Question about Alpine Car Audio & Video
I have an alpine amp for a car and the + and - symbols have worn off. I dont even know the wattage or size. The only numbers are on the mother board which are 5710059411-b (pmf310)
  • Darren Kessinger
    Darren Kessinger May 20, 2011
    ok those numbers dont seem to produce ANY results at all so can you describe it more?
    what color is it?
    how many channels?
    can you possibly upload a picture of it to photobucket or some sort of site like that and then provide a link to it?? if you can do that i am pretty sure i can tell you the model , year , and power output information and so on .....
  • 3,018 Answers
  • For this, with such little mark on the amp to indicate what ratings it has I recommend contacting alpine here http://www.alpine-usa.com/product/category/amplifiers and go to the bottom right of the page and click "support" and contact them and tell them the mother board ID number. Alpine does have some real good customer service.
Regards, Tony
Posted on May 20, 2011
Alpine cda9811 powers off when car is running but works fine with key backwards
is the radio the only thing being powered, do you have amps and or subs if so I would assume that your radio is not powerful enough for the added wattage, if you dont have neither of the two you have a shortened ground trace all grounds. 2_18_2014_5_19_28_pm.jpg
Jan 10, 2014 | Car Audio & Video
Just want to know what speaker wattage matches my v12 mrv f705 85 rms x4 channel amplifier?
Use speakers that will handle 85 RMS continuous or higher wattage. I have 200 watt Rockford 6.5s on a 75 watt amp. They sound great with plenty of headroom if I go to a bigger amp.
Nov 20, 2012 | Alpine Car Audio & Video
Alpine MRP m1000
Q4901 is a ktd600k. The actual alpine part number is 48E39128S01. If you are in the U.S. it can be obtained at pacparts.com.
Oct 31, 2012 | Alpine MRP-M1000 1000W RMS, Class D...
On low volume using the clean channel the sound is great but as soon as you get to about three or more the sound gets a bit distorted,the amp is the fender hot rod deluxe, ithort i may had blown the...
try a differrent speaker of suitable wattage and ohmage (displayed with a number next to a ? symbol on the back of the speaker),
or
remove the original amp speaker and gently push in and out on it, checking for uneven resistance or scratching. the speaker should retract and return smoothly, without any scratchiness or uneven resistance from within, and if there is any of this scratchiness or uneven resistance from within, the speaker is likely damaged from too much wattage or distortion.
Mar 09, 2011 | Fender Hot Rod Deluxe Guitar Combo...
How many watts is these woofers?
Manufacturer Alpine Wattage 600 Watt Speakers Format Round Active / Passive Speakers Passive Speakers Installation Built-In Category Pair of Speakers, Subwoofer Number of Ways 2, 1 Size (Diameter) in mm 250 EAN 4958043515356
Sep 30, 2010 | Alpine SWS-1040 Car Subwoofer
I have an alpine type rs one is a1542 and one is 1522 how can I make them hit the same or can I ?
I dont think it matters but it is not really a good idea to have two different subs in one box (if they are). They need to be in phase. They have to have the same amp is running them with corrects wattage and impedance, ya they can hit the same. The subs are so much the same i really dont think it matters if they are in the same box.
Feb 12, 2010 | Alpine SWR-1542D Car Subwoofer
Alpine 9845 cde head unit car stereo i Cannot figure out how to access the Fader not the balance,altho i havent seen that function either. ive been to the alpine site and they dont even mention it. im sure...
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS → TREBLE → SUBWOOFER* → BALANCE → FADER
→ DEFEAT → VOLUME → BASS
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
Feb 11, 2010 | Alpine CDE-9845 CD Player
I wired my 2 alpine 10 inch type r's to 2 ohms. now when i play it they play just when i try to crank it the subs just like shut off but the amp stays on. even at low gain and low bass eq. i dont know...
It sounds like it may be going into a protect mode. You may be overloading the amp. You might want to go higher impedance and take it easy on the amp. The internal power supply MAY be collapsing under the load.
Don't believe all the numbers that manufacturers put out... we call that "Specsmanship"... in other words INFLATED numbers so you buy ours instead of theirs.
Jan 23, 2010 | Alpine MRP-M650 Car Audio Amplifier
Need to know how to wire Alpine 12" 1242D 4ohm Want to use 1 speaker in ported box with Phoenix gold 2200pro amp
As long as the total wattage of the amp does not exceed the total wattage of the speaker, you can bridge the amp. To do this, put the positive wire of the speaker on the positive terminal of channel 1 on the amp, and the speaker negative wire on the negative terminal of channel 2. This allows you to run the amp's full power into one speaker.
Aug 02, 2008 | Alpine Car Audio & Video
Car Audio & Video Logo
71 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
