Question about Toshiba Satellite L675-S7048 Notebook
The keys stick and/or skip - Toshiba Satellite L675-S7048 Notebook
    President:
  • 1,216 Answers
Use a small screwdriver to gently pop the sticky keys off of the keyboard. You do not need to use excessive force, as a bit of gentle pressure should allow the key to come loose easily. If you are cleaning the entire laptop keyboard, draw a keyboard map on a piece of paper so that you know exactly where each key goes. There may be a small piece of rubber connected to each key, depending on your make of laptop, so remove these as well and place them in a small container, as they are small and easily lost.
2 Clean the exposed area under the key well with a cotton swab slightly dampened with rubbing alcohol. Replace the cotton swabs often as they collect residues, but be sure that they are only very slightly damp, as excess liquid can damage the keyboard. You can roll the swab against the opening of the alcohol bottle to remove excess liquid making sure that alcohol does not drip from the swab.
3 Scrub the actual keys and their rubber components with cotton swabs and alcohol, removing all traces of grease and sticky residue. Spray the keys with standard household cleaner and allow them to set for at least five minutes before rinsing them thoroughly with hot water. Put the keys on a paper towel and allow them to dry completely.
4 Set the rubber components aside and place the laptop keys bottom side up on a paper bag. Coat the keys very lightly with film lubricant and allow them to dry. Make sure that the lubricant covers all of the small guide spaces inside of each key; however, you must be careful not to use too much lubricant, as the solvent can damage the plastic.
5 Apply a small amount of solvent to the tip of a cotton swab and lubricate the exposed key space on the keyboard, again being sure to cover all of the small spaces. Allow the keyboard to dry thoroughly.
6
Replace all of the rubber components into the keyboard and then install the keys. Make sure that the wire is placed into the guide slot next to the key and apply firm yet gentle pressure until the key snaps into place. Congratulations, no sticky keys!
Posted on May 20, 2011
How do you fix a skipping typewriter?
Skipping as to spaces in typing. usually lubrication, what is called the escapment under the keyboard is usually sticking. It works like a rocker one tooth goes to what is called the star wheel, moves one space and the second tooth catches it. Usually spary that are with WD40. If it works you need to lightly spru with spay oil or silicone. could be broken teeth also on gears and what is called escapment rack, good luck.
Aug 04, 2014 | Smith Corona Vintage Classic 12 Manual &...
Car stuck in drive wont let me turn it off so i took the batter cable off
please elaborate this.
the engine wont shut down, at key off>
the tranny A/T will not stick in drive. how can it do that?
are you saying the A/T transmission shift lever is stuck in
PRNDL. lever.
in D, L or 2 or 1? stuck, means you can move the the lever.
and all cars shift to Neural at any time. from any gear.
(cables seizures , excepted)
my wild guess, is the dash lamps (cluster) glows, key out?
tell all things that glow, key out (skip Headlamps and parking lamps
as the always glow key off, if active)
Feb 14, 2014 | 1991 Honda Accord
Y Logitech keyboard K120 theletters are skipping
Sounds like you need to clean it. If you take a straw and hold the other end next to the keys that are sticking, blow a steady air under the keys, this may fix your problem, though you will have to do a good cleaning eventually. GOOD LUCK. Believe me, Iv'e been where you are, and I know it's aggravating.
Jul 02, 2012 | Compaq Keyboard
My keys seem to stick a little on my laptop..when i try to type fast it skips letters or the space bar
could be dirt under your keys try cleaning with compressed air or pc cleaning foam and a soft cotton bud, be gentle tho as the keys are very tricky to put back on if they pop off
Nov 24, 2009 | Acer Extensa 4620 Notebook
STICKS on cycle, wash, etc. If manually moved
Do you mean the timer or control dial sticks. If so then it may be the timer mechanism itself.
Make sure that when you are skipping a turn on the timer that the machine is actually performing that particular task of the cycle. For example if the timer gets stuck before the drain cycle, and you manually skip forward to it, that it actually drains the water out.
If so then it is most likely a worn timer mechanism which sticks.
Ash
Oct 23, 2009 | Frigidaire Dishwashers
Compaq laptop keys doubling like ny comes up for the letter n
the keyboard is skipping letters it sounds like. Get the keyboard replaced, keys tend to stick over time due to dirt, dust, etc.
Aug 09, 2009 | Compaq Keyboard
I need instructional manual for tiger wood 08 pc dvd
Tiger Woods PGA Tour 08 (IBM PC Compatible) Instructions:
COMPLETE CONTROLS
GENERAL KEYBOARD CONTROLS
Alt Key = open pop-up menu
Control Key + M Key = return to main menu
Control Key + K Key = view scorecard
Control Key + L Key = view leaderboard
Control Key + O Key = options screen
Control Key + B Key = view caddie book
Control Key + S Key = save game
Left Arrow or Right Arrow Key = aim left or right
> or < Key or Mouse Wheel = select next club
[ or ] Key = select next shot type
Esc Key = skip ball flight, cancel shot
T Key = toggle trueswing analyzer on or off
M Key = take a mulligan (if enabled)
/ Key = bring up putter
P Key = enage practice swing (once to take a swing, again to step up and address yout ball)
CAMERA CONTROLS
W, S, A, or D Key = move camera forward, backward, left or right
F or V Key = move camera up or down
- or + Key = slow or speed up camera movement
1 Key = swing view
2 Key = ball-drop view
3 Key = blimp view
4 Key = green reading view
5 Key = ball cam forward to green
6 Key = low camera to flag
7 Key = tv tower tee box view
8 Key = tv tower greenside view
9 Key = side profile swing view
0 Key = opponent view
Control Key + E Key = camera editor
E Key = shot target camera
G Key = toggle grid on or off
O Key = toggle overhead map on or off
ONLINE GAMES
Enter Key = chat
GAMEPAD SWING CONTROLS
SETTING UP A SHOT
D-Pad = move targeting mark
5 Button (Hold) + Left or Right Analog Stick = control free camera
9 Button = watch the hole fly-by overview
10 Button = preview club yardage
6 Button = switch clubs
4 Button = change camera view
1 Button = select shot type
3 Button = zoom to targeted landing spot
2 Button = start swing
SWINGING
2 or A Button + Left or Right Analog Stick Down = begin backswing
Left or Right Analog Stick Up = downswing
Left or Right Analog Stick Back Diagonally + Left or Right Analog Stick Up = draw or fade the shot
PUTTING
Left or Right Analog Stick Up and Down = putting
TRUESWING
Mouse Back = backswing
Mouse Forward = downswing, follow-through
Esc Key of Left Mouse Button = interrupt a swing
Jan 01, 2009 | Electronic Arts Tiger Woods PGA Tour 08 ...
Engine skips
When you press the clutch the engine control computer senses the clutch is in and adjusts the idle speed, maybe the idle speed control motor is dirty and sticks, this will almost feel like a skip or miss, do you have any trouble codes?
Dec 03, 2008 | 2000 Mitsubishi Eclipse
My benz in trunk cd changer skips....
Hi if you have cd lense cleaner try run it twice so that the small particles stick it lense will be remove .
also put some rubberized foam cushion around the cd if buit in.
Jan 30, 2008 | Sony XR-C6100 CD Changer
Toshiba Satellite L675-S7048 Notebook Logo
134 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
