Question about Philips 32MF231D Television
Everything its working perfect on my 32mf23id/37,except I can't turn it on from my remote control , but I'am sure the remote control its good So what's the problem. Please help me to find the problem
  • Anonymous Mar 14, 2014
    my remote control will not allow me to turn on channel 3.. Everything else on the remote works except for the #'S
  • 11,361 Answers
You need to verify if the remote is sending out the IR signals or not first.
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
If the remote checked out OK, then look at the back of the TV first for the "REMOTE INPUT", use a mini-phone plug and insert the plug into the remote input jack in and out a couple times to clean the switch contacts that select between the front IR receiver of the TV or the rear panel IR input jacks.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 20, 2011
Magnavox 32mf23id/37
The video you inserted here shows nothing but a blank screen. Its back-light inverter board should be checked. There is no back-light now. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.
Apr 28, 2013 | Televison & Video
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
My two remotes stopped functioning at the same time.
you have to replace the IR sensor you can order at ebay.
Oct 02, 2012 | LG 37LG30 37 in. LCD HDTV
My Phillips HTS3400/37 Home Theater System came with a remote control, as usual, but it just has stoped working.. I've been trying to make it work by replacing the batteries and it still appears to be...
Try this first on the original remote. Insert the batteries backward and make sure that they make contact with the terminals in the remote control(stick a piece of metal in there to make sure all the posts make contact), then take them off and install them correctly and see if it works, it's a long shot but i've had some luck using this method. now, for the question regarding if the new remote will work, well, i couldn't find the correct code for your receiver using the RCA universal control. The receiver brand(Phillips) is not listed so it probably won't. Here's the RCA control's codes. Just copy and paste the link. http://www.remotecodelist.com/remotes/rca/rca_rcu404.html
Aug 23, 2011 | Televison & Video
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
I bought a Denon AVR-2807 used from eBay, I got it hooked up properly to my speakers, JBL E100 front bi-amped, JBL EC35 center and E50 rears, no subwoofer. HDMI from PS3 to Denon and HDMI from Denon to...
TMI.
This is strictly a remote control failure.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Or look on eBay, usually much cheaper if available.
Another thing would be to make sure the receiver's remote eye isn't picking up infrared from anything else in the environment.
Jun 22, 2011 | Denon AVR-2807 Receiver
My viper remote worked perfect, until now. the unlock/lock and function button work perfectly, except now the car wont start. the start button works and the car tries to start but shuts down. all the...
The issue is not with the remote as you have stated the vehicle attempts to start. The issue may be with an immobilizer bypass module but, I can't say for sure because you mention the year/make/model of the vehicle. Usually the vehicle will give you visual reason for the failed attempt( the lights will flash a set number of times). But, in any event, the issue is not with the remote and more information is required to assist you.
Apr 26, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote control brocken and dont know how to turn on tv without it
hi,
just press the power button or channel up button or down button on the pannel of your tv.
ok
Mar 07, 2011 | Toshiba 37C3030D 37 in. LCD Television
MY REMOTE CONTROL DOES NOT WORK AFTER DARK
bdale
You may have IR interference at night because of other items you turn on at night. Try leaving everything off except your TV and receive, try your remote to make sure it functions. Then turn 1 item on at a time, try the remote to see if it works or stops working. Once it stops working, the last item you turned on is causing the interference. It is then a matter of relocating that item so it won't continue to interfere with the remote functions. I hope this helps.
Ray Calo
DISH Network
Nov 22, 2010 | DISH Network IR Remote Control
Will not recognize a remote
Olevia has no remote code like all the other brands... it is too new.  the universal remotes were made without Olevia codes because there weren't any.  i'm not sure if/when this will change, but i can't wait.  right now we mostly control the TV volume by using the stereo remote........
Aug 25, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
91 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
