Question about Vizio 42 in. LCD TV
I have a vizio 42" lcd tv and it is a 2007 model.
  • 7 more comments
  • mike rondeau May 20, 2011
    fhdtv10a is the model. i actually have two. one of them wont power up at all and on that one i replaced the power supply, and tcon board and still nothing.
    the model is fhdtv10a i actually have two of them the other does not power on at all and i have changed the power supply and the tcon board on that one.
    the model is fhdtv10a i also have another of the same model just a 07 model and it does not power on at all. i have changed the power supply and the tcon board in that one and still nothing.
    what is the j1connector?
    it does not respond at all. the orange icon on the front remains lit and orange. there is no response at all. when i try to turn it on it does not blink or anything and there are also no response at all in the back of the tv. i dont here any clicking in the tv either.
    So do you think that both tvs need the power supply replaced? If the capacitors look good could it be that there is a way to repair the supply instead of replacing the whole thing?
    When I accept your solution is that how you get a vote or do I accept your solution and also vote?
    So do you think that if I touched up all the solder joints that could likely be the problem?
  • mike rondeau May 21, 2011
    Thank you for the very excellent advice and spectacular communication!
  • 4,889 Answers
T-con and inverter boards are not related to this problem so you might as well return them for a refund. When you try to power it on what is the status of the LED at the front ? Does it remain in standby mode or does it turn on but does not respond to any command?
Posted on May 20, 2011
  • 2 more comments
  • eagle338
    eagle338 May 20, 2011
    If you do not hear any kind of clicking noise when you try to power it up then you can be assured that its a power supply board issue as the relays are not turning on at all. So here's the plan. Get me part number off the power supply board and I will find you a replacement. I can tell you for sure that its not the T-con or backlight inverter as when one of these go bad you will have sound but no picture and all other features would workchanging channels etc.)
  • eagle338
    Well it can be probably fixed but component level requires a proper service manual, multimeter nad excellent soldering skills. Besides the power supply costs only about 50-75$ so that would be the best way forward. And yes you just have to accept by clicking the accept button next to my solution. That will be counted as a vote.
  • eagle338
    eagle338 May 21, 2011
    I don't think its a solder joints issue. There is a short in one of the 5v, 24v or 12v lines. We should find the component thats causing the short and replace it. It can be anything like a diode, resistor, voltage regulator. If you have a multimeter and know how to use it we can give it a shot. Just touching the solder joiints wont do you any good
  • eagle338
    You are welcome. Just get me the part number and I will find you a replacement
  • 1,238 Answers
Good day!
if you don't have any bulged top capacitors on the power supply.
Please try this procedure on how to fix that problem.
  1. Remove the back cover of your TV.
  2. look for the power supply board.
  3. check the output voltage of your power supply.It should have 5vdc for the main board,12vdc or 16vdc for the audio and 24vdc for the inverter using multimeter (range on DC)
  4. If the said voltage have no reading or have an voltage drop.The problem could be on the power supply board.
  5. If the output voltage is complete and the voltage is all OK.The problem could be the main board or system board.Its not for D.I.Y because the component of that board is surface mount and its very sensitive.Please replace it with a new one.
I hope this solution will be helpful.Thank you and good luck.
Posted on May 21, 2011
  • bonifacio gomez
    bonifacio gomez May 21, 2011
    Thank you for your positive response.I really appreciate it.
    Please try my solution and update me for immediate response thank you.
    If my solution is helpful please accept my answer.Thank you
  • Vizio Master
  • 2,098 Answers
May I know the exact model no. of your unit. It will help diagnose the exact caused of the problem.
Jdvillanueva
  • Jdvillanueva
    Jdvillanueva May 20, 2011
    I want to know the output voltages at J1 connector. Please let me know...
  • Jdvillanueva
    Your unit is standby mode only. Since you've already replace the power supply board, this is not the issue why the unit didn't power up. Replaced the EEPROM in the main board. This is a 8-pin IC (TA24C16BN) part no. 0430-3011-3011. Most of this symptom was caused by faulty EEPROM.
I plug in my Vizio TV and it will not power on however the orange light in the front is flashing.
Sounds like mine I replaced the Bridge Inverters ( easy job ) , and worked great after that. I got mine from Shop Jimmy dot com paid $85 cheap fix not like $300 - 500 ! you may pay for repair man.
Jul 23, 2014 | Vizio VO420E 42 in. LCD TV
Vizio tv has no power
When you plug in the set, does the Vizio emblem turn Orange?
Jun 09, 2013 | Vizio VX42L 42 in. LCD TV
My vizio wont come back on what do ineed to do to get it to work?
There are several things that could be wrong. When you plug in the set, is the Vizio light orange? When you try to turn it on, does it turn white?
Jan 14, 2013 | Vizio VX42L 42 in. LCD TV
No power, tried plugging in different outlet
When it's plugged in is there a light anywhere on the T.V. that is on?
May 04, 2011 | Vizio 42 in. LCD TV
My Vizio 42" LCD SV421XVT
U getting a non respones from ur remote or the manual side panel tv controls buttons wright.U already tries resetting it back to factory setting.But the problems still the same.Yes,the tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 11, 2010 | Vizio 42 in. LCD TV
Vizio vw42lhdtv10a 42" vizio will not turn on the vizio light is orange when tv not on and white when tv is on it turns white but i get no video or audio the screen doesnt change like it even wants to come...
check out the power supply board! Look for popped capacitors. They either leak or swell up. They are the can shaped things on the board with the plastic coverings on them...you can usually see a swollen cap sticking up over its covering as a telltale sign.
Good luck and be careful
Mar 16, 2010 | Vizio VW42LF 42 in. LCD HDTV
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Mar 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
844 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
