Question about Viking Professional Series VCBB36 Bottom Freezer Refrigerator
Bottom freezer has ice building up because when it defrosts it will not drain out through the back. Ice builds up to a point where I have water draining out the front of the freezer all over the floor. Drip pan remains dry all the time. Had repairman out twice he couldn't figure it out. Boyfriend tried to fix a year ago and the part where the drain was had rotted out and the drip pan worked for the first time since purchased in2004. Drained for a few months and now I am back to the original freezing up.
    Scholar:
  • 142 Answers
I suppose the ice is building up in the drain trough under the evaporator (inside the freezer). There are two ways used to keep the trough from ice build up. It either has a heater built into it, or the defrost heater is close enough to the trough so that when the refer goes into defrost, it would melt any ice in the drain trough. Or the hose / pipe running from the trough to the drain pan it clogged, in which case you should be able to blow it clean. Note: this hose or pipe has to have a trap similar to the one under your kitchen sink. That is to prevent air from moving up, bringing undesired moisture into the fereezer.
Posted on May 20, 2011
Water in bottom freezer
Sounds like possible defrost drain. Water builds up over time. Need to pull evap cover and see if ice is build up in tray. If so defrost drain, should fix issue
Aug 24, 2012 | Maytag MBF2258XEW
Csx22br freezer ice build up water runs out bottom of freezer
Your defrost drain hole may be plugged or frozen over. Open the freezer door and remove the lower shelf and basket so you can get to the back evaporator cover, and right under it is the drain hole. Remove what ice may be built up and pour very hot water into drain. It helps to have a syringe to remove the water and pour more hot water into drain. Then use a wire or other flexible tubing to poke into drain to clear restriction then flush with water.
Oct 30, 2011 | Hotpoint Refrigerators
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Ice at the bottom of the freezer
bottom of rezzer compartment is supposed to be frozen( depending on timeof cycle) i wouldnt point to a defrost problem unitil the ice build up is hindering refigeration, its quite possible that thte defrost drain has just frozen itself over, and needs to be cleared to allow defrost water to go into the drip pan under unit
May 02, 2008 | Maytag MSD2756GES Side by Side...
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Drain plugged in freezer
First of all, is it ice or frost? If it is ice, I would say you have a leaky water valve to icemaker, running down evap. coils. Replace water valve. If you have frost-find out why it is not defrosting(defrost heater, defrost thermostat, or defrost timer.
Jan 17, 2008 | Refrigerators
Viking Professional Series VCBB36 Bottom Freezer Refrigerator Logo
529 people viewed this question
Top Viking Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
