My Wi-Fi isn't working isn't working, no matter what I try or do it is not getting any access points, what could be the problem?
Boot to F8 then select Last known good configuration. If no fix then boot back to F8 then safe mode then system restore from the time everything was working fine.
If all no fix do the following:
Check if your laptop can see other network aside from your home network.
If your laptop cannot see any network check if the wifi or wireless switch is turned on.
If the wifi or wireless switch is on then uninstall / reinstall the wlan or wifi driver.
Posted on May 20, 2011
Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
Jan 27, 2015 | Mach Speed Trio Stealth G2 Tablet -...
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
I have a net rca tablet. It works fine except it won't go on wifi. I did exactly what I was suppose to do, and it won't connect.
Hi
I presume that the tablet detects a Wi-Fi network,since you say it won't go on to it.
A couple of points here - firstly this tablet will not go onto mobile broadband as there is no mention of a SIM card capability in the manual, which can be obtained in pdf format here:
http://www.rcatablets.com/sites/default/files/RCT6203W46%20IB_English.pdf
OK - one point down, so now we are talking about wireless access points. If the tablet doesn't detect an access point, it obviously won't connect. If it can detect an access point, then you need the access code to join that particular network. When you tap on the access point SSID (identification), it should ask for a wireless key which you must enter in order to access the Wi-Fi network and get on line.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 03, 2014 | Tablets & eReaders
Removing bluetooth chip
Without knowing what the desktop computer motherboard is, I\'d only be guessing as to location of Wi-Fi chipset.
However even if I knew the motherboard manufacturer name, and model number; the point is Moot.
A) You remove that Wi-Fi chip, and kiss the motherboard goodbye.
It\'s designed into the circuitry of the motherboard.
Isn\'t going to be jumper wires taking it\'s place, and making connections to circuit traces on the motherboard.
B) Do you have a wireless router?
Dunno.
Do you have a wireless connection set up?
No.
You can use just a LAN connection. (Hard wired)
C) Suggest if having a Bluetooth option on your motherboard is not an option then use a different motherboard that doesn\'t have that option.
Regards,
joecoolvette
Apr 06, 2013 | Computers & Internet
I want to locate my wi fi password for my iphone.
I am assuming that you are trying to connect to the internet using the built in wifi instead of the 3G. To clarify, iphones don't have passwords for wifi. Wireless access points and wireless routers are the ones that have passwords. If you want to connect to the internet using an access point or router you must get the SSID of the router or access point and also the encryption and password to join said access point or router.
Once you have this information go to your iphone and select the settings icon. Then select the Wi-Fi, then turn on the wi-fi (if it is off), then under choose a network select "Other" and then type in the name (which is the SSID), tap on "Security", select the encryption that matches your access point or router (wep, wpa, wpa2, etc) tap on "Other network" (on the top left hand corner) to go back to the configuration page, and then type in the correct password.
Once you have done this your iphone will automatically connect to the access point or router whenever it is in range and connect to the 3G when it is out of range of the access point or router.
Hope this helps.
Aug 03, 2011 | Computers & Internet
Can't get my wi-fi connection to work on it
Here's How:
  1. Turn on the Nintendo DSi
  2. Click on the wrench icon to access "System Settings."
  3. Select "Internet" on the third page of System Settings.
  4. Select "Connection Settings" and tap the "None" bar in "Connection 1."
  5. You have the option of setting up a connection manually, or searching for available connections in the area. You may also access your Nintendo Wi-Fi USB connector, if you have one (the product has been discontinued). The easiest thing to do is select "Search for an Access Point."
  6. Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
  7. If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key.
  8. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify.
  9. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Jul 21, 2011 | Nintendo DSi XL Burgundy
Wi-fi froze in middle of game and cant get it back
Seems like intermittent wi-fi issue. Suggest you to upgrade your router's latest frimware
Jul 09, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
I have a 5 month old HTC Wildfire. I don't have access to WiFi and most often use Vodafone Mobile Connect to connect to the Internet. Suddenly, since the day before yesterday, whenever I'm trying...
Seems like your phone is functioning correctly.
You have disabled wi-fi so it is asking whether you wish to use Phone Data Connection instead. (Standard Practice when trying to access data services)
What you need to do is un-tick the option in options Use only 2g networks. (3g is the mobile data service) That should then allow you to access Mobile Data. (3g)
Also enable data enabled
Jun 17, 2011 | Cell Phones
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
