Question about Kyocera Mita KM-4035 Printer
Photocopier kyocera km4035 is always paper jam at the document processor, please help me,thank you
    Scholar:
  • 118 Answers
Do you mean that it is always jamming in the Document Feeder on the top of the copier?
If this is the case, I would like to know how far the paper goes in?
If it does,nt move at all, then lift the top plastic cover that sits above the paper. This will lift up and give you access to the paper pickup rollers. If you dont see any paper jammed, give the rollers a good clean with a clean cloth dampened with warm water.
Posted on May 20, 2011
Kyocera TASKalfa 3050ci Photocopier paper jam 0100
remove the fuser and look for paper between the induction and roller systems or wrapped around the fuser rollers
Aug 11, 2014 | Kyocera Office Equipment & Supplies
Paper jam in tray one after receiving every photocopy in kyocera fs6525 wht's a problem ???
First make sure that tray is set up for correct paper size. That would be first thing. Check for paper dust in paper path blow it out. Really sounds like paper tray not set correctly.
Feb 23, 2014 | Kyocera Fs-6525mfp Copier, Printer,...
HI there! Our Kyocera 180 does not photocopy documents. The paper that comes out is just blank. We recently replaced the tonner so we believe there's still enough ink. Should we checked if the photocopier...
if you are getting blank copies nothing on the page you need to check the drum main charge or the developer unit is locked into place correctly and if the developer unit is turning take out the developer unit and see if there is an even coating of dev and toner on the roller use a piece of paper rub of a small are on the developer roller put in the machine and do a copy after take out the developer unit and see if where you marked is visable if it is then the developer unit has a problem as it is not turning
Check the main charge roller it is connected to the side door
Feb 05, 2011 | Kyocera TASKalfa 180 Copier
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
What is code error E70 on kyocera km-1510
the problem e70 is concerning with the document processor of ur machine. either there is a jammed paper on it or the actuator of ur switch on the document processor is broken.
Jun 23, 2009 | Kyocera KM-1510 Copier
Can you help with kyocera cs-1820
Look in the Document Processor, That is the auftomatic feed device.Look for a scrap of paper jammed in the machine.Try using a dustblaster(canned air) to blow the debris out of the feeder.something in the feeder is operating the switch that detects paper in the feeder.Good Luck
Feb 11, 2009 | Kyocera Copystar CS-1820 Black and White...
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
Printer Problem
hi there... our copier in the office is also kyocera... and i also encountered that same problem before.... try to check all areas of your machine especially those that passes the paper... maybe it's still has a piece of paper stuck in it thats' why... that's always the problem of kyocera machine... it is so sensitive...
Feb 28, 2008 | Computers & Internet
Kyocera KM4035 Service Message C6050
the above is incorrect, Kyocera made a mistake by having a thermistor that physically touches the upper heat roller/belt.. it has worn the roller to a point where it throws up the error.. you will have to install a new fixing unit.
I have done over 25 warranty replacements regarding the 4050/5050/2525 etc.
Sep 14, 2007 | Office Equipment & Supplies
Kyocera Mita KM-4035 Printer Logo
256 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
