Question about Cameras
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even used another freshly charged battery but the camera still won't turn on.
    Master:
  • 340 Answers
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
Posted on May 20, 2011
Testimonial: "great feedback and fast...still trying to find a solution...Thanks!"
  • bettywolf14 May 20, 2011
    Nothing happens..not a sound when I turn the camera on...I have tried to clean the battery connection and that doesn't help either. I have taken the lens off and on and still nothing....
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
I got my camera 3 weeks ago. Now Im on vacation in Thailand and used the camera snorkeling. Yesterday the camera "froze" so the only way to get it going again was to remove the battery. Today...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 04, 2011 | Pentax Optio W90 Digital Camera
My Kodak af 3x optical aspheric lens camera won't turn on. it was fine yesterday but today it wont turn on. I've charged it and everything but it doesn't do anything. Help!
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Sep 24, 2009 | Cameras
Canon 40D Autofocus not working
Maybe The Button Is Broken Chek The Button If It Still does Not work Let an Axpert Chek Your camera
Sep 22, 2009 | Canon EOS 40D Digital Camera
Canon 50D failure to turn on
Did you figure this out? I would send it back asap so your warranty can cover the problem. Also run over to Ritz camera or another camera store to figure if they can help. Ask for their Canon expert. I hope this helps.
Jul 04, 2009 | Canon EOS 50D Digital Camera
Help
Wow, this is trully amazing. I went to do a search on why my camera wouldnt turn on the past couple of days, even after i charged all THREE of my batteries and found similar complaints within the same time frame!! WOW. We need to get together and fight this, cause its suspect!!! I bought mine in Mass, anyone else?
Jun 30, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Help
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 25, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Jazz dv179
Please call Jazz Products @ 732-572-7050
Mar 08, 2008 | Jazz DV-179 Digital Camera
Digital camera wont turn on
I just answered another question similar. Try that.
http://www.fixya.com/support/t244396-wont_turn
If it HelpsYa, please choose FixYa! ThankYa! =)
Nov 30, 2007 | Fuji FinePix A360 Digital Camera
Cameras Logo
246 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
