Question about Quark Academic QuarkXPress 6.1 for PC
I purchased Quark Xpress back in 1990 or so, and the installation discs were the old 3 1/4 discs. I paid for updaters, and at updater 6.1, I still have the Quark CD, but some of the original Quark Xpress on my old computer did not transfer properly when I purchased the new Windows 7 computer. Now, Quark Xpress is totally messed up, and I can't use it at all. I have all the validation and serial numbers to show I paid for this, but I need to know if I can go online and 'download' the old Quark Xpress, at least up to the point where my 6.1 updater will take over.
    Problem Solver:
  • 7 Answers
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4.1 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
In fact, if you look into the .DLLs under Windows, you may find versions of the same .DLL that can run under 64, 32 and 16 bit environments. I suspect it will work under Windows 8 if MS doesn't leave working procedures ALONE!
Posted on Mar 26, 2012
  • 415 Answers
I doubt you'd be able to get the old floppy disc version. However perhaps if you contact the company and explain the situation, give them the old key numbers etc, they would send you an install disk (cd) so you can have it running. I would try doing that first. Many companies will assist in that way.
Posted on May 20, 2011
Can't get activation form for Quark 9 on imac running Lion
Did you migrate Quark from your old computer to your new computer? It probably won't upgrade if it doesn't see the prior version.
Jan 17, 2013 | Apple iMac Computers & Internet
Error 1720. Trying to install Quark 6.1 on Windows 7
I definitively solved this problem. Follow these steps:
1) Install first Quark Xpress 6.1 on a Windows XP PC.
2) Copy the entire directory of installed files (Normally c:\program files\quark) on a pen drive.
3) Install Quark Xpress 6.1 on your Windows 7 PC until the installation stops with 1720 error.
4) Abort the installations, then copy the Quark directory stored on your pendrive in c:\programs x 86 directory overwriting the existing one.
This way Xpress 6.1 works perfectly on a Windows 7 PC. Guaranteed!
Sep 02, 2010 | QuarkXPress 6.1
I have a Quark XPress 6.1 system on my AppleMac for my work as a journalist. For some reason, completely out of the blue, when I try to click on a page on my desktop to see on screen I get the clock...
It could be that your quark preferences have corrupted, I would go to your users folder then go into the library folder, then the preferences folder and then the quark folder within the quark folder there should be a file called "XPress Preferences.prf" move this to the trash. (Do not empty the trash if it does not work you can replace the file back into the preference folder) When you open quark next it will recreate the preference file and hopefully that will sort it out. Please note your preferences will be back to default and you will need to reset them. Hope this helps
Jul 02, 2010 | QuarkXPress
Quark keeps quitting
I take it you mean it quits on startup, if so this is what I would suggest.
What you could do is go to users folder then open up the folder of whoever is the active user (generally this user folder icon is a house icon) then open the library folder then the preferences folder and then quark folder then QuarkXPress 6.0 folder.
In this folder there is a file called "XPress Preferences.prf" move it to the trash (Do not empty the trash if it does not work you can replace the file back into the preference folder) and then start up Quark, it should rebuild the file.
I would also suggest that you go to www.quark.com then support and update your version of quark to the most up to date version from 6.0 possibly up to 6.1 or 6.52.
Hope this helps.
Apr 08, 2010 | QuarkXPress Passport 6.0 for Mac
Quark xpress no longer valid error
iI,m also angry, coz i've lost my Cd Key of Resident Evil 4. I want to play But I can't. Plz Tell Me that how can i get back my CD KEY again?
Feb 22, 2010 | QuarkXPress 7 Full Single User Mac/Win...
Quark won't open. I have shut down, completed repair permissions . . . no luck. Starts to load and immediately quits. This started after doing an update on Microsoft Office. What can I do? I am using Quark...
This is for Quark on a Mac. What you could do is go to users then which ever user is the active one then library then preferences then quark then QuarkXPress 6.0 (or may say 6.5) in this folder is a file called "XPress Preferences.prf" move it to the trash (Do not empty the trash if it does not work you can replace the file back into the preference folder) and then start up Quark, it should rebuild the file.
Hope this helps.
Nov 11, 2009 | QuarkXPress
Quark xpress 6.5 crashing
Try updating Quark first and reopen the document, if the problem persists, remove the preference file - this may have become corrupt.
Often a Quark crash is related to corrupt fonts, or fonts sharing the same id number as others already on the machine. Do you use a font manager such as Suitcase?
Aug 28, 2009 | QuarkXPress 6.5
Quark XPress 4.1
quarkxpress_56302.jpg Related Tags:
  • quark
  • xp
  • windows 7
  • windows xp
Problem with Quark QuarkXPress
How can I install my Quark 7 on my new Windows 7? All I get is 'QuarkXpress 7 requires that your computer is running Windows XP or Windows 2003. Help!
Posted by avatar15.jpgNervousFlyer on May 29, 2010
Solutions (2) Start the Windows "Program Compatibility Wizard".
Tell it that you want to install a Windows XP application.
Tell it that the software to be installed is on a CD-ROM.
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
MikeE
Jan 04, 2009 | QuarkXPress Passport 4.1 (112283) for PC
Quark Academic QuarkXPress 6.1 for PC Logo
249 people viewed this question
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Laxman Bisht
Laxman Bisht
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
