Question about Amana AKT3020 Electric Cooktop
Looking for the cooktop glass,need help part # d8599904
Glass cooktop cracked
Glass cooktops can be removed/replaced with the aid of two small screwdrivers. Gently go around the outer rim using the two screwdrivers like tyre levers don't due too much pressure and it will generally lift quite easily.
Mar 23, 2014 | Samsung NE595R0ABSR/AC 30-in Smooth...
Purchased the cooktop from Sears over a year ago. Something fell on the edge of the cooktop and it broke. The burners all work but looks ugly.would like to fix or replace it. What are my options? Shoul I g...
Is what broken and lools ugly the glass for the cooktop? if that is the case you should know the cost just for the glass is $470.00 plus the service call and labor it's going to be at least $600 to replace the glass
Gene
Aug 05, 2011 | Bosch NET8654UC 37 in Electric Cooktop
I have a Cooktop Jenn-Air Model JED8430. The cooktop glass is broken. Would it be possible to change only the glass? If so, where could I get an other one ?
Yes, you can change just the glass. It is called the maintop assembly and usually starts at $275 and goes up. You will need to get the remaining 3 digits for your particular model in order to get the right glass. A good place to start looking would be: http://www.searspartsdirect.com/partsdirect/part-model/JED8430?pathTaken=modelSearch&prst=0&shdMod=JED8430
Apr 15, 2011 | Jenn-Air JED8430 Electric Cooktop
I need to replace the glass cooktop. Can anyone
you have to call the company who it was manifactured out of sorry
Jan 14, 2010 | GE 30 in. Profile JP989 Electric Cooktop
Was cooking fudge-hot sugary liquid boiled over onto glass cooktop. I tried to clean, but appears as if glass top has been ruined. It is rough. Tried scraping with razor, but does not help. Used cooktop...
Maybe try white vinegar - apparently you can clean glass hobs with it & it might help dissolve the fudge stuff if you pour it on that. I wouldn't use a razor as you might damage the hob more.
Dec 15, 2009 | Jenn-Air JED8430 Electric Cooktop
I HAVE A WHIRLPOOL ELECTRIC COOKTOP WITH A LARGE CRACK CAN I REPLACE JUST THE SURFACE IF SO WHERE CAN I GET ONE?
The glass can be replaced. Go to any appliance parts website and look up the model number for your cooktop. They should have a parts directory and then search for your cooktop glass. I warn you though - the glass is almost as expensive as a new unit!!
Mar 13, 2009 | Whirlpool GJC3034 Electric Cooktop
Looking for new spare parts Creda Gas cooktop 42320
Contact this gentleman: Sandor Horky shorky@adcoservice.com
He helped us with parts we needed for our CREDA Model GGH110. I believe the company ADCO is the after market people for CREDA. Good Luck. PA Fi.
Mar 12, 2009 | Cooktops
Jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
Feb 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn-air JED8430 cooktop
Fairly difficult but doable for the mechanically inclined. They are all a little different - look underneath to uninstall the entire unit (turn off power first!). It is probably held in by a few screws. The glass is likely held by screws underneath as well. Hope this helps!
Dec 28, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktop downdraft blower control knob broke off
Hello
Yes their is a way, you need to unplug the power, and look for the brackes that holds the cooktop to the counter, remove those scrwes and lift the cook top, then look under the top lip and you will see small scrwes, remove those and the glass will lift, then just reverse the steps.
Hope this help!!
Eddie Rentas
Tupper Lake NY
Jun 08, 2008 | Cooktops
Amana AKT3020 Electric Cooktop Logo
23 people viewed this question
Top Amana Cooktops Experts
Dan Webster
Dan Webster
Ted Maxwell
Paul Carew
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
