Question about Panasonic Televison & Video
Does TV model TH-L42D25A have an analogue tuner as well as digital?
  • tedhat May 20, 2011
    Thanks! A weight off my mind for reasons I'll spare you!
  • Panasonic Master
  • 2,098 Answers
Hi tedhat,
Yes, you can select from analogue TV to Digital TV input.
This is also stated in the User's Manual(operating instructions) on page 30.
You may click the link above to view the pdf. format of the manual.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 20, 2011
Just got digital service, can't tune the stations
Check and make sure that your TV has compatibility tuner [analogue / Digital] provided inside. If not, you have to buy a digital to analogue converter to receive digital transmission. Refer the device user manual for details. If f the tuner is digital/analogue compatible; and you can't receive digital channels, it is faulty. The tuner have to be replaced. http://electronicshelponline.blogspot.com/
Dec 06, 2015 | Televison & Video
TV won't recognize channels. Help
Without knowing where you are in the world let me ask
are you trying to tune analogue or digital stations
Here in australia analogue tv has been discontinued and all transmissions are in digital.
your tv even though it says HDready does not have a digital tuner
so if you are scanning for digital you won't have any luck
If i am correct the only option will be a digital set top box or a newer model tv..
Len
Oct 13, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Auto retune has wiped everything. Help
There is the digital tuner (DTV) and the analogue tuner (TV). Make sure you are tuning the digital side as there are no longer any analogue TV broadcasts in the UK.
Sep 04, 2014 | LG 26LH2000 26 in. HDTV LED TV
Lg 26lh2000 wont auto retune, help please.
Is this TV digital? I've lost channels since the change to digital from analogue
I doubt it has a digital tuner but the owner manual should show that or Google the model number.
Sep 03, 2012 | Toshiba 14DLV75 14 in. TV/DVD Combo
Have had digital installed and cannot get tv to work through digital. Any advice?
Hello
Thei Orion model Tv is not equipped with a digital tuner inside. There is only an analogue tuner fitted and only analogue channels can be received by this set. To get digital channels, you have to buy one settop box, which can convert digital signals to analogue signals. In short, a Digital to Analogue Converter should be bought, if you want to get digital channels. OK.
Dec 23, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Cant seem to tune in after digital switch over not got any chanels
If your TV is an older variety that wasnt set up for digital signal you will need a set top converter box.
Jun 22, 2011 | Toshiba Televison & Video
My Sony Bravia television froze on a digital picture today and now when I change channels there is no picture and no sound. I tried to do a digital scan and it picked up no digital signals,. The analogue...
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Regards,
BElectric
Dec 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Does the Bush LT26M1CA have an analogue tuner
Hi, Your Tv does indeed have an analog tuner for UHF and VHF reception. Remember you need to have an external antenna connected to receive anything via the analog input. On your remote in the upper right hand corner is a button labeled tv/dtv that will switch back and forth between your analog and freeview digital. Good Luck, this should Fixya!
Mar 20, 2009 | Televison & Video
Ive got a twin tuner tv card 1 tuner digital the other analogue im on windows vista but the media centre will only tune the digital i cannot find how to get the analogue tuner to work.
Vista will only work with digital signals, you may need to install a software program or hardware to switch from anolog to digital.
Mar 21, 2008 | Computers & Internet
Televison & Video Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
