same as the tap , if not investigate , fill pipes at rear etc..
Nov 02, 2009 | Washing Machines
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
